Solver for a ventilation problem
Old   December 25, 2008, 09:15
Default Hi all! I am trying to build
cruiser
vizag is on a distinguished road
Hi all!
I am trying to build a solver for simulating the flow inside closed room.
i guess, i have to use an incompressible flow solver,with turbulence enabled.(steady or unsteady).
Somebody, please suggest me a solver on which i can build my problem specific solver.
cheers!!
vizag is offline   Reply With Quote
Old   December 25, 2008, 11:09
Default Hi Cruiser, If your problem
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
Hi Cruiser,
If your problem is isothermal, then simpleFoam is what you need.
Regards,
Paulo Rocha
paulo is offline   Reply With Quote
Old   December 25, 2008, 11:31
Default Hi, you also can use bouyan
tian's Avatar
Tian
tian is on a distinguished road
you also can use bouyantSimpleFoam or with radiation: bouyantSimpleRadiationFoam.
I got many good experience with both solvers.
Bye
Tian
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance.
tian is offline   Reply With Quote
Old   December 25, 2008, 11:38
Default Hi! Thanks for the replies!
cruiser
Hi!
surely, my problem is isothermal.
but i am afraid, the compressible solver may take longer to converge,if i use buoyantSimpleFoam.
there is no radiation either in the problem.
should i build a solver from turbFoam?
Old   February 6, 2009, 12:34
Default Hello Cruiser Looking at wh
Rishi .
hellorishi is on a distinguished road
Hello Cruiser
Looking at what the buoyantSimpleFoam tutorials, it seems like a good solver for your case. If you run the tutorial hotRoom or hotBox, it will converge in short time (few minutes on standard workstation/PC).
If you have already managed to run the simulation, I would like to know the paramters you used. I am having trouble running a similar ventilation case. Its not converging. Kindly help if you can.
:Rishi
hellorishi is offline   Reply With Quote
Boundary condition for ventilation problem D.Prakash FLUENT 1 September 13, 2005 13:29
case example for ventilation problem. Kevin CFX 0 March 20, 2004 04:58
Problem with CFX-5.5.1 solver Tuhin CFX 1 July 15, 2003 08:39
effect of ventilation on particles problem Jules FLUENT 0 June 10, 2002 15:41
Problem Solver Rizk, Lisa Main CFD Forum 1 August 5, 1998 13:54
