New user and OpenFoam 15
Old   January 25, 2009, 23:59
Default Hi Stephen, I don't know
Michael Jaworski
mike_jaworski is on a distinguished road
Hi Stephen,
I don't know much about the netgen tool, however, I think I've used it, or something like it in the past. It sounds more like there are problems when you go to edit the boundary file either by typos or other alterations.
However, since I'm not an expert in this stuff, I'm going to make an alternate suggestion, of sorts. There's a nice CAD-like software called SALOME which can generate meshes for you and allows you to keep track of the patch names and the like. I believe it can import IGES files (and probably several other formats besides) which means you could continue to make your geometry in your favorite CAD program, mesh it with SALOME, run CFD on it with OpenFOAM, and do whatever else you want.
The CAELinux distro has some very good flash tutorials on how to use SALOME+OpenFOAM and this might give you an idea of how your own workflow could go. You can see the tutorials here.
Good luck!
Mike J.
mike_jaworski is offline   Reply With Quote
Old   January 26, 2009, 02:42
Default Hi Stephen, You write that
Gijsbert Wierink
gwierink is on a distinguished road
Hi Stephen,
You write that you have edited the patch names etc in the boundary file and the error message is
Expected a ')' or a '}' while reading PtrList, found on line 60 an error
file: /home/s/Desktop/cavity/constant/polyMesh/boundary at line 60.
Did you perhaps just accidentally delete or forgot to write a ')' or '}' where there should be one in the file /home/s/Desktop/cavity/constant/polyMesh/boundary at line 60 ?
Regards, Gijsbert
Regards, Gijs
gwierink is offline   Reply With Quote
Old   January 26, 2009, 04:20
Default here is the boundary file afte
Stephen
basilwatson is on a distinguished road
here is the boundary file after I edited it
Aslo I am used to salome , and have CAE but I cant locate the tutorial , ( if I remember it also used FOAMX )
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
7
patch1
type wall;
nFaces 5;
startFace 44;
patch2
type wall;
nFaces 5;
startFace 49;
patch3
type empty;
nFaces 11;
startFace 54;
patch4
type wall;
nFaces 6;
startFace 65;
patch5
type empty;
nFaces 11;
startFace 71;
patch6
type wall;
nFaces 6;
startFace 82;
King Regards Stephen
basilwatson is offline   Reply With Quote
Old   January 26, 2009, 04:41
Default Seems the tutorials are up and
Stephen
Seems the tutorials are up and running again ,,, they weren't last time I checked , sorry about that
Stephen
Old   January 26, 2009, 05:24
Default Hi Stephen, Aha, there it i
Gijsbert Wierink
Hi Stephen,
Aha, there it is! Your missing a ")" at the end of the file. The file should look like (note the added ")" in the end after the last "}" and before the // ***** ... **** //):
version 2.0;
format ascii;
object boundary;
7
patch1
type wall;
nFaces 5;
startFace 44;
patch2
type wall;
nFaces 5;
startFace 49;
patch3
type empty;
nFaces 11;
startFace 54;
patch4
type wall;
nFaces 6;
startFace 65;
patch5
type empty;
nFaces 11;
startFace 71;
patch6
type wall;
nFaces 6;
startFace 82;
Regards, Gijsbert
Regards, Gijs
New user and OpenFoam 15 basilwatson OpenFOAM Running, Solving & CFD 3 July 7, 2009 09:59
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 14:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 09:54
OpenFoam 12 Adding a user application class vvqf OpenFOAM Pre-Processing 3 October 27, 2005 14:18
User viscosity routine and user scalars? Jeff Siemens 3 January 6, 2003 06:26
