IGNITING COMBUSTION MIXTURE IN reactingFoam HOW msha |
February 4, 2009, 02:24 |
if Non-premixed -> reactingFoa
#21 |
Mojtaba Shahmohammadian
Rep Power: 17 |
if Non-premixed -> reactingFoam
if premixed or partially premixed ->Xifoam |
February 4, 2009, 02:52 |
hello
#22 |
pavan
Rep Power: 17 |
hello
Mojtaba Shahmohammadian sir i am solving this problem in XIfoam only. my verticies are convertToMeters 1; vertices ( (0 0 0) (0 0.5 0) (14 0 0) (14 0.5 0) (180 0 0) (180 0.5 0) (0 22.5 0) (180 22.5 0) (0 0 1) (0 0.5 1) (14 0 1) (14 0.5 1) (180 0 1) (180 0.5 1) (0 22.5 1) (180 22.5 1) ); blocks ( hex (0 2 3 1 8 10 11 9) (14 1 1) simpleGrading (1 1 1) hex (2 4 5 3 10 12 13 11) (166 1 1) simpleGrading (1 1 1) hex (1 5 7 6 9 13 15 14) (180 22 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet1 ( (1 9 14 6) ) patch inlet2 ( (0 8 9 1) ) patch outlet ( (5 13 15 7) ) wall topwall ( (6 14 15 7) (1 9 11 3) ) wall bottomwall ( (0 8 10 2) (2 10 12 4) ) empty frontandback ( (8 9 11 10) (0 1 3 2) (9 14 15 13) (1 6 7 5) (10 11 13 12) (2 3 5 4) ) ); mergePatchPairs ( ); // ************************************************** *********************** // i need to define species seperately for air and fuel inlets, where i have to define species sir.. |
February 4, 2009, 03:01 |
have a look at run/tutorials/d
#23 |
Rep Power: 17 |
have a look at run/tutorials/dieselFoam/aachenBomb
and you see how to define boundary |
February 12, 2009, 04:27 |
hi everyone
i am solving one
#24 |
pavan
Rep Power: 17 |
hi everyone
i am solving one methane combustion problem, i am facing difficulty please any one can send one combustion solved problem through link for reference.. |
September 28, 2009, 11:38 |
why reaction rate is zero?
#25 |
mehdi
Rep Power: 17 |
Dear members,
I have a difficulty with reactingFoam. When I calculate reactingFoam tutorial or dieselenginfoam tutorial, the reaction rate is always Zero. I have switched on the chemistry and combustion as well as using a high temperature ignition region, however, regardless of the temperature and Arrhenius parameters that I used in chem.inp, the reaction rate is always zero. I should mentioned that other transport properties and equation for species (YEq) is properly solved. The problem is just in the calculation of reaction rate. Any help! |
September 28, 2009, 12:07 |
#26 |
Christof Benz
Rep Power: 17 |
where is the reaction rate calculated in dieselFoam? Christof |
September 29, 2009, 10:30 |
#27 |
mehdi
Rep Power: 17 |
the reaction rate is calculated in ~/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/chemistryModel/chemistryModel
September 29, 2009, 11:12 |
#28 |
Christof Benz
Rep Power: 17 |
Mehdi,
how could you get access to the reaction rate? Christof |
December 23, 2009, 10:48 |
#29 |
Ilja Sabelfeld
Rep Power: 17 |
hello niklas,
can you tell me how to compile the modified reactingFoam solver with wmake? i typed "wmake" in the terminal and got this: /applications/solvers/combustion/reactingFoam> wmake linuxGccDPOpt/options:7: *** missing separator. Schluss. wmake error: file 'Make/linuxGccDPOpt/objectFiles' could not be created |
June 15, 2010, 13:22 |
Access to specieThermo data
#30 |
mehdi
Rep Power: 17 |
Dear All,
Does any of you know to access to the thermodynamic propertie of species such as hi(T) where hi is enthalpy of ith specie and Ti is temprature of cell? In openFoam-1.5 you can write hi = chemistry.specieThermo()[i].h(Ti); and it works. See disealengienfoam solver in openfoam-1.5. However, in OpenFoam-1.6 if you write the same you get psichemistrymodel has no memebr specieThermo. How can we use specieThermo in OpenFoam-1.6? |
June 15, 2010, 19:32 |
#31 |
Marco A. Turcios
Rep Power: 28 |
Its related to how the thermo is now a member of the chemistry (or vice-versa, it's been a while since I took OO programming). I am trying to figure it out to solve the problem stated in a thread I started recently.
Mixture fraction with PPDF combustion | Erik | Siemens | 1 | September 5, 2011 22:47 |
RSMEARSM MSHA | msha | OpenFOAM Running, Solving & CFD | 4 | January 21, 2008 01:32 |
Mixture fraction for combustion problem | Jonathan Lemay | CFX | 3 | November 5, 2007 15:57 |
Which Solver MSHA | msha | OpenFOAM Running, Solving & CFD | 2 | October 15, 2007 12:04 |
Mixture fraction in Partially premixed combustion | Viktor | FLUENT | 1 | December 30, 2005 00:30 |
