December 13, 2007, 05:36 |
Hello Alessandro,
I experim
#21 | |||
Rosario Russo
Rep Power: 17 |
Hello Alessandro,
Ciao. Rosario. |
December 14, 2007, 07:23 |
Alessandro,
I obtain good r
#22 |
Emanuele
Rep Power: 17 |
Alessandro,
I obtain good results using turbFoam with the SpalartAllmaras model. kEpsilon or kOmegaSST return floating point error...perhaps i have bad boundary conditions on k, epsilon and omega. Now i'm working on a 3d case with turbFoam and Spalart Allmaras model....i'll say you my results i hope good results... Emanuele |
December 17, 2007, 13:03 |
Hi, can i use the tool patchIn
#23 |
Emanuele
Rep Power: 17 |
Hi, can i use the tool patchIntegrate of pressure field on airfoil to compute lift coefficients ??
April 21, 2008, 14:06 |
Hi everybody,
I'm a new use
#24 |
Leonardo Nettis
Rep Power: 17 |
Hi everybody,
I'm a new user of openfoam and I'm trying to analyse a naca profile with potentialfoam. Although I'm quite sure concerning the boundary conditions these are the results that I get on a C-grid: As you can see in the previous image it is strange that the velocity around the wing (and in the whole domain) is equal to 0, whilst it should be 239.6 m/s according to the boundary condition! Moreover there is only a little flow perturbation on the trailing edge, but the velovity increase very much inside that!! The boundary conditions are the following: -domain contour: freestream (U=239.6 m/s p=26624 Pa) -lateral side:empty (2D analysis) - wing: wall and this is the 0/U file: dimensions [0 1 -1 0 0 0 0]; internalField uniform (239.6 0 0); boundaryField { defaultFaces { type empty; } lateral_side1 { type empty; } lateral_side2 { type empty; } outlet { type inletOutlet; inletValue uniform (239.6 0 0); value uniform (239.6 0 0); } wing { type fixedValue; value uniform (0 0 0); } freestream { type inletOutlet; inletValue uniform (239.6 0 0); value uniform (239.6 0 0); } } I hope somebody can help me. Thank you very much dino |
April 21, 2008, 14:07 |
this is another view of the wh
#25 |
Leonardo Nettis
Rep Power: 17 |
this is another view of the whole domain (C-grid) in terms of streamlines, quite strange as well:
dino |
April 28, 2008, 05:44 |
Hi everyone, I've got a proble
#26 |
Samuel Pang
Rep Power: 17 |
Hi everyone, I've got a problem that pertains to the liftdrag tool to a NACA 2410 airfoil too. I am running a case of icoFoam for a company because they just want to see if the liftdrag coefficients are more or less accurate with collected data.
I am still fairly new to OpenFOAM so I have no idea how to use blockMesh to create the profile of the airfoie. At the moment I've used SALOME to draw the geometry and then exported the mesh over to OpenFOAM. The problem I'm facing is that I can't seem to get the Courant number to stay at a low level. I've tried reducing the timestep to a pico-second, but it still gives errors. It could be because of meshing errors that caused it to be as such. Besides that, the lift and drag coefficients kept rising until they were beyond the millions. Can someone help me troubleshoot this? Or if possible, is there anyone with a NACA mesh that I can use already? |
May 15, 2008, 09:28 |
I have similar problems.
I wa
#27 |
I want to obtain a k-omega calculation on a NACA0012 profile at 0° AoA. It's blockmesh capable to produce this mesh, or it's necessary to make it with another mesh package (like prostar or something...)? |
May 17, 2008, 05:35 |
Hi Ivan
Yes I use blockMesh
#28 |
Simone.Sa
Rep Power: 17 |
Hi Ivan
Yes I use blockMesh to create an airfoil's computtional domain (I use a NACA 4421). This is my blockMeshDict file: convertToMeters 1; vertices ( ( 0 0 -0.5) // vertex 0 ( 1 0 -0.5) // vertex 1 ( 21 0 -0.5) // vertex 2 (-12.5 0 -0.5) // vertex 3 ( 0 12.5 -0.5) // vertex 4 ( 1 12.5 -0.5) // vertex 5 ( 21 12.5 -0.5) // vertex 6 ( 0 -12.5 -0.5) // vertex 7 ( 1 -12.5 -0.5) // vertex 8 ( 21 -12.5 -0.5) // vertex 9 ( 0.5 0.0534 -0.5) // vertex 10 ( 0.5 -0.1318 -0.5) // vertex 11 ( 0.5 12.5 -0.5) // vertex 12 ( 0.5 -12.5 -0.5) // vertex 13 (-12.5 12.5 -0.5) // vertex 14 (-12.5 -12.5 -0.5) // vertex 15 ( 0 0 0.5) // vertex 16 ( 1 0 0.5) // vertex 17 ( 21 0 0.5) // vertex 18 (-12.5 0 0.5) // vertex 19 ( 0 12.5 0.5) // vertex 20 ( 1 12.5 0.5) // vertex 21 ( 21 12.5 0.5) // vertex 22 ( 0 -12.5 0.5) // vertex 23 ( 1 -12.5 0.5) // vertex 24 ( 21 -12.5 0.5) // vertex 25 ( 0.5 0.0534 0.5) // vertex 26 ( 0.5 -0.1318 0.5) // vertex 27 ( 0.5 12.5 0.5) // vertex 28 ( 0.5 -12.5 0.5) // vertex 29 (-12.5 12.5 0.5) // vertex 30 (-12.5 -12.5 0.5) // vertex 31 ); blocks ( hex ( 0 10 12 4 16 26 28 20) (10 40 1) simpleGrading (0.15 40 1) // block 1 hex (10 1 5 12 26 17 21 28) (10 40 1) simpleGrading ( 3.5 40 1) // block 2 hex ( 1 2 6 5 17 18 22 21) (40 40 1) simpleGrading ( 10 40 1) // block 3 hex ( 8 9 2 1 24 25 18 17) (40 250 1) simpleGrading (10 1 1) // block 4 hex (13 8 1 11 29 24 17 27) (10 250 1) simpleGrading (0.5 1 1) // block 5 hex ( 7 13 11 0 23 29 27 16) (10 250 1) simpleGrading (0.3 1 1) // block 6 hex (15 7 0 3 31 23 16 19) (40 250 1) simpleGrading (0.05 1 1) // block 7 hex ( 3 0 4 14 19 16 20 30) (40 40 1) simpleGrading (0.05 40 1) // block 8 ); edges ( simpleSpline 0 10 ( (0.0125 0.0242 -0.5) (0.0250 0.0348 -0.5) (0.0500 0.0478 -0.5) (0.0750 0.0562 -0.5) (0.1000 0.0615 -0.5) (0.1500 0.0675 -0.5) (0.2000 0.0698 -0.5) (0.2500 0.0692 -0.5) (0.3000 0.0676 -0.5) (0.4000 0.0616 -0.5) ) simpleSpline 10 1 ( (0.6000 0.0440 -0.5) (0.7000 0.0335 -0.5) (0.8000 0.0231 -0.5) (0.9000 0.0127 -0.5) (0.9500 0.0074 -0.5) ) simpleSpline 16 26 ( (0.0125 0.0242 0.5) (0.0250 0.0348 0.5) (0.0500 0.0478 0.5) (0.0750 0.0562 0.5) (0.1000 0.0615 0.5) (0.1500 0.0675 0.5) (0.2000 0.0698 0.5) (0.2500 0.0692 0.5) (0.3000 0.0676 0.5) (0.4000 0.0616 0.5) ) simpleSpline 26 17 ( (0.6000 0.0440 0.5) (0.7000 0.0335 0.5) (0.8000 0.0231 0.5) (0.9000 0.0127 0.5) (0.9500 0.0074 0.5) ) simpleSpline 1 11 ( (0.9500 -0.0211 -0.5) (0.9000 -0.0385 -0.5) (0.8000 -0.0691 -0.5) (0.7000 -0.0950 -0.5) (0.6000 -0.1160 -0.5) ) simpleSpline 11 0 ( (0.4000 -0.1416 -0.5) (0.3000 -0.1427 -0.5) (0.2500 -0.1388 -0.5) (0.2000 -0.1317 -0.5) (0.1500 -0.1204 -0.5) (0.1000 -0.1035 -0.5) (0.0750 -0.0924 -0.5) (0.0500 -0.0782 -0.5) (0.0250 -0.0584 -0.5) (0.0125 -0.0445 -0.5) ) simpleSpline 17 27 ( (0.9500 -0.0211 0.5) (0.9000 -0.0385 0.5) (0.8000 -0.0691 0.5) (0.7000 -0.0950 0.5) (0.6000 -0.1160 0.5) ) simpleSpline 27 16 ( (0.4000 -0.1416 0.5) (0.3000 -0.1427 0.5) (0.2500 -0.1388 0.5) (0.2000 -0.1317 0.5) (0.1500 -0.1204 0.5) (0.1000 -0.1035 0.5) (0.0750 -0.0924 0.5) (0.0500 -0.0782 0.5) (0.0250 -0.0584 0.5) (0.0125 -0.0445 0.5) ) ); patches ( wall airfoil ( (0 16 26 10) (10 26 17 1) (11 1 17 27) (0 11 27 16) ) patch inlet ( ( 14 30 19 3 ) ( 3 19 31 15) ) patch outlet ( ( 22 6 2 18) ( 18 2 9 25) ) patch up ( ( 14 4 20 30 ) ( 4 12 28 20) ( 12 5 21 28) ( 5 6 22 21) ) patch down ( (15 31 23 7) (7 23 29 13) (13 29 24 8) (8 24 25 9) ) empty frontAndBack ( (3 14 4 0 ) (0 4 12 10) (10 12 5 1 ) (1 5 6 2 ) (15 3 0 7 ) (7 0 11 13) (13 11 1 8 ) (8 1 2 9 ) (19 16 20 30) (16 26 28 20 ) (26 17 21 28 ) (17 18 22 21) (31 23 16 19) (23 29 27 16) (29 24 17 27) (24 25 18 17) ) ); mergePatchPairs ( ); Now you can simply change the airfoil interpolation points, in the edges definition. I get the points at this site: http://www.ae.uiuc.edu/m-selig/ads/c...atabase.html#N There are a lot of airfoil coordinater, Naca 0012 too. Ok? S. |
May 17, 2008, 05:51 |
In my case I want to evaluate
#29 |
Simone.Sa
Rep Power: 17 |
In my case I want to evaluate the ground effect but I think that in your case you have to substitute, to get a finest mesh, the block definition that I have post up with this:
hex ( 0 10 12 4 16 26 28 20) (10 40 1) simpleGrading (0.15 40 1) // block 1 hex (10 1 5 12 26 17 21 28) (10 40 1) simpleGrading ( 3.5 40 1) // block 2 hex ( 1 2 6 5 17 18 22 21) (40 40 1) simpleGrading ( 10 40 1) // block 3 hex ( 8 9 2 1 24 25 18 17) (40 40 1) simpleGrading (10 0.025 1) // block 4 hex (13 8 1 11 29 24 17 27) (10 40 1) simpleGrading (0.5 0.025 1) // block 5 hex ( 7 13 11 0 23 29 27 16) (10 40 1) simpleGrading (0.3 0.025 1) // block 6 hex (15 7 0 3 31 23 16 19) (40 40 1) simpleGrading (0.05 0.025 1) // block 7 hex ( 3 0 4 14 19 16 20 30) (40 40 1) simpleGrading (0.05 40 1) // block 8 OK? S. |
May 21, 2008, 02:43 |
Hi Simone
I'm still getting
#30 |
Samuel Pang
Rep Power: 17 |
Hi Simone
I'm still getting some problems with the meshing, especially the neighbour cells. I've got a copy of the error message, maybe you'd like to take a look at it. ----------------------------------------------- Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 134 zero or negative pyramid volume: -6.51042 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 134 zero or negative pyramid volume: -13.0208 for face 5 Default patch type set to empty --> FOAM FATAL ERROR : face 0 in patch 0 does not have neighbour cell face: 4(0 16 26 10)#0 Foam::error::printStack(Foam:stream&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face> > const&, int) const in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh " #5 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh " #6 main in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh " #7 __libc_start_main in "/lib/i686/libc.so.6" #8 Foam::regIOobject::readIfModified() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh " From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127. FOAM aborting |
May 21, 2008, 05:47 |
Hi Samuel.
Are you using th
#31 |
Simone.Sa
Rep Power: 17 |
Hi Samuel.
Are you using the blockMesh file that I have posted up? Can you post your blockMeshDict file? S. |
May 21, 2008, 07:37 |
Hi Simone,
Yes, I used the
#32 |
Samuel Pang
Rep Power: 17 |
Hi Simone,
Yes, I used the blockMesh file that you uploaded. The thing is that this is an error that I've been having all the time, the problem with the cells. I'm not sure whether it's the problem with the OF script because your blockMesh seems to be correct. Samuel |
May 21, 2008, 08:06 |
Have you changed something in
#33 |
Simone.Sa
Rep Power: 17 |
Have you changed something in the blockMeshDict file that I have upload?
When the error happens? When you try to run the solver? Have you checked the mesh with checkMesh utility before running the solver? Try to use checkMesh . <namecase>, if an error occurred, post me what they says and the blockMeshDict file... S. |
December 31, 2008, 03:02 |
Hi Ivan
Yes I use blockMesh
#34 |
NAVEEN.K.M
Rep Power: 17 |
Hi Ivan
Yes I use blockMesh to create an airfoil's computtional domain (I use a NACA 4421). This is my blockMeshDict file: convertToMeters 1; vertices ( ( 0 0 -0.5) // vertex 0 ( 1 0 -0.5) // vertex 1 ( 21 0 -0.5) // vertex 2 (-12.5 0 -0.5) // vertex 3 ( 0 12.5 -0.5) // vertex 4 ( 1 12.5 -0.5) // vertex 5 ( 21 12.5 -0.5) // vertex 6 ( 0 -12.5 -0.5) // vertex 7 ( 1 -12.5 -0.5) // vertex 8 ( 21 -12.5 -0.5) // vertex 9 ( 0.5 0.0534 -0.5) // vertex 10 ( 0.5 -0.1318 -0.5) // vertex 11 ( 0.5 12.5 -0.5) // vertex 12 ( 0.5 -12.5 -0.5) // vertex 13 (-12.5 12.5 -0.5) // vertex 14 (-12.5 -12.5 -0.5) // vertex 15 ( 0 0 0.5) // vertex 16 ( 1 0 0.5) // vertex 17 ( 21 0 0.5) // vertex 18 (-12.5 0 0.5) // vertex 19 ( 0 12.5 0.5) // vertex 20 ( 1 12.5 0.5) // vertex 21 ( 21 12.5 0.5) // vertex 22 ( 0 -12.5 0.5) // vertex 23 ( 1 -12.5 0.5) // vertex 24 ( 21 -12.5 0.5) // vertex 25 ( 0.5 0.0534 0.5) // vertex 26 ( 0.5 -0.1318 0.5) // vertex 27 ( 0.5 12.5 0.5) // vertex 28 ( 0.5 -12.5 0.5) // vertex 29 (-12.5 12.5 0.5) // vertex 30 (-12.5 -12.5 0.5) // vertex 31 ); blocks ( hex ( 0 10 12 4 16 26 28 20) (10 40 1) simpleGrading (0.15 40 1) // block 1 hex (10 1 5 12 26 17 21 28) (10 40 1) simpleGrading ( 3.5 40 1) // block 2 hex ( 1 2 6 5 17 18 22 21) (40 40 1) simpleGrading ( 10 40 1) // block 3 hex ( 8 9 2 1 24 25 18 17) (40 250 1) simpleGrading (10 1 1) // block 4 hex (13 8 1 11 29 24 17 27) (10 250 1) simpleGrading (0.5 1 1) // block 5 hex ( 7 13 11 0 23 29 27 16) (10 250 1) simpleGrading (0.3 1 1) // block 6 hex (15 7 0 3 31 23 16 19) (40 250 1) simpleGrading (0.05 1 1) // block 7 hex ( 3 0 4 14 19 16 20 30) (40 40 1) simpleGrading (0.05 40 1) // block 8 ); edges ( simpleSpline 0 10 ( (0.0125 0.0242 -0.5) (0.0250 0.0348 -0.5) (0.0500 0.0478 -0.5) (0.0750 0.0562 -0.5) (0.1000 0.0615 -0.5) (0.1500 0.0675 -0.5) (0.2000 0.0698 -0.5) (0.2500 0.0692 -0.5) (0.3000 0.0676 -0.5) (0.4000 0.0616 -0.5) ) simpleSpline 10 1 ( (0.6000 0.0440 -0.5) (0.7000 0.0335 -0.5) (0.8000 0.0231 -0.5) (0.9000 0.0127 -0.5) (0.9500 0.0074 -0.5) ) simpleSpline 16 26 ( (0.0125 0.0242 0.5) (0.0250 0.0348 0.5) (0.0500 0.0478 0.5) (0.0750 0.0562 0.5) (0.1000 0.0615 0.5) (0.1500 0.0675 0.5) (0.2000 0.0698 0.5) (0.2500 0.0692 0.5) (0.3000 0.0676 0.5) (0.4000 0.0616 0.5) ) simpleSpline 26 17 ( (0.6000 0.0440 0.5) (0.7000 0.0335 0.5) (0.8000 0.0231 0.5) (0.9000 0.0127 0.5) (0.9500 0.0074 0.5) ) simpleSpline 1 11 ( (0.9500 -0.0211 -0.5) (0.9000 -0.0385 -0.5) (0.8000 -0.0691 -0.5) (0.7000 -0.0950 -0.5) (0.6000 -0.1160 -0.5) ) simpleSpline 11 0 ( (0.4000 -0.1416 -0.5) (0.3000 -0.1427 -0.5) (0.2500 -0.1388 -0.5) (0.2000 -0.1317 -0.5) (0.1500 -0.1204 -0.5) (0.1000 -0.1035 -0.5) (0.0750 -0.0924 -0.5) (0.0500 -0.0782 -0.5) (0.0250 -0.0584 -0.5) (0.0125 -0.0445 -0.5) ) simpleSpline 17 27 ( (0.9500 -0.0211 0.5) (0.9000 -0.0385 0.5) (0.8000 -0.0691 0.5) (0.7000 -0.0950 0.5) (0.6000 -0.1160 0.5) ) simpleSpline 27 16 ( (0.4000 -0.1416 0.5) (0.3000 -0.1427 0.5) (0.2500 -0.1388 0.5) (0.2000 -0.1317 0.5) (0.1500 -0.1204 0.5) (0.1000 -0.1035 0.5) (0.0750 -0.0924 0.5) (0.0500 -0.0782 0.5) (0.0250 -0.0584 0.5) (0.0125 -0.0445 0.5) ) ); patches ( wall airfoil ( (0 16 26 10) (10 26 17 1) (11 1 17 27) (0 11 27 16) ) patch inlet ( ( 14 30 19 3 ) ( 3 19 31 15) ) patch outlet ( ( 22 6 2 18) ( 18 2 9 25) ) patch up ( ( 14 4 20 30 ) ( 4 12 28 20) ( 12 5 21 28) ( 5 6 22 21) ) patch down ( (15 31 23 7) (7 23 29 13) (13 29 24 8) (8 24 25 9) ) empty frontAndBack ( (3 14 4 0 ) (0 4 12 10) (10 12 5 1 ) (1 5 6 2 ) (15 3 0 7 ) (7 0 11 13) (13 11 1 8 ) (8 1 2 9 ) (19 16 20 30) (16 26 28 20 ) (26 17 21 28 ) (17 18 22 21) (31 23 16 19) (23 29 27 16) (29 24 17 27) (24 25 18 17) ) ); mergePatchPairs ( ); i am not able to solve above airfoil case ie 4421 airfoil...could u please help me regarding this problem... |
December 31, 2008, 03:41 |
Hi Samuel.
Can you post y
#35 |
NAVEEN.K.M
Rep Power: 17 |
Hi Samuel.
Can you post your blockMeshDict file for naca 0012 airfoil.... |
December 31, 2008, 03:45 |
hi
Emanuele Tartaglia
Can
#36 |
VENKATESH
Rep Power: 17 |
hi
Emanuele Tartaglia Can you post your blockMeshDict file for naca 0012 airfoil.. |
December 31, 2008, 04:25 |
Hi m.janssens Sir,
This
#37 |
VENKATESH
Rep Power: 17 |
Hi m.janssens Sir,
This is Venkatesh .I need NACA0012 coordinates can u please send the coordinates. |
December 31, 2008, 04:29 |
Hi Alessandro Spadoni sir,
#38 |
VENKATESH
Rep Power: 17 |
Happy New year I Wnt NACA0012 Aerofoil coordinates could please send me the coordinates |
January 7, 2009, 11:09 |
as I understand, there is (sti
#39 |
Wolfgang Heydlauff
Rep Power: 21 |
as I understand, there is (still) a bug in the simpleSpline option. better use "polyLine"! for this you will have to insert more coordinates. best: use X-Foil to create it. alternatively use any CAD system to spline your profile and export more vertices.
January 7, 2009, 11:17 |
And here is a little hint for
#40 |
Wolfgang Heydlauff
Rep Power: 21 |
And here is a little hint for 2D airfoil blockMeshing:
for vertices in the "front-plane" use even numbers (0,2,4...) an in the "back-plane" uneven numbers (1,3,5...). so the corresponding vertices in the verticeslist are always together like (20 20 0)//0 (20 20 1)//1 (15 15 0)//2 (15 15 1)//3 and a block definition then looks like (0 2 4 6 1 3 5 7) also the patch definition for front or back only contains even or uneven numbers .....makes it much easier to find mistakes afterwards. |
Question to liftDrag | hoochie | OpenFOAM Post-Processing | 29 | September 19, 2014 04:38 |
LiftDrag for 141 | ryan_m | OpenFOAM Running, Solving & CFD | 2 | August 24, 2009 22:26 |
Liftdrag calculation | marco | OpenFOAM Post-Processing | 10 | March 6, 2009 10:51 |
LiftDrag coefficient in LES | fabian_korn | OpenFOAM Post-Processing | 1 | September 22, 2008 03:34 |
LiftDrag utility not available | guggi | OpenFOAM Running, Solving & CFD | 1 | August 2, 2006 13:36 |
