LiftDrag tool
Old   January 15, 2009, 01:45
Default hi heydlauff sir
  #41
NAVEEN.K.M
naveen is on a distinguished road
hi heydlauff sir
i am new to openfoam 1.4.1....could u please send me the procedure of solving naca 0012 airfoil and how to mention the different angle of attack...
naveen is offline   Reply With Quote
Old   January 15, 2009, 07:02
  #42
NAVEEN.K.M
hi heydlauff sir
Old   January 19, 2009, 02:21
Default hi heydlauff sir can
  #43
NAVEEN.K.M
hi heydlauff sir
can u tell me how to install liftDragtool in openfoam 1.4.1...
Old   February 2, 2009, 06:44
Default hi everybody can any one
  #44
NAVEEN.K.M
hi everybody
can any one tell me how and where to install liftDragtool in openfoam 1.4.1...
Old   February 2, 2009, 08:44
Default hey naveen, use openfoam 1.
  #45
Wolfgang Heydlauff
wolle1982 will become famous soon enough
hey naveen,
use openfoam 1.5 with its force-tool!!
the different angle of attack you will have to set in die /0/U file in oyur casefolder. there is the vector for "inlet" velocity (0 0 0). just change the x and y component to the wished value (must calculate from SIN or COS).
e.g. (1 1 0) for angle of 45deg and speed of sqrt(2) (=1.41 m/s).
wolle1982 is offline   Reply With Quote
Old   September 2, 2009, 18:56
John
nomad is on a distinguished road
Hi Emanuele,
Are you defining the airfoil surfaces as a single patch, and if so, how are you doing that? I'm having problems simulating flow at 5 degrees aoa. When I try to visualize the streams, there are very few streams visible and the Cl and Cd values don't make sense. What mesh generator are you using?
Would it be possible to post your case files so I can gain more insight into the solvers and variables you're setting?
Thanks.
nomad is offline   Reply With Quote
Question to liftDrag hoochie OpenFOAM Post-Processing 29 September 19, 2014 04:38
LiftDrag for 141 ryan_m OpenFOAM Running, Solving & CFD 2 August 24, 2009 22:26
Liftdrag calculation marco OpenFOAM Post-Processing 10 March 6, 2009 10:51
LiftDrag coefficient in LES fabian_korn OpenFOAM Post-Processing 1 September 22, 2008 03:34
LiftDrag utility not available guggi OpenFOAM Running, Solving & CFD 1 August 2, 2006 13:36
