DynamicRefineFvMesh dies on snappyHexMesh generated grid
Old   January 29, 2009, 13:07
Default I am building a very much simp
Christian Trapp
chtrapp is on a distinguished road
I am building a very much simplified simulation of smoke coming out of a chimney. The case runs fine with interDyMFoam when using a staticFvMesh. Whenever I try to run it with a dynamicRefineFvMesh, the case aborts with the following message:
Starting time loop
Courant Number mean: 0.0877711 max: 0.504
deltaT = 0.25
Time = 0.75
Selected 0 cells for refinement out of 20000.
Only call if constructed with history capability#0 Foam::error::printStack(Foam:stream&) in "/usr/local/fgtools/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/usr/local/fgtools/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::hexRef8::getSplitPoints() const in "/usr/local/fgtools/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicMesh.so"
#3 Foam::dynamicRefineFvMesh::selectUnrefinePoints(do uble, Foam::PackedList<1> const&, Foam::Field<double> const&) const in "/usr/local/fgtools/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#4 Foam::dynamicRefineFvMesh::update() in "/usr/local/fgtools/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#5 main in "/usr/local/fgtools/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interDy MFoam"
#6 __libc_start_main in "/lib/tls/libc.so.6"
#7 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/usr/local/fgtools/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interDy MFoam"
From function hexRef8::getSplitPoints()
in file polyTopoChange/polyTopoChange/hexRef8.C at line 4666.
FOAM aborting
What am I doing wrong?
Greetings, christian
chtrapp is offline   Reply With Quote
DynamicRefineFvMesh dies on snappyHexMesh generated grid chtrapp OpenFOAM Running, Solving & CFD 10 October 4, 2012 07:30
How to import grid generated using ICEM/CFD Harry Siemens 2 April 17, 2006 01:01
Use of grid generated by GAMBIT ramp Main CFD Forum 5 July 8, 2005 14:24
StarWatch Daemon always dies! Jiaying Xu Siemens 14 December 9, 2002 22:52
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 Isaac Manohar Ch. FLUENT 1 June 2, 2000 05:58
