Solving NACA AIRFOIL
Old   February 6, 2009, 07:01
Default HI EVERYBODY I am facing
NAVEEN.K.M
naveen is on a distinguished road
HI EVERYBODY
I am facing difficult to solve NACA 0012 airfoil case which is imported from fluent...can u please send me the procedure of solving this case in openFoam 1.4.1..
naveen is offline   Reply With Quote
Old   February 6, 2009, 07:43
Default Naveen, You keep posting th
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Naveen,
You keep posting the same question over and over again besides the fact that you have been given an entire test setup.
The test case can be found at
http://powerlab.fsb.hr/ped/kturbo/Op...P/naca0012.tgz and if you are having problems running it, it is because you haven't tried the tutorials.
You have by far exceeded the tolerance limit of this forum, and I suggest that you consider your general havaviour.
The present behaviour just clutter the forum, and makes it nearly impossible for serious users to find relevant information on the naca-profiles. All they find are unanswered threads composted by you.
/Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
[Commercial meshers] Naca 0012 airfoil naveen OpenFOAM Meshing & Mesh Conversion 7 April 14, 2011 12:03
Solving naca 0012 airfoil naveen OpenFOAM Pre-Processing 3 February 17, 2009 10:25
Problem solving NACA airfoil mathieu OpenFOAM Running, Solving & CFD 4 November 16, 2008 14:05
Naca Airfoil Dario Main CFD Forum 5 July 13, 2007 20:23
NACA Airfoil Coordinate Suryakant Nagdewe Main CFD Forum 0 December 16, 2003 14:29
