Multiphase Flow n phases
Old   August 25, 2009, 09:50
Sandy Lee
sandy is on a distinguished road
I also want to know.
sandy is offline   Reply With Quote
Old   January 3, 2010, 07:03
Claus Meister
idrama is on a distinguished road
Hey people!
Could anybody tell me what is the purpose of the file
0/alphas!
Cheers,
Claus
idrama is offline   Reply With Quote
Old   January 13, 2010, 16:27
Kent Wardle
kwardle is on a distinguished road
The 0/alphas file is simply a field combining all the phases into a single field that can be plotted--for example, if you have 4 phases, the alphas field will go from 0 to 3 (it is automatically computed and will show up in time directories after 0). Over the continuous scale, 0=phase1, 1=phase2, 2=phase3, 3=phase4. The only trick here is that if you have a phase boundary between phase1 and phase4 then it will look like there is a small layer of phase2 then phase3 between 1 and 4--that's the problem with a continuous color scale. Unfortunately there is not really any other easy way to visualize the phases. If you learn of one I would be interested .
kwardle is offline   Reply With Quote
Old   May 10, 2017, 14:28
Default model for incompressible multiphase flow with phase change
  #24
Abbas Rahimi
AbbasRahimi is on a distinguished road
Originally Posted by duderino View Post
Hi Henry
What does this mean? Are there any plans to do this?
Best regards duderino
Hi foamer,
I wonder if you could kindly point me to any possible models to take care of incompressible multiphase flow with cavitation?
Thank you.
AbbasRahimi is offline   Reply With Quote
Old   January 25, 2018, 06:03
Default three-phase flow
  #25
Lucie
Goldberry is on a distinguished road
Hi!
I'm modelling a three-phase flow (air, water and a third Newtonian fluid). The third fluid generates waves by sliding on a slope into water. I tried to use multiphaseInterFoam but I am not satisfied by the results comparing to experiment and another code. I am wondering if I set the computation right.
Are there any validation cases available? Or is someone working on a similar case using OpenFOAM?
Lucie
Goldberry is offline   Reply With Quote
Old   January 25, 2018, 07:12
BlnPhoenix is on a distinguished road
Originally Posted by Goldberry View Post
Hi!
Lucie
You can use the expample cases in OpenFoam. For example DamBreak deals with 4 phases in multiphaseInterFoam..
BlnPhoenix is offline   Reply With Quote
Old   January 25, 2018, 07:22
Lucie
Yes, I found these, that was my basis for my case.
Old   March 5, 2018, 01:53
chengan.wang
wangchengan2003 is on a distinguished road
Send a message via Skype™ to wangchengan2003
Dear Pei-Ying Hsieh,
I want to set a three-phase flow moving from left to right by using multiphaseInterfoam.
I try to use groovybc to set the boundary conditions as following:
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.air;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    atmosphere
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
/*    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    inlet
        type            groovyBC;
        valueExpression "(pos().y>0.6) ? 1 : 0";
        value           uniform 0;
        // type            zeroGradient;
    outlet
        type            zeroGradient;
    bottom
        type            zeroGradient;
    front
        type            empty;
    back
        type            empty;
    cylinder
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.oil;
boundaryField
    atmosphere
        type            inletOutlet;
        value           uniform 0;
    inlet
        type            groovyBC;
        valueExpression "(pos().y>0.3 && pos().y<=0.6) ? 1 : 0";
        value           uniform 0;
        //type            zeroGradient;
    outlet
        type            zeroGradient;
    bottom
        type            zeroGradient;
    front
        type            empty;
    back
        type            empty;
    cylinder
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.water;
boundaryField
    atmosphere
        type            inletOutlet;
        value           uniform 0;
    inlet
        type            groovyBC;
        valueExpression "(pos().y<=0.3) ? 1 : 0";
        value           uniform 0;
    outlet
        type            zeroGradient;
    bottom
        type            zeroGradient;
    front
        type            empty;
    back
        type            empty;
    cylinder
        type            zeroGradient;
Once I run the case, the error appeared:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&,  Foam::UList<double> const&, Foam::UList<double>  const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField,  Foam::volMesh> > Foam::operator/<Foam::fvPatchField,  Foam::volMesh>(Foam::tmp<Foam::GeometricField<double,  Foam::fvPatchField, Foam::volMesh> > const&,  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField,  Foam::volMesh> > const&) at ??:?
#5   Foam::multiphaseMixture::multiphaseMixture(Foam::GeometricField<Foam::Vector<double>,  Foam::fvPatchField, Foam::volMesh> const&,  Foam::GeometricField<double, Foam::fvsPatchField,  Foam::surfaceMesh> const&) at ??:?
#6  ? at ??:?
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8  ? at ??:?
Floating point exception (core dumped)
But if I use
type            zeroGradient;
instead of groovybc, the case can work.
Could you give some help?
Best regards,
Chengan
wangchengan2003 is offline   Reply With Quote
Old   March 5, 2018, 20:34
chengan.wang
Hello Lucie,
Have you solved your problem? how do you set boundary conditions for the three fluids?
Best regards,
Chengan
Pressure correction in two-phases flow Noel Phoenics 3 July 23, 2008 13:03
multicomponet flow vs.Homegeneous multiphase flow klarke Main CFD Forum 5 October 10, 2006 23:10
2 phases flow system in cylindrical pipe ivan FLUENT 3 February 25, 2006 12:52
two phases flow with reaction dingding CFX 6 September 17, 2001 09:46
HELP!!TWO PHASES FLOW dingding CFX 4 August 6, 2001 04:59
