Cyclic specification
Old   February 8, 2009, 15:17
Default Despite reviewing past posts o
David Boger
boger is on a distinguished road
Despite reviewing past posts on this same topic, I'm still having trouble with specification of a cyclic boundary condition.
The application is a turbomachine with 8 blades, where I'm only solving one passage. I've specified the cyclic boundary, and checkMesh is satisfied with it (faces are correctly ordered, face areas match, etc.).
When I look at the solution (from simpleSRFFoam after foamToFieldview9), I find that the p and Uxrel fields are periodic (as they should be) but so are Uyrel and Uzrel (which should not be). In other words, the velocity is being matched at the cyclic boundaries without being properly transformed (rotated).
I've tried...
cyclic
type cyclic;
nFaces 13440 ;
startFace 2229120 ;
featureCos 0.9 ;
transform rotational;
rotationAxis (1 0 0);
rotationCentre (0 0 0);
...and...
cyclic
type cyclic;
nFaces 13440 ;
startFace 2229120 ;
featureCos 0.9 ;
... but get the same behavior in each.
Can someone help point out my mistake?
Thanks.
David A. Boger
boger is offline   Reply With Quote
Workstation specification M. Sau FLUENT 1 October 29, 2003 13:03
Re: swirl specification Christian FLUENT 0 September 2, 2002 09:12
swirl specification Prasad Laxman Kane FLUENT 0 August 31, 2002 04:00
BC specification Julie Polyakh Siemens 1 February 9, 2002 07:09
Turbulence Specification Oliver FLUENT 5 March 23, 2001 13:24
