Syntaxproblem LU decomposition of a matrix
Old   January 20, 2009, 06:40
Default Hello! I am having a proble
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hello!
I am having a problem with the the syntax used to decompose a matrix with LU decomposition.
I found two makros:
scalarMatrix::LUsolve declared as:
template<class>
static void LUsolve (Matrix<scalar> &matrix, Field<t> &source)
and simpleMatrix:LUsolve declared as:
Foam::Field<t> LUsolve ( ) const
Here is the snippet from my code:
volTensorField D = fvc::grad(U);
volTensorField Wtr = 0.5 * (D.T() + D);
volTensorField WtrLambda = Wtr - test * I;
volVectorField solution = WtrLambda.LUsolve();
The compiler gives me the following error:
error: 'struct Foam::volTensorField' has no member named LUsolve.
I understand, that LUsolve is obviously not a member function of volTensorField.
Can anybody tell me the correct syntax to use the LUsolve macro? What is the difference between the two macros?
I searched the forum, but I couldn't find anything regarding this topic.
Thank you a lot!
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   January 20, 2009, 12:57
Default Dear Kathrin, I am not exac
Henrik Rusche
henrik is on a distinguished road
Dear Kathrin,
I am not exactly sure what exactly you are trying to do. There are many ways to assemble and solve a linear system in OF depending whether you seek a solution for a standalone linear system, a discretised PDE or a pointwise solution.
simpleMatrix is a NxN matrix & solver. It doesn't know about geometric Fields. It is used, for example, in the ODE solvers - where you can also find examples how to use it.
scalarMatrix is used to solve discretised PDEs, but you would normally go solve(ffm::div(s)) or similar.
However, my feeling is that you a looking for a pointwise solution of a 3x3 matrix (or tensor). If this is the case, you want to check out Tensor::cofactors and Tensor::inv (see $FOAM_SRC/src/OpenFOAM/lnInclude/TensorI.H).
BTW, symm(D) is faster than 0.5 * (D.T() + D) and can also be found in $FOAM_SRC/src/OpenFOAM/lnInclude/TensorI.H.
Henrik
henrik is offline   Reply With Quote
Old   January 20, 2009, 13:46
Default Dear Henrik, thank you a lo
Kathrin Kissling
Dear Henrik,
thank you a lot for your answer. That helps me a lot!
Regards!
Kathrin
Addressing matrix element and reuse of system matrix marziolettich OpenFOAM Running, Solving & CFD 2 February 19, 2008 06:04
Skewness & Decomposition Marc FLUENT 2 July 5, 2007 15:54
CCM+ and manual decomposition William Blake Siemens 3 June 29, 2006 17:43
Helium-Decomposition chakri Main CFD Forum 1 December 13, 2002 05:17
Elemtary matrix to CSR global matrix xueying Main CFD Forum 2 September 24, 2002 10:44
