Specifying nonuniform initial condition
Like Tree6Likes
Old   January 20, 2009, 15:05
Default Hello! I am a new user of Ope
  #61
Suraj Deshpande
suraj is on a distinguished road
Hello!
I am a new user of OpenFoam. I was looking at the damBreak case and nozzleFlow2D case. Both the cases require setting a non uniform gamma field. However, the damBreak case uses setFields utility to do this while nozzleFlow2D uses cellSet utility. Is there a particular reason why this is done? When I looked at the user manual, I saw that both these utilities are for selecting a cell set through a dictionary- one does it in preprocessing while the other does it in mesh manipulation.
Can somebody please help me know why two different dictionaries are used here?
Thanks,
Suraj
suraj is offline   Reply With Quote
Old   March 17, 2016, 05:01
Default Velocity Boundary condition on Imported 3D Mesh
  #62
Abhishek
Abhi16 is on a distinguished road
I wanted to specify the given Velocity Boundary Condition varying with distance from Base of Fluid Domain).For this I have created a Body and have done meshing on it,then imported in openFoam.I have tried using
inlet
type fixedValue;
value nonuniform List<vector>
45
(0 0 6.7)
(0 0 6.8)
(0 0 6.90)...
There was a option for specifying velocity vectors at the specific patches(given above), but I am not able to understand how to specify faces for each velocity vector in the Inlet patch of the imported Mesh.
Alternatively, Is there is any option to specify the Height of the vectors they are acting at??
Abhishek
Abhi16 is offline   Reply With Quote
Old   March 19, 2016, 18:17
Retired Super Moderator
Bruno Santos
Quick answers:
  1. setFields should be able to help you with this task, if the values are constant at a specific height.
  2. If you need a more mathematical way of defining the values, for example, by defining the value in function of the height, then you can try using funkySetFields.
Old   March 28, 2016, 01:08
Default Imported Mesh
  #64
Abhishek
Thanks for the reply
But I have a doubt does it work for IMPORTED Mesh as well, if so then how do we apply setField there.
Abhishek
Old   March 28, 2016, 09:19
Bruno Santos
Quick answers:
As long as the mesh is valid in OpenFOAM, it should work.
Have you done the 3 tutorials from the OpenFOAM User Guide? http://cfd.direct/openfoam/user-guide/tutorials/
Have you managed to import the mesh into the OpenFOAM case? Can you share the case? Or at least provide a simple test case so that it's easier to show you how to use setFields.
More details available here: http://www.cfd-online.com/Forums/ope...-get-help.html
Old   April 25, 2016, 05:23
Default non-uniform velocity profile
  #66
katia chekini
cyndy M is on a distinguished road
hello everyone
I'm using OpenFoam for my study and I would like to specify non uniform initial conditions for my case (velocity).
Can someone tell me more about that. I'm a begenner and I have no idea how to do it
thank you
cyndy M is offline   Reply With Quote
Specifying nonuniform boundary condition maka OpenFOAM Running, Solving & CFD 59 October 22, 2014 15:52
Nonuniform initial condition using cellSetDict rinao OpenFOAM Running, Solving & CFD 6 January 9, 2013 01:42
Initial Condition Tang Kuei FLUENT 0 May 17, 2006 20:54
Nonuniform gradient boundary condition ankgupta8um OpenFOAM Running, Solving & CFD 1 March 14, 2006 02:34
Nonuniform initial conditions nico OpenFOAM Pre-Processing 2 January 4, 2006 07:37
