Marangoni bc
Like Tree7Likes
Old   May 19, 2017, 04:21
akidess's Avatar
Anton Kidess
Originally Posted by gtarang View Post
Hello Thomas,
I am implementing the same boundary condition. However I want to ask, do we really need to update the solver application? There must be another way of adding this IOobject externally I mean through codeStream or function object. Pl. suggest.
Tarang
That's right, you can replicate the functionality using a groovyBC boundary condition. Probably also with codeStream, but I haven't used that yet.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   March 1, 2019, 05:31
Navid
navidamin is on a distinguished road
Hey guys!
the links to the files that tehache posted are apparently corrupt now. Can any one please upload the files and post the link here?
Thanks
Originally Posted by tehache View Post
I updated the boundary condition a little (its now writing also its value, was missing before..), and its working for me now with 1.6.x.
As the testcase was too large to upload here, please find it (and the B.C.) at the links given below.
Under the link named MarangoniTest I add a small testcase. Gravity is set to 0, Marangoni-Number is small in order to obtain a stationary and axisymmetric solution (although calculation is 3D), which I have compared to results from our own 2D-Code Crysmas, and with Fluent, results are (within some percent, did not check grid dependence..) the same.
Therefore, I personally trust it, but dont give any guarantee
I have run the testcase using a slightly modified buoyantBoussinesqSimpleFoam:
add this to createFields to store temperature gradients:
Info<< "Generating/reading field gradT\n" << endl;
volVectorField gradT
IOobject
"gradT",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
mesh,
dimensionSet(0,-1,0,1,0,0,0)
gradT=fvc::grad(T);
and add this in the solver code:
turbulence->correct();
-> gradT=fvc::grad(T);
runTime.write();
specify the B.C. in U as follows:
outerwall
type marangoni;
marangonicoeff -9.9e-06;
the marangonicoeff to specifiy is the usual marangonicoefficient (d sigma/dT) divided by DYNAMIC viscosity!
http://servww6.ww.uni-erlangen.de/~jung/marangoniFvPatchVectorField-1.6.x.tar.gz
http://servww6.ww.uni-erlangen.de/~jung/MarangoniTest.tar.gz
Thomas
navidamin is offline   Reply With Quote
Old   March 1, 2019, 06:13
Default Marangoni Condition
  #23
Tarang
gtarang is on a distinguished road
Here, use this. I am also right now seeing the feasibility if gradT can be calculated inside boundary patch only. Let's see when I am able to do it. For the time being you calculate gradT as mentioned in the post. Further you can use
IOobject::NO_READ,
IOobject::NO_WRITE
in place of
There is no need to read or write the gradT.
PS: The file will work for Openfoam-4.1 onwards
Tarang
navidamin and fjgwd002 like this.
gtarang is offline   Reply With Quote
Old   March 1, 2019, 06:42
Navid
Thanks Tarang!
could you please also upload your sample case?
Old   November 1, 2019, 01:49
Nikhil Chitnavis
Nikhil2511 is on a distinguished road
hello,
I am using the marangoni Bc for the 2D square cavity with temperature and concentration given to side wall but the results i am getting is not correct, the flow is not developing. I am using Marangoni BC with simpleFoam.
please suggest something on this.
thanks
Nikhil2511 is offline   Reply With Quote
Old   July 12, 2020, 15:59
Default Marangoni Boundary condition
  #26
Tarang
I have updated the marangoni condition to work with both compressible as well as incompressible solvers. The boundary condition calculates gradient of temperature internally. I have tested it in my problems and it is working well. Let me know if you face any problem.
You can also check out my github page
https://github.com/gargtarang/OpenFOAM_Extensions_TG
This I maintain mainly as an hobby or interest.
Thanks
gtarang
sxpsxp007 likes this.
Marangoni stress, help!! dong FLUENT 2 February 23, 2024 13:30
Marangoni flow Tao CFX 0 September 4, 2007 18:14
Marangoni Convection Rucy FLUENT 0 July 6, 2005 06:17
Marangoni Stress At the Wall Peter Nagy FLUENT 4 January 26, 2004 16:06
Marangoni VS Rayleigh-Bernard Peter Nagy FLUENT 2 January 12, 2004 10:53
