Incompressible RSM turbulence thermal transport Can OpenFOAM do this
Old   February 18, 2009, 13:05
Default Hi everyone, I'm new to OpenFO
ms
anothr_acc is on a distinguished road
Hi everyone, I'm new to OpenFOAM but have Fluent experience. I'm choosing a package to use at work, but am unsure whether OpenFOAM is able to solve the case I need.
Specifically, I have a bluff body, Re = 33k. With Fluent, I found best results using an RSM turbulence model, so hope to use it here. An added complication now, is thermal effects. I want to simulate the heat transfer from the flow into the body, and from the body into the flow, at the same time as the turbulence calculations.
The temperature distribution throughout the body
is also required.
Is this possible?
Best regards,
Mark.
anothr_acc is offline   Reply With Quote
Old   February 20, 2009, 10:58
Default Um, anybody know? A yes / no
ms
Um, anybody know? A yes / no is enough; I'll investigate from there. It looks to me like it will do it, but some verification would be nice....
BR,
Mark.
Old   February 23, 2009, 07:45
Default Well, it appears that to solve
ms
Well, it appears that to solve thermal transport with incompressible, laminar flow with an unsteady solution, requires copying, changing / adding to the solved equation by editing the code, and recompiling; detailed at
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
So, I'm wondering, how complicated is it to generate the temperatures in a solid body, in a turbulent flow. Possibly, very?!
Comments, anyone?
Old   February 23, 2009, 08:34
Default Isn't chtMultiRegionFoam solve
Etienne Lorriaux
elorriaux is on a distinguished road
Isn't chtMultiRegionFoam solver designed to perform such cases ? : http://opencfd.co.uk/openfoam/doc/st...l#x13-880003.5
The only point to be discussed concerns the possibility to use a RSM model since it does not to be available in the RASproperties from the tutorial.
elorriaux is offline   Reply With Quote
Old   February 23, 2009, 09:40
Default Oooh. Interesting. I read
ms
http://www.cfd-online.com/cgi-bin/Op...=3807#POST3807
and
and was getting worried. I'll explore your suggestion. As far as the RSM model is concerned, it is of importance, I'm afraid. Still, things look better, already! Thanks....
BR,
Mark.
Old   February 23, 2009, 09:52
Default Hello Mark, I think you will
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello Mark,
I think you will find this discussion also interesting: conjugate heat transfer
I hope it will be helpful,
Dragos
dmoroian is offline   Reply With Quote
Old   February 24, 2009, 06:39
Default Hi Dragos, Wonderful link,
ms
Hi Dragos,
Wonderful link, and very interesting! I am going to recommend OpenFOAM at work, and start the installation.
BR,
Mark.
OpenFoam for heat transport problems Martin Lorenz (Lorenz) OpenFOAM Running, Solving & CFD 16 March 18, 2009 04:05
What is advection term of incompressible turbulence model waynezw0618 OpenFOAM Running, Solving & CFD 2 December 6, 2008 08:46
OpenFOAM - incompressible solver + porous zones Nicolai Heilskov FLUENT 1 October 23, 2008 09:34
Thermal and species transport in steady state mrangitschdowcom OpenFOAM Running, Solving & CFD 3 October 10, 2007 06:21
incompressible turbulence code Frank Main CFD Forum 4 May 28, 2005 00:31
