April 26, 2005, 10:17 |
Dear OpenFOAM experts,
Can
Pei-Ying Hsieh
Rep Power: 18 |
Can anyone here explain the differences between coodles and sonicTurbFoam? Is there such thing as "steady state compressible (Mach .5 - 0.9) turbulent flow"? Thanks! Pei |
April 26, 2005, 10:25 |
sonicTurbFoam:
Transient RANS
Eugene de Villiers
Rep Power: 21 |
sonicTurbFoam:
Transient RANS solver for trans-sonic/supersonic, turbulent flow of a compressible gas. coodles: LES solver for sub/trans-sonic turbulent flow of a compressible gas. |
April 26, 2005, 11:13 |
Thanks Eugene!
When using o
Pei-Ying Hsieh
Rep Power: 18 |
Thanks Eugene!
When using oneEqEddy in LES, k is needed in /0/k. How is this k calculated for the inlet? Pei |
April 26, 2005, 11:18 |
What kind of inlet are we talk
Eugene de Villiers
Rep Power: 21 |
What kind of inlet are we talking about, i.e. fully/partially developed, laminar or slugflow?
April 26, 2005, 11:51 |
Hi, Eugene,
Last time I did
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Eugene,
Last time I did turbulence was 15 years ago. So, I am learning. Inlet will be fully developed turbulent. Is it LES generally more computational expensive than RANS? Especially, I have a complex geometry, so, may be I should stick to RANS kEpsilon model (I do not really want to resolve small flow structures)? Can you advise which solver will be appropriate for sub-sonic/transonic with kEpsilon model? Thanks again for your help! Pei |
April 26, 2005, 12:02 |
Ho! You definitely dont want t
Eugene de Villiers
Rep Power: 21 |
Ho! You definitely dont want to be doing LES unless you have to. It is VERY expensive.
Try rhoTurbFoam for a compressible RANS solver, although I dont know how it will cope with trans-sonic flows. There is also sonicTurbFoam, but again this is not my area of expertise. Maybe someone who is more knowledgeable than me can give you some pointers on what the different RANS compressible codes do? |
April 26, 2005, 14:14 |
Rep Power: 22 |
rhoSimpleFoam |
April 26, 2005, 17:16 |
Thanks Henry!
What rhoTurbF
Pei-Ying Hsieh
Rep Power: 18 |
Thanks Henry!
What rhoTurbFoam is for? Is it suitable for mach .5? Pei |
April 26, 2005, 18:02 |
rhoTurbFoam is for transient c
#9 |
Rep Power: 22 |
rhoTurbFoam is for transient compressible low-Ma laminar and turbulent flow and rhoSimpleFoam is for steady-state compressible low-Ma laminar and turbulent flow.
February 3, 2009, 07:13 |
Hi fomers,
I am running a
#10 |
Vishal Jambhekar
Rep Power: 17 |
Hi fomers,
I am running a case with sonicTurbFoam with 3 mach velocity at inlet. whare as inlet static temprature is 110 K and pressure is 0.15 bar. I want to mainly capture the shock boundry layer interaction at inlet for air breathing engine. Can you please tell me what outlet conditions should i apply. any other openions regarding any tool to plot static pressure along surface is also welcome. Plase help me in this issue. Thanks
Cheers, Vishal Jambhekar... "Simulate the way ahead......!!!" |
February 3, 2009, 07:17 |
One more thing is curre
#11 |
Vishal Jambhekar
Rep Power: 17 |
One more thing is currently i am using RNG K-Epsilon method. WHich scheme is best suite for capturing physics. Thanks ij advance. VIshal.
Coodles | anja | OpenFOAM Pre-Processing | 33 | January 14, 2010 10:05 |
Pressure waves bouncing around while using coodles | ankgupta8um | OpenFOAM Running, Solving & CFD | 4 | March 5, 2008 07:54 |
Pow in lib64tlslibmso6 SigFpe when running coodles with SpalartAllmaras | lillberg | OpenFOAM Bugs | 4 | December 7, 2007 09:17 |
Question about coodles | tangd | OpenFOAM Running, Solving & CFD | 0 | June 20, 2006 04:58 |
Startingsetting coodles on an academic case | melanie | OpenFOAM Running, Solving & CFD | 5 | March 30, 2006 05:00 |
