Z direction thickness control by using fluentMeshToFoam
Old   January 31, 2009, 14:51
Default Hi, all I'm using the fluen
wei wu
wei_wu is on a distinguished road
Hi, all
I'm using the fluentMeshToFoam to extrude the 2D fluent mesh into 3D foam mesh. The aspect ratio is way too high for the boundary layer cells. I think the high aspect ratio comes from the Z dimension because when I check the 2D mesh in the gambit they are fine, but when I used the checkMesh after it's converted into 3D it reported the high ratio problem. I'm using 0.0001m for the thickness of first the boundary layer cell , but the thickness in the Z direction is 1.442m, which is automatically generated after fluentMeshToFoam. My question is how can I control the Z direction dimension when I'm converting the 2D mesh to a 3D?
Thank you
wei_wu is offline   Reply With Quote
Z direction thickness control when using fluentMeshToFoam to extrude 2D mesh wei_wu OpenFOAM Running, Solving & CFD 2 February 1, 2009 05:15
[Commercial meshers] FluentMeshtoFoam error sukratu OpenFOAM Meshing & Mesh Conversion 4 March 7, 2008 23:54
thermal conductivity in plane &thickness direction sreenivas Siemens 1 February 21, 2008 06:27
[Commercial meshers] FluentMeshToFoam errorplease help me andycong OpenFOAM Meshing & Mesh Conversion 18 November 5, 2007 17:43
[Commercial meshers] FluentMeshToFoam no set written kian OpenFOAM Meshing & Mesh Conversion 2 May 25, 2007 13:04
