Solve Simple foam for laminar flow
Old   January 16, 2009, 15:52
Default Hi All, I am relatively new
Vishal Nandigana
nandiganavishal is on a distinguished road
Hi All,
I am relatively new to openFoam.. I just finished solving the tutorial for SimpleFoam, but I would like to know how the simple foam is used for laminar flow equations as the k epslon terms are not there for laminar flow right... So how do we change the code to make it work for laminar flow...
Kindly give your suggestions in this regard.
Regards
Vishal
nandiganavishal is offline   Reply With Quote
Old   January 17, 2009, 02:46
Default In the constant/RASProperties
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
In the constant/RASProperties file, set the RASModel to 'laminar' instead of 'kEpsilon' and turbulence to 'off' instead of 'on'.
When running the case, you should then see these messages before the first time step:
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model laminar
To find out all the available options, set the 'RASModel' to some arbitrary text, say 'scooby_doo' and then run simpleFoam. The code will then return something like:
Unknown RASModel type scooby_doo
Valid RASModel types are :
15
NonlinearKEShih
kEpsilon
realizableKE
LienCubicKELowRe
LienLeschzinerLowRe
LaunderSharmaKE
laminar
SpalartAllmaras
LienCubicKE
LamBremhorstKE
RNGkEpsilon
LRR
QZeta
LaunderGibsonRSTM
kOmegaSST
Now, you have a full list of available turbulence models!
msrinath80 is offline   Reply With Quote
Old   January 17, 2009, 10:03
Default What does turbulence when set
Mahendra
mahendra is on a distinguished road
What does turbulence when set to "on" or "off" while selecting RASModel laminar mean?
mahendra is offline   Reply With Quote
Old   January 19, 2009, 14:35
Default Hi Srinath, Thanks a lot fo
Vishal Nandigana
Hi Srinath,
Thanks a lot for the reply. I would like to know if I select these two options, then what should we do for the RASModel transport properties... as there are many property values like kepsilon etc.. similarly in the fvsolution all these k-e values are present.. wat should one do to these parameters...
Kindly let me know...
Regards
Vishal
Old   January 20, 2009, 01:56
Default Well, they're not used to my k
Well, they're not used to my knowledge. So they are just ignored for laminar flow.
Simple foam solver mardinoglu OpenFOAM Running, Solving & CFD 1 October 17, 2014 05:56
Simple Foam flow around airfoil topik OpenFOAM Running, Solving & CFD 15 April 15, 2009 10:59
msha solve Eqn programming in C using FOAM msha OpenFOAM Running, Solving & CFD 2 January 6, 2008 08:03
msha solve Eqn programming in C using FOAM msha OpenFOAM 2 December 30, 2007 03:39
Can the FOAM solve the conjugate heat transfer problem ztdep OpenFOAM Running, Solving & CFD 1 September 15, 2005 15:26
