Problems with 3 degrees of rotation
Old   June 17, 2007, 09:37
Default This is a good news! However,
  #21
Francesco Del Citto
fra76 is on a distinguished road
However, I would like to implement something like "dynamicBodyFvMesh" with the new algorithm in OF 1.4...
fra76 is offline   Reply With Quote
Old   June 19, 2007, 06:23
Default Hi all! In the OF 1.4 release
  #22
Francesco Del Citto
Hi all!
In the OF 1.4 release notes, regarding mesh motion, I've found: "Flexible and efficient finite volume based mesh motion solvers (replacing the finite element mesh motion solvers)."
In another post inside this forum (http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/4218) Hrvoje wrote "the cell-based diffusion equation which "replaces it" is so pathetically useless that I have abandoned it more than 10 years ago"
Can someone please explain me why the cell based method is so worse than the finite element one? Some article about both methods would help me a lot, too!
In one of my test cases, OF 1.3 fails, while the new method works better, and much faster, even if it slightly changes a fixed boundary. (Hrvoje, I think I could send you the pictures, if you're interested)
Bye
Francesco
Old   June 19, 2007, 06:46
Default Just put the pictures here. I
  #23
Frank Bos
lr103476 is on a distinguished road
Just put the pictures here. I am also interested in the new car:-)
When Hrvoje manages to put all three (finite volume, cell decomp, cellFace decomp) into one 1.4 development release, I will make a comparison using a 3D moving body, looking at accuracy and efficiency.
Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   February 3, 2009, 13:10
Default Hi Frank and others, Can yo
  #24
sek
Sung-Eun Kim
sek is on a distinguished road
Can you please tell me how I can specify a dynamic pitching motion of an airfoil with 1.5? I see lots of discussion here but it's not clear whether I can do it without writing any code or not. -Thanks,
sek is offline   Reply With Quote
Old   February 3, 2009, 14:55
Default Hi Sung-Eun Kim! Do you wan
  #25
Frank Bos
Hi Sung-Eun Kim!
Do you want to describe the complete plunging pitching motion of the airfoil, or is there any fluid-structure interaction involved?
Regards, Frank
Frank Bos
Old   February 3, 2009, 15:23
Default Hi Frank, Thanks a lot for
  #26
sek
Sung-Eun Kim
Hi Frank,
Thanks a lot for your reply.
for now I have forced oscillation (prescribed motion) in mind. After posting the question, I somehow figured out from examples I could prescribe a translational and a rotational motion on the airfoil (both are periodic) using the dynamicBodyFvMesh class as shown below.
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
solverLib "libdynamicFvMesh.so";
dynamicFvMesh dynamicBodyFvMesh;
dynamicBodyFvMeshCoeffs
bodyPatchName movingWall;
translationDirection (0 1 0);
translationAmplitude 0;
translationFrequency 1;
initialRotationOrigin (0 0 0);
rotationAxis (0 0 1);
rotationAmplitude 0.349;
rotationFrequency 10;
twoDMotion yes;
solver laplaceFaceDecomposition;
diffusivity quadratic;
frozenDiffusion on;
distancePatches
movingWall
And in "U" file, I set the type as "movingWallVelocity". That's all I did. The solution seems what you would expect from a dynamically pitching airfoil. Did I miss something?
Thanks,
Sung-Eun
Old   February 3, 2009, 15:36
Default Hi Sun-Eun, This is exactly
  #27
Frank Bos
Hi Sun-Eun,
This is exactly what I do for a complex flapping wing. In a dynamicFvMesh based class you can do whatever you like with the boundary points, so translation, rotation and/or flexing. DynamicBodyFvMesh is a class with only translation and rotating in one direction (if I am not mistaken), but you can easily extend that. Be aware that for large rotations the standard laplacian motion solver may not be good enough. In that case try the SBRStress motion solver, a small rewrite of your dynamicFvMesh class may be necessary......
Soon, we will put our Radial Basis Function motion solver in the SVN-dev repository.....
Enjoy the moving meshes!
Frank
Frank Bos
Old   April 6, 2014, 05:07
Post flapping wing FSI
  #28
Arash Mahboubidoust
arashfluid is on a distinguished road
Send a message via Yahoo to arashfluid
Hi Frank and friends
I want to use icoFsiFoam in OF-1.6-ext to solve pitching and plunging motion of 3D wing problem. without FSI mode, I've applied those motions using two methods in dynamic MeshDict:1)solidBodyMotionFvMesh,2)dynamicMotionSo lverFvMesh with displacement Laplacian solver using pointDisplacement. But these methods and RBFmotion are based on finite volume,whereas icoFsi mesh motion is based on finite element.That's why I converet this solver to finite volume solver.The problem is that after running the solver,wingsolid and wingfluid,each of them moves separately and do not affect each other.
would you please tell me how I could do it with the previous finite element solver?Like the flapping console test case, with knowing the difference between these two cases, that here the plunging motion should also be applied to solid.
arashfluid is offline   Reply With Quote
Old   September 25, 2014, 12:56
Default how to implement prescribed 3D translation and rotations in OpenFOAM 2.3?
  #29
maryam f
maryfery is on a distinguished road
it is used to be possible to do it in OF 1.6 via dynamicBodyFvMotion class but this class does not exist in 2.3 version.
also I tried to use SBRStress but i don't know how to implement the prescribed motion.
I need a function like tabulated6DoFMotionCoeffs which reads the translations and rotations from a .dat file for example.
thanks for your response in advance.
cheers;
maryam
maryfery is offline   Reply With Quote
Old   May 18, 2016, 04:00
Default dynamicMeshDict
  #30
le
fsifsi is on a distinguished road
Hello Francesco Del Citto
Could you post your dynamicMeshDict again, please.
I get error "Selected mesh motion solver is RBFMotionSolver, instead tetMotionSolver"
when i use dynamicBodyFvMesh in OF3.1.ext
Many thanks
Originally Posted by fra76 View Post
Thanks Frank!
My mistake was using "moveMesh" instead of "moveDynamicMesh".
I can rotate the cube, at last, and I know what I have to modify in order to add mya own motion laws.
I'll play a bit with this, and I'll let you know if I'll be able to move a subset within another one.
Ciao
Francesco
fsifsi is offline   Reply With Quote
3D duct bending at 90 degrees Kabo Main CFD Forum 1 October 11, 2007 05:37
Degrees of freedom NGUYEN Viet Hung FLUENT 0 July 9, 2006 20:59
1, 2 or 3 degrees of problem using 6 dof feature Manoj Kumar FLUENT 0 November 2, 2005 02:20
about the Degrees of Freedom! KEVIN FLUENT 0 March 23, 2004 09:13
180 degrees bend flow Tim Franke Main CFD Forum 0 February 1, 2000 08:28
