July 26, 2010, 04:36 |
#121 |
Nima Samkhaniani
Rep Power: 25 |
hi sasan
im sure the version of openFoam in ur laptop and and where you run in it parallel is different , in new release of openFoam (1.7) , for stability,"p_rgh" is used instead of "p". |
July 26, 2010, 12:36 |
#122 |
sasan
Rep Power: 16 |
Thanks Nima and ngi,
That was helpful. |
April 24, 2011, 17:13 |
#123 |
Pablo
Rep Power: 17 |
Hello Hrvoje,
As I said, if there are no topological changes, no field mapping gets done. Instead, the integral equations we are discretising are rewritten for the arbitrary moving control volume instead of the static one. There are two effects: 1) the rate of change of the volume in the ddt term (vol and old vol) 2) the relative velocity in the convection term, equal to the difference between the absolute velocity and the mesh motion velocity - that's the mesh.phi() bit in the solver. Once you do that, the mesh motion effect is actually built into the equation itself and the "mapping" you refer to becomes a part of the solution. Can you tell me what procedures are doing the steps 1) and 2)?, i mean change at volumen and relative velocity correction?? Advanced thanks, Pablo |
May 9, 2011, 16:22 |
piso algorithm in interFOAM
#124 |
Nima Samkhaniani
Rep Power: 25 |
hello friend
why this following expression has been added to piso Algorithm - (fvc::grad(U) & fvc::grad(muEff)) is it for varying mu ? beacuse i think the effect of varying mu has been seen in : - fvm::laplacian(muEff, U) |
May 9, 2011, 16:35 |
#125 |
Santiago Marquez Damian
Rep Power: 24 |
This is explained in Edin Berberovic's paper and due viscosity spacial variability and the expansion of (nabla U + nabla U^T) term.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
May 9, 2011, 18:23 |
#127 |
Rep Power: 24 |
I've sent it to the mail published in your contact info.
Regards.
May 25, 2011, 17:30 |
#128 |
Walter Schostak
Rep Power: 15 |
So i've been using interFoam for the past week few weeks now and I'm starting to wonder if it's the best solver for what I'm trying to do (vof and mhd together).
It seems like interFoam, rather than taking properties of each fluid separately, takes properties of the mixture into account. Is there a different solver that would be more suited to solving two separate fluids such as liquid metal and plasma? |
September 19, 2019, 04:20 |
#129 |
neginmondegari
Rep Power: 7 |
hello , I want to model the exterimental flume with the changeable slope and I want to model the bottom outlet with openfoam , is it possible to model it with interfoam? and is it possible to model the dam with changeable slope because of topography and is it possible to model the bottom outlet in dam?
December 2, 2019, 06:39 |
Mules
#130 |
Deutschland
Rep Power: 7 |
Hello every one,
Does anybody know about the Algorithm which is used in the MULES method? |
InterFoam MULES solver | jaswi | OpenFOAM Running, Solving & CFD | 6 | June 21, 2022 09:46 |
Wmake problem interFoam solver | feijooos | OpenFOAM Running, Solving & CFD | 4 | December 8, 2008 12:01 |
DICPCG solver in interFoam | m9819348 | OpenFOAM Running, Solving & CFD | 1 | September 20, 2007 14:10 |
About interfoam solver | qiu | OpenFOAM Running, Solving & CFD | 0 | May 6, 2007 23:48 |
Need documentation for interFOAM solver | mer | OpenFOAM Running, Solving & CFD | 5 | May 31, 2006 13:22 |
