Moving mesh
Like Tree5Likes
Old   September 11, 2006, 11:54
Default Mmm, allright. It seems that a
  #61
Frank Bos
lr103476 is on a distinguished road
Mmm, allright. It seems that all your development sources work for you, so I'll have to find the solution in my own version (which has to be the same as yours, but apparently it isn't).
I just compiled your latest version and tried to run icoDyMFoam on the tutorial movingCone, without success. All other version worked.
Since this problem concerns the standard tutorial passing my case is not very usefull.
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   September 11, 2006, 13:01
Default Just as a proof: no changes no
  #62
Hrvoje Jasak
Just as a proof: no changes no modifications, all checking switched on. I have tried both the debug and optimised version and the log file is below.
Could you please investigate further why your compilation does not work: dump a core, produce a trace-back, run it in gdb, whatever. (I get a bit upset when people claim there are bugs in my code and I cannot reproduce them - I want to get to the bottom of this because claiming that OpenFOAM does not work when in fact it does isn't too good for its reputation).
There is no core dump, no errors and results all look fine. If you are running linux and wish to try my pre-compiled version, I will upload it for you.
Hrv
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : icoDyMFoam /home/hjasak/OpenFOAM/OpenFOAM-1.3/tutorials/icoDyMFoam movingCone
Date : Sep 11 2006
Time : 13:03:51
Host : wooster
PID : 11167
Root : /home/hjasak/OpenFOAM/OpenFOAM-1.3/tutorials/icoDyMFoam
Case : movingCone
Nprocs : 1
Create time
Create mesh
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: laplaceTetDecomposition
--> FOAM Warning :
From function motionSolver::New(const polyMesh& mesh)
in file motionSolver/motionSolver.C at line 128
library "libtetDecompositionMotionSolver.so" did not introduce any new solvers
Selecting motion diffusion: quadratic
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Courant Number mean: 0 max: 0.3
Time = 5e-06
ICCG: Solving for motionUx, Initial residual = 0.333932, Final residual = 8.50863e-07, No Iterations 356
ICCG: Solving for motionUy, Initial residual = 0, Final residual = 0, No Iterations 0
ICCG: Solving for motionUz, Initial residual = 0, Final residual = 0, No Iterations 0
ICCG: Solving for motionUx, Initial residual = 3.73751e-06, Final residual = 8.84986e-07, No Iterations 30
ICCG: Solving for motionUy, Initial residual = 0.987058, Final residual = 9.34251e-07, No Iterations 263
ICCG: Solving for motionUz, Initial residual = 0.546445, Final residual = 8.85339e-07, No Iterations 323
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 6.23114e-07, No Iterations 75
time step continuity errors : sum local = 6.26213e-10, global = 6.4426e-12, cumulative = 6.4426e-12
BICCG: Solving for Ux, Initial residual = 1, Final residual = 7.61303e-06, No Iterations 2
BICCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
BICCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
ICCG: Solving for p, Initial residual = 1, Final residual = 6.03629e-07, No Iterations 75
time step continuity errors : sum local = 6.07671e-10, global = 6.45641e-12, cumulative = 1.2899e-11
ICCG: Solving for p, Initial residual = 0.00677437, Final residual = 8.22704e-07, No Iterations 62
time step continuity errors : sum local = 1.00025e-07, global = 2.34368e-09, cumulative = 2.35658e-09
ExecutionTime = 3.41 s ClockTime = 4 s
Courant Number mean: 0.0397779 max: 0.372153
Time = 1e-05
Correct mesh motion diffusion field.
ICCG: Solving for motionUx, Initial residual = 3.41515e-06, Final residual = 8.93471e-07, No Iterations 49
ICCG: Solving for motionUy, Initial residual = 0.989602, Final residual = 9.85824e-07, No Iterations 289
ICCG: Solving for motionUz, Initial residual = 0.546265, Final residual = 9.13804e-07, No Iterations 269
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 6.7167e-07, No Iterations 72
time step continuity errors : sum local = 6.71839e-14, global = 2.13234e-16, cumulative = 2.35658e-09
BICCG: Solving for Ux, Initial residual = 0.344286, Final residual = 1.12243e-06, No Iterations 2
BICCG: Solving for Uy, Initial residual = 0.32579, Final residual = 2.20941e-06, No Iterations 2
BICCG: Solving for Uz, Initial residual = 0.362702, Final residual = 3.99925e-07, No Iterations 2
ICCG: Solving for p, Initial residual = 0.0113948, Final residual = 7.16112e-07, No Iterations 66
time step continuity errors : sum local = 8.12654e-08, global = -2.47821e-09, cumulative = -1.21634e-10
ICCG: Solving for p, Initial residual = 0.139198, Final residual = 9.54865e-07, No Iterations 67
time step continuity errors : sum local = 5.44034e-09, global = -1.28179e-10, cumulative = -2.49812e-10
ExecutionTime = 5.49 s ClockTime = 6 s
Courant Number mean: 0.0398552 max: 0.356209
Time = 1.5e-05
ICCG: Solving for motionUx, Initial residual = 3.22157e-06, Final residual = 9.86558e-07, No Iterations 64
ICCG: Solving for motionUy, Initial residual = 0.988925, Final residual = 9.88541e-07, No Iterations 286
ICCG: Solving for motionUz, Initial residual = 0.544325, Final residual = 9.72933e-07, No Iterations 335
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 9.57401e-07, No Iterations 69
time step continuity errors : sum local = 5.20859e-15, global = -1.81837e-16, cumulative = -2.49813e-10
BICCG: Solving for Ux, Initial residual = 0.0290755, Final residual = 2.51565e-07, No Iterations 2
BICCG: Solving for Uy, Initial residual = 0.0182216, Final residual = 3.24186e-07, No Iterations 2
BICCG: Solving for Uz, Initial residual = 0.0495605, Final residual = 1.36253e-07, No Iterations 2
ICCG: Solving for p, Initial residual = 0.0561452, Final residual = 5.71964e-07, No Iterations 68
time step continuity errors : sum local = 4.49475e-09, global = 1.09514e-11, cumulative = -2.38861e-10
ICCG: Solving for p, Initial residual = 0.0277816, Final residual = 8.98554e-07, No Iterations 66
time step continuity errors : sum local = 2.92845e-09, global = -1.98449e-11, cumulative = -2.58706e-10
ExecutionTime = 7.77 s ClockTime = 8 s
Courant Number mean: 0.0398308 max: 0.364695
Time = 2e-05
ICCG: Solving for motionUx, Initial residual = 3.32674e-06, Final residual = 8.90922e-07, No Iterations 53
ICCG: Solving for motionUy, Initial residual = 0.987783, Final residual = 7.52348e-07, No Iterations 289
ICCG: Solving for motionUz, Initial residual = 0.545915, Final residual = 8.88369e-07, No Iterations 269
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 7.12271e-07, No Iterations 72
time step continuity errors : sum local = 2.08577e-15, global = 1.31623e-17, cumulative = -2.58706e-10
BICCG: Solving for Ux, Initial residual = 0.0130907, Final residual = 1.13601e-07, No Iterations 2
BICCG: Solving for Uy, Initial residual = 0.00892455, Final residual = 2.62396e-07, No Iterations 2
BICCG: Solving for Uz, Initial residual = 0.0291297, Final residual = 2.58634e-07, No Iterations 2
ICCG: Solving for p, Initial residual = 0.080324, Final residual = 9.88008e-07, No Iterations 65
time step continuity errors : sum local = 2.56599e-09, global = -7.18699e-11, cumulative = -3.30576e-10
ICCG: Solving for p, Initial residual = 0.0145031, Final residual = 8.49663e-07, No Iterations 63
time step continuity errors : sum local = 1.36934e-09, global = 5.81763e-11, cumulative = -2.724e-10
ExecutionTime = 9.84 s ClockTime = 10 s
Courant Number mean: 0.0398289 max: 0.381277
Time = 2.5e-05
ICCG: Solving for motionUx, Initial residual = 3.08727e-06, Final residual = 7.46627e-07, No Iterations 72
ICCG: Solving for motionUy, Initial residual = 0.988006, Final residual = 8.85239e-07, No Iterations 273
ICCG: Solving for motionUz, Initial residual = 0.544007, Final residual = 7.89614e-07, No Iterations 336
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 8.09497e-07, No Iterations 71
time step continuity errors : sum local = 1.10848e-15, global = -8.70327e-18, cumulative = -2.724e-10
BICCG: Solving for Ux, Initial residual = 0.00689708, Final residual = 9.06655e-08, No Iterations 2
BICCG: Solving for Uy, Initial residual = 0.00525592, Final residual = 2.6685e-07, No Iterations 2
BICCG: Solving for Uz, Initial residual = 0.0261652, Final residual = 7.36214e-07, No Iterations 2
ICCG: Solving for p, Initial residual = 0.0900033, Final residual = 7.65894e-07, No Iterations 65
time step continuity errors : sum local = 1.08237e-09, global = -3.39246e-11, cumulative = -3.06324e-10
ICCG: Solving for p, Initial residual = 0.00504438, Final residual = 8.92693e-07, No Iterations 61
time step continuity errors : sum local = 1.55422e-09, global = 6.77828e-11, cumulative = -2.38541e-10
ExecutionTime = 12.07 s ClockTime = 12 s
Courant Number mean: 0.0398403 max: 0.396002
Time = 3e-05
ICCG: Solving for motionUx, Initial residual = 2.99113e-06, Final residual = 9.08349e-07, No Iterations 42
ICCG: Solving for motionUy, Initial residual = 0.988275, Final residual = 8.56148e-07, No Iterations 278
ICCG: Solving for motionUz, Initial residual = 0.545496, Final residual = 8.68867e-07, No Iterations 272
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 7.67399e-07, No Iterations 72
time step continuity errors : sum local = 1.19255e-15, global = -3.27025e-17, cumulative = -2.38542e-10
BICCG: Solving for Ux, Initial residual = 0.00693229, Final residual = 9.56379e-08, No Iterations 2
BICCG: Solving for Uy, Initial residual = 0.0044486, Final residual = 5.1566e-07, No Iterations 2
BICCG: Solving for Uz, Initial residual = 0.0257812, Final residual = 1.39664e-09, No Iterations 3
ICCG: Solving for p, Initial residual = 0.0566965, Final residual = 8.99613e-07, No Iterations 61
time step continuity errors : sum local = 1.46782e-09, global = 4.79478e-11, cumulative = -1.90594e-10
ICCG: Solving for p, Initial residual = 0.00275329, Final residual = 9.16257e-07, No Iterations 54
time step continuity errors : sum local = 1.41291e-09, global = 3.96204e-11, cumulative = -1.50973e-10
ExecutionTime = 14.07 s ClockTime = 14 s
Courant Number mean: 0.0398482 max: 0.409515
Time = 3.5e-05
Hrvoje Jasak
Old   September 11, 2006, 15:54
Default Frank I recently compiled H
  #63
irc
Ian Cowan
irc is on a distinguished road
Frank
I recently compiled Hrv's code (on an AMD64 under RHEL v3), and it runs without any problems ... What version of gcc are you using? What platform did you compile on?
irc is offline   Reply With Quote
Old   September 11, 2006, 17:42
Default I am using gcc version 4.1.1 o
  #64
Frank Bos
I am using gcc version 4.1.1 on a single core Intel processor running RedHat EL4 (kernel version = 2.6.9-11).
Prof Hrvoje Jasak, I do not claim that there are bugs in your code. On the contrary, learning more about the code, I am getting more and more exciting how well things are programmed, how well things work and the vast capabilities of the code.
All that I want is to figure out why my compiled version shows some problems. Moving to newer versions of gcc, OF sources and paraview causes me some problems at this moment. I am not very familiar with core dumps, trace-back and gdb, but tomorrow I will give these things a try. If it is no much work, could you please upload your precompiled version, just to test.
Regards, Frank
Frank Bos
Old   September 11, 2006, 20:55
Default Hi Frank, Don't worry about
  #65
Hrvoje Jasak
Hi Frank,
Don't worry about it - I am just trying to find out if there are bugs or some problems I haven't see before. Here are two ways to produce a core dump and traceback on linux.
1) from a core file. Type
unlimit
or
limit coredumpsize unlimited
Run the code. This should crash and produce a core file (probably quite large) in the current directory. Once you've got the core do the following
gdb icoDyMFoam core
(note that the name of the core file may have some numbers attached - just use the complete file name). When you get the prompt, type:
where
The stuff that comes up on the screen is a cure trace-back - this is what I need.
2) Running from gdb. Do
gdb icoDyMFoam
Wait until you get the prompt. The do (r is for Run):
r <root> <case>
The effect should be similar to above, but without creating the core file. Once you get the prompt back, type:
where
and send me the trace-back.
I have uploaded a pre-compiled version on:
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/release/
Enjoy,
Hrv
Hrvoje Jasak
Old   September 12, 2006, 10:30
Default Again I have some problems con
  #66
Frank Bos
Again I have some problems concerning the recompilation of the development sources. Let me give an overview:
Machine 1: Red Hat Enterprise 4, gcc 4.1.1:
1) compiling prof Jasak's sources (11-09-2006) -> segmentation fault when using icoDyMFoam on movingCone tutorial.
2) compiling prof Jasak's sources (11-09-2006) with DEBUGGING enabled -> icoDyMFoam on movingCone tutorial works (so no core dump since it works:-S) but needs thousands of iterations, strange!
3) using precompiled version of prof Jasak's sources (11-09-2006) -> segmentation fault when using icoDyMFoam on movingCone tutorial.
Machine 2: OpenSuse 10, gcc 4.1.0:
1) compiling prof Jasak's sources (11-09-2006) -> segmentation fault when using all solvers
2) using precompiled version of prof Jasak's sources (11-09-2006) -> icoDyMFoam on movingCone tutorial works perfectly!
So only the precompiled version works on my home machine, which is not that fast. I want to use my RHEL4 machine. Do I miss some extra libraries?
Regards, Frank
Frank Bos
Old   September 12, 2006, 10:49
Default Sounds nasty - are you picking
  #67
Hrvoje Jasak
Sounds nasty - are you picking up the wrong compiler of libstdc++?
I have to say I'm happy you can now see that I was telling the truth when I said "it works for me" :-)
I really don't know how to help further - please feel free to ask specific questions if appropriate.
Hrv
Hrvoje Jasak
Old   September 12, 2006, 11:30
Default On my 2 machines different lib
  #68
Frank Bos
On my 2 machines different libstdc++ versions are natively installed, when I use rpm -q.... But I thought that this libstdc++ is in the /OpenFOAM/linux/gcc-4.1.1/lib So that one is supposed to be used.
Machine 1: RHEL4
lraspasik:/home/frankl > rpm -q libstdc++
libstdc++-3.4.3-22.1
Machine 2: OpenSUSE 10
mithril:/home/frankl> rpm -q libstdc++
libstdc++-4.0.2_20050901-3
In both cases the foamInstallationTest shows no errors.
Frank
Frank Bos
Old   September 12, 2006, 14:07
Default It seems that all the other so
  #69
Frank Bos
It seems that all the other solvers are working succesfully on the tutorials.
Is there a specific difference between icoDyMFoam and the other solvers which could cause some compiler related issues? On the other hand, icoDyMFoam works perfectly on the mixer2D tutorial. So a major difference between mixer2D and movingCone could also play a role.
Summarising: it appears that there are compiler and platform dependent pieces of source code present in icoDyMFoam only.
Frank
Frank Bos
Old   September 13, 2006, 05:23
Default icoDymFoam uses the dlopen fun
  #70
Mattijs Janssens
mattijs is on a distinguished road
icoDymFoam uses the dlopen functionality (loads a .so library at runtime). Possibly your version of os and libraries has problems with it.
Also you get the warning
Maybe there is a problem with loading it twice?
mattijs is offline   Reply With Quote
Old   September 13, 2006, 05:44
Default It is even getting stranger. I
  #71
Frank Bos
It is even getting stranger. I've put an exact copy of the precompiled sources, OpenFOAM-1.3 and /linux (11-09-2006) on my network account and icoDyMFoam and everything else works beautifully:-S
So, I've got two exact versions running on the same machine (!!!), but at different locations. Each uses the same versions of gcc (4.1.0) from /OpenFOAM-1.3/linux.
The one from the network location works, the other local version doesn't. Strange!!
At both locations I checked: ldd `which icoDyMFoam`:
local location:
lraspasik:/home/frankl/OpenFOAM/frankl-1.3/run/tutorials/icoDyMFoam > ldd `which icoDyMFoam`
libdynamicFvMesh.so => /home/frankl/OpenFOAM/frankl-1.3/lib/linuxGcc4DPOpt/libdynamicFvMesh.so (0x00b81000)
libdynamicMesh.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libdynamicMesh.so (0x008c9000)
libtetDecompositionMotionSolver.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libtetDecompositionMotionS olver.so (0x0017a000)
libengine.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libengine.so (0x00f74000)
libmeshTools.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libmeshTools.so (0x001e7000)
libfiniteVolume.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libfiniteVolume.so (0x00fc8000)
libOpenFOAM.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libOpenFOAM.so (0x0043b000)
libstdc++.so.6 => /home/frankl/OpenFOAM/linux/gcc-4.1.0/lib/libstdc++.so.6 (0x00337000)
libm.so.6 => /lib/tls/libm.so.6 (0x00111000)
libgcc_s.so.1 => /home/frankl/OpenFOAM/linux/gcc-4.1.0/lib/libgcc_s.so.1 (0x00747000)
libpthread.so.0 => /lib/tls/libpthread.so.0 (0x00134000)
libc.so.6 => /lib/tls/libc.so.6 (0x00752000)
libPstream.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/lam-7.1.1/libPstream.so (0x00146000)
libtriSurface.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libtriSurface.so (0x00eff000)
libcellDecompFiniteElement.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libcellDecompFiniteElement .so (0x00cdb000)
libsampling.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libsampling.so (0x0014d000)
liblagrangian.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/liblagrangian.so (0x00170000)
libfoamUser.so => /home/frankl/OpenFOAM/frankl-1.3/lib/linuxGcc4DPOpt/libfoamUser.so (0x00173000)
libz.so => /home/frankl/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libz.so (0x00702000)
/lib/ld-linux.so.2 (0x00424000)
libmpi.so.0 => /home/frankl/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOpt/lib/li bmpi.so.0 (0x00a40000)
liblam.so.0 => /home/frankl/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOpt/lib/li blam.so.0 (0x00ab4000)
libutil.so.1 => /lib/libutil.so.1 (0x00c8d000)
libdl.so.2 => /lib/libdl.so.2 (0x00175000)
network location:
lraspasik:/home12/frank/OpenFOAM/frank-1.3/run > ldd `which icoDyMFoam`
libdynamicFvMesh.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libdynamicFvMesh.so (0x002c7000)
libdynamicMesh.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libdynamicMesh.so (0x00111000)
libtetDecompositionMotionSolver.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libtetDecompositionMotion Solver.so (0x00b81000)
libengine.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libengine.so (0x002e4000)
libmeshTools.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libmeshTools.so (0x004a7000)
libfiniteVolume.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libfiniteVolume.so (0x00bee000)
libOpenFOAM.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libOpenFOAM.so (0x005f7000)
libstdc++.so.6 => /home12/frank/OpenFOAM/linux/gcc-4.1.0/lib/libstdc++.so.6 (0x00338000)
libm.so.6 => /lib/tls/libm.so.6 (0x00288000)
libgcc_s.so.1 => /home12/frank/OpenFOAM/linux/gcc-4.1.0/lib/libgcc_s.so.1 (0x002ab000)
libpthread.so.0 => /lib/tls/libpthread.so.0 (0x0043b000)
libc.so.6 => /lib/tls/libc.so.6 (0x008be000)
libPstream.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/lam-7.1.1/libPstream.so (0x002b6000)
libtriSurface.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libtriSurface.so (0x009e7000)
libcellDecompFiniteElement.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libcellDecompFiniteElemen t.so (0x00a56000)
libsampling.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libsampling.so (0x0044d000)
liblagrangian.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/liblagrangian.so (0x002bd000)
libfoamUser.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libfoamUser.so (0x00498000)
libz.so => /home12/frank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libz.so (0x00470000)
libmpi.so.0 => /home12/frank/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOpt/lib/l ibmpi.so.0 (0x01a5a000)
liblam.so.0 => /home12/frank/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOpt/lib/l iblam.so.0 (0x033f8000)
libutil.so.1 => /lib/libutil.so.1 (0x002c0000)
libdl.so.2 => /lib/libdl.so.2 (0x00418000)
Anymore ideas?
Regards, Frank
Frank Bos
Old   September 13, 2006, 08:18
Default here another riddle: *icoDy
  #72
Frank Bos
*icoDyMFoam works when installed on the network and run from the network drive on my RHEL4 machine.
*icoDyMFoam fails when installed on the network and run from the local drive on my RHEL4 machine.
In both cases all the links are pointing towards the OpenFOAM en linux dirs on the network drive.
At least this gives me the good feeling that it
will work on our cluster, but I am not able to use my local harddrive while running.
Regards,
Frank
Frank Bos
Old   September 13, 2006, 10:08
Default It works using a different use
  #73
Frank Bos
It works using a different user account on my local disk!!! Very strange, but it probably has something to do with my user id settings......but I copied my .bashrc to the new user....strange:-S
Anyway, this is no major problem anymore, and I can resume developing new stuff instead of trying to solve these strange windows-like problems. I bet the new versions will work again using my ordinary user account :-S
Regards, Frank
Frank Bos
Old   October 16, 2006, 14:46
Default Dear Prof Hrvoje Jasak and Fra
  #74
kim
Hyung min Kim
kim is on a distinguished road
Dear Prof Hrvoje Jasak and Framk Bos
I am trying to solve oscillating cylinder in a channel using icoDyMFoam with oscillatingFixedVlaue boundary.
But I have the same problem as Foank Bos had before.
Could you tell me how to fix the problem.
If I need the prof. jasak precompiled OpenFoam,
Could some tell me how to get the code?
Thank you
pius
kim is offline   Reply With Quote
Old   October 16, 2006, 16:00
Default Dear Prof Jasak When I run
  #75
kim
Hyung min Kim
Dear Prof Jasak
When I run your case "oscillatingCavityMotion"
I have a same problem as Frank Bos
" NO motions are solved"
Please tell me How to fix the problem.
if I need your code, Please tell me How to get is?
Thank you
pius
Old   October 16, 2006, 16:56
Default Hi Pius, Using the develop
  #76
Frank Bos
Hi Pius,
Using the development code of OpenFOAM v1.3 of prof. Jasak (from 11 sept 2006) my problems of "no motion" were solved. I think that he solved some wall BC related problems, which appeared in the current release of OpenFOAM 1.3.
I still have some unknown user profile related problems using that OF version, but creating a new user for OF calculation also solved that problem.
I dont know what the best, either prof Jasak has to provide you his latest sources (I dont know if he still got the version I am using now) or I have to put my working version (precompiled) on my site.
Prof Jasak, do you mind if I share your code? It is still GPL, right?
Regards, Frank
Frank Bos
Old   October 17, 2006, 03:17
Default Allright, Pius, You can ta
  #77
Frank Bos
Allright, Pius,
You can take the precompiled development code from my site: www.aero.lr.tudelft.nl/~frank
goto downloads->files
Regards, Frank
Frank Bos
Old   October 17, 2006, 19:58
Default Thanks, Frank It wokrs well
  #78
kim
Hyung min Kim
Thanks, Frank
It wokrs well.
Pius
Old   January 14, 2009, 05:33
Default Hi all, i am using OF-1.5.
  #79
Andreas Christl
andy is on a distinguished road
Hi all,
i am using OF-1.5.
I want to move a rotating cylinder on a circular path in a fluid bordered
by a fix cylinder...
I modded tutorial case movingCone (icoDyMFoam) with type angularOscillatingDisplacement
for movingWall (rotating inner cylinder) in pointMotionU.
The start looks nice...but soon the gridlines coil round the rotating inner cylinder...
(1)Is there any possibility to change this mesh behavior?
(2)Or should i try simpleSRFFoam like in mixer-tutorial? But how to realize the circular path?
I would be grateful for any hints.
Andy
andy is offline   Reply With Quote
Old   January 25, 2009, 13:59
Default hi... solved the problem...
  #80
Andreas Christl
hi...
- used setBoundary to put a velocity profile on the inner cylinder which will not move anymore
[please change binary to ascii in controlDict/write if you build your case from movingCone- tutorial!!]
- changed oscillatingDisplacement.C and .H (compile with Allwmake in /OF-1.5/src...first time compiling takes a little time ;)) to create a circular path for the outer cylinder
-axis of both cylinders should differ
so no more mesh-problems occurs
perhaps someone has a smarter way to move something on a circular path...i didn`t
find one...
Andy
Moving Reference frame - UDF - Moving mesh modisa FLUENT 0 April 18, 2008 14:31
Moving Mesh & Not Rotating Mesh AB Siemens 1 October 25, 2004 04:10
moving mesh Jim Siemens 2 August 27, 2002 08:39
moving mesh zqf Siemens 1 June 19, 2002 02:30
moving mesh khb Main CFD Forum 1 June 5, 2002 11:46
