Modelling Supersonic TwoPhase Flow with Phase Change
Old   February 14, 2008, 09:47
Default Hi Every one, I have inter
wes
Hi Every one,
I have interest to model a Steam Injector using OpenFOAM. However, I am not sure if it has that capability.
The steam injector is a passive jet pump (with no moving parts) that has various applications, and currently, widely investigated in the nuclear industry (see its historical development http://en.wikipedia.org/wiki/Injector as well as recent work ftp://ftp.cordis.europa.eu/pub/fp5-e...ssi_en_ppt.pdf).
Essentially, a motive fluid (steam) from a high pressure vessel is released and passes through a nozzle supersonically and expands into a mixing chamber while entraining a working fluid (water or slurry) in the form of a jet before it breaks up and vaporises due to momentuum and heat energy transfer - forming a two-phase or dispered flow.
The two-phase system (condensing steam, vaporising water) finally passes through a diffuser throat as liquid.
The process involves both compressible flow (supersonic steam) and incompresible fluids (water), a water jet breakup, phase change of both water and steam.
Does OpenFOAM has such supersonic two-phase flow modelling capability at present? or
Is it potentially extendable to address such problems (for example, including scramjet fuel injection under cross flow ?)
I will appreciate your advice, specially commenting past experiences and more importantly the best place to start in investigating OpenFOAM so that I can spend some time on it.
Many thanks in advance
Wes
Old   May 2, 2008, 13:19
Default Hi, Wes It is nice to see y
YI
engs0226 is on a distinguished road
Hi, Wes
It is nice to see you put the case here. I will have a look into it.
Yi
engs0226 is offline   Reply With Quote
Old   October 2, 2008, 09:52
Default Hi, its nice to see your inte
Vishal Jambhekar
vishal is on a distinguished road
its nice to see your interesting upload
thanks, i would definately love to see it
Regards,
Vishal
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   October 2, 2008, 10:25
Default This would be very interesting
Martin Aunskjaer
aunola is on a distinguished road
This would be very interesting for me as well. I am faced with a problem that involves transient compressible/incompressible flow with phase change (condensation) and velocities from 0 to supersonic.
Currently, I have not used the multiphase solvers already included in OpenFOAM. I suspect we will not find a solver that can handle these problems:
http://www.opencfd.co.uk/openfoam/standardSolvers.html
aunola is offline   Reply With Quote
Old   October 2, 2008, 11:14
Default Wes, I model flashing flow wi
David P. Schmidt
schmidt_d is on a distinguished road
Wes,
I model flashing flow with an in-house code built from openFoam.
S. Gopalakrishnan and David P. Schmidt, "A Computational Study of Flashing Flow in Fuel Injector Nozzles," SAE Congress, Detroit, Paper 2008-01-0141, 2008.
The code handles condensation in an ad-hoc way, assuming it is just flashing in reverse. I've tried simulating a condensing jet pump, but the code isn't quite ready for it. Let's stay in touch, because over the next year or so, this is something that I want to get working.
-David
schmidt_d is offline   Reply With Quote
Old   February 6, 2009, 13:18
Default Hei Martin Aunskjaer im new
Nugroho Adi
mahaputra is on a distinguished road
im newbie on OpenFOAM
i also have same problem with you.
im working on multiphase of CO2 and H20, and trying to condense (phase change) the water vapour by the cooling tubes.
could you please guide me to solve these, and how to make our own solver for my case?
i didnt find until now any right solver for my case
Hilsen,
Nugroho Adi
mahaputra is offline   Reply With Quote
Old   August 12, 2009, 09:13
Default Supersonic two-phase flow with phase change
Wes Maru
WesMaru is on a distinguished road
Dear all,
Many thanks for your interest in the question I posted (as guest) few months back.
Appologies that I didn't follow it up to see your timely responses. In particular, I would like to thank David Schmidt for the reference material. I have also read your recent publication on Proceedings of the Combustion Institute 32 (2009) 3215–3222. It has some useful ideas. We are making progress but we are not yet where we wnated to be.
Our approach follows an Eulerian-Eulerian multifluid model, including jet-break-up under flashing conditions.
I will be happy to hear from you all.
Best Regards,
WesMaru is offline   Reply With Quote
Old   September 10, 2015, 08:54
Default Supersonic Two Phase Flows with Phase change
Shyam Sunder
ssyadav is on a distinguished road
Is it possible to simulate compressible (supersonic) two phase flows with phase change using OpenFOAM? The physical problem we want to simulate is the supersonic flow of CO2 in an ejector which will suck liquid CO2. Mixing and phase change will happen in the ejector throat. Any progress happened in OpenFOAM in this regard?
Thanks
ssyadav is offline   Reply With Quote
Old   April 26, 2016, 08:21
Francesco
ilfrance90 is on a distinguished road
Dear ssyadav,
I'm very interested in CO2 supersonic ejector with phase change. Have you found a solution for your problem using OpenFOAM or any other open-source/commercial software?
At the present moment I'm using ANSYS Fluent with lack of good results.
Please let me know if you made any progress.
Best Regards,
Francesco
ilfrance90 is offline   Reply With Quote
Old   July 27, 2021, 12:05
Default evaporation of water in a supersonic flow
Носов Геннадий А
Gena is on a distinguished road
Hello!
I am considering the problem of cooling the surface in a supersonic flow by creating a water film on the surface. Is there any way to calculate a similar task in the FOAM?
That is, the problem must contain simultaneously models of supersonic flow, two-phase flow and evaporation
Gena is offline   Reply With Quote
Assistance for modelling unsteady supersonic flow in FLUENT SATISH A.V FLUENT 11 October 1, 2014 23:36
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 04:59
one-fliud formulation twophase flow with phase cha Dusky.He Main CFD Forum 0 December 30, 2005 11:27
Modelling Phase Change using software.... ting Main CFD Forum 0 November 21, 2003 01:38
Phase change modelling Sebastien DANIEL FLUENT 1 July 6, 2000 04:35
