July 15, 2008, 22:13 |
I notice fan type BC in
Pei-Ying Hsieh
Rep Power: 18 |
I notice fan type BC in OF-1.5. Had anyone tried it yet? Does anyone knows how to use it? pei |
July 16, 2008, 08:00 |
The fan boundary is an interna
Eugene de Villiers
Rep Power: 21 |
The fan boundary is an internal coupled patch (cyclic) with a scalar jump for pressure. Basically a jump boundary.
July 16, 2008, 09:22 |
Hi, Eugene,
Thanks for the
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Eugene,
Thanks for the answer. Is there any example on how to use it? Pei |
July 17, 2008, 09:27 |
Hi, Eugene,
I am considerin
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Eugene,
I am considering using the fan type BC to model a fan inside fluid domain. A fan has an intake and an outlet (back into the fluid domain). If the pressure at far field is 0, then, the intake side of the fan might be negative, then, there is a pressure jump to the outlet (this pressure may be positive). Can the fan type BC handle something like this? That is, specify low pressure on the fan intake side, and then, a pressure jump for the whole fan? Pei |
July 17, 2008, 09:56 |
I didn't write this BC, so alt
Eugene de Villiers
Rep Power: 21 |
I didn't write this BC, so although I have based some development off it, don't take my word as writ. Basically this boundary effects a pressure jump. Cross in one direction and the pressure increases, cross in the other and it decreases.
Unfortunately I don't have an example of its usage. I can say that it works on top of a cyclic type boundary though. This means all the other flow fields will have a cyclic (or cyclic derived) boundary at the location of the fan. So to answer your questions yes and yes. |
July 17, 2008, 23:06 |
Thanks again, Eugene!
Pei
Pei-Ying Hsieh
Rep Power: 18 |
Pei |
July 27, 2008, 13:17 |
Good morning,
I understand
Pierre-Olivier Dallaire
Rep Power: 17 |
Good morning,
I understand that the new fan BC adds a pressure jump on an internal boundary (surface). For this BC, how is defined the velocity ? Is is possible to use the fan bc and specify a velocity profile at the fan outlet (using funkysetfield) ? I already have a case where a thin cylinder was grooved and removed from the mesh. I applied some bcs on the two circular surfaces in order to simulate the fan inlet/outlet behavior. My fan is in a room. A pressureInlet bc was specified for the room inlet and the pressureInletOutlet bc was used for the room outlet. I'd like to try this new fan bc but did not find any specific example case using it. Best regards, PO |
July 28, 2008, 06:35 |
You will not be able to specif
Eugene de Villiers
Rep Power: 21 |
You will not be able to specify the velocity at the jump boundary without some user coding. At the moment there are only 2 boundaries that can coincide with an internal boundary: cyclic and jumpCyclic. To do what you want, you will have to derive a new BC type that can sit on top of a cyclic patch, but behave like a fixed value.
Unfortunately, this might be quite tricky. |
February 24, 2009, 07:00 |
Hello http://www.cfd-online.co
#9 |
Steinar Aasebų
Rep Power: 17 |
Hello
I do not find any examples of how to assign this fan boundary condition. Are there anyone who have done this before? Best regards, Steinar |
March 18, 2009, 03:57 |
#10 |
Vincent RIVOLA
Rep Power: 18 |
Hi everyone,
Thanks to Eugene I understood that the internal faces are treated with a cyclic boundary condition in OpenFOAM. I also would like to use the fan boundary condition to impose a pressure jump through an internal surface. My problem is that I don't know how to set up the boundary condition files. For the boundary of interest named disk, i have the following: in p file: disk { type cylic; value uniform -1000; } in U file: disk { type cyclic; } in boundary file: disk { type cyclic; nFaces 640; startFace 53760; } If I impose the conditions above, there is no pressure jump happening during the computation with simpleFoam. Could one of you tell me how to set up those boundary conditions to get a pressure jump? Thanks in advance. Vincent |
April 15, 2009, 12:55 |
#11 |
Steinar Aasebų
Rep Power: 17 |
Dear Foamers
The fan boundary condition is working on a cyclic patch (named ad here) defined in constant/polyMesh/boundary as ad { type cyclic; } and then in the pressure file 0/p: ad { type fan; patchType cyclic; f List<scalar> 2(10.0 -1.0); value uniform 0; } The f above is a list of polynomial coefficients in the pressure jump definition delta p = f_1 + f_2 * v + f_3 * v^2 + ... Above only f_1 and f_2 is assigned, respectively 10.0 and -1.0. In 0/U and so on, the ad patch is defined as cyclic. My problem is now: Is it possible to assign nonuniform coefficients f along the patch, e.g. if I want to assign a nonuniform pressure jump independent of velocity (using only f_1)? Best Regards Steinar |
April 17, 2009, 15:08 |
Example case
#12 |
Michael Roth
Rep Power: 17 |
Thanks Steinar. Here's an example for flow down a duct driven by a fan in the middle.
Mike |
July 17, 2009, 17:52 |
#13 |
What is the "featureCos" in the boundary file? It is set to 0.9
What's the definition? |
April 30, 2010, 04:03 |
#14 | |
maddalena
Rep Power: 23 |
could you explain me how I set the sign of pressure difference? How can I understand if I have to set the delta p is positive or negative before running the case itself? Thank you! |
April 30, 2010, 08:06 |
#15 |
Steinar Aasebų
Rep Power: 17 |
For a fan, you probably want a positive pressure jump when moving through the fan in the velocity direction (from suction side to pressure side). But if it is the order of patches in the cyclic, or the coordinate system that tells if f_1 should be positive also, I don't remember. You will see it quite quick if the pressure jump has wrong direction. BR, Steinar |
June 16, 2010, 06:05 |
A Reqest
#16 |
mohsen
Are you have any information about Intake-fan Boundry condition? I have a project about Intake fan, that have a problem, can you help me ? in the other hand i need 2 example about intake-fan. Thank u for reply. |
September 14, 2010, 04:59 |
#17 | |
maddalena
Rep Power: 23 |
...thinking to what Eugene posted above...
2) Does this mean that the fan can be used as a sort of local losses to simulate the pressure drop on a system that does not need to be modeled? mad Last edited by maddalena; September 14, 2010 at 05:30. |
September 14, 2010, 09:27 |
#18 |
Olivier
Rep Power: 18 |
hello maddalena,
for 1), i would say yes, but i am a new user here ... for 2), yes, you can use fan as a porous jump to model flow through a grid ... but maybe not in 1.6 or 1.7 see http://www.cfd-online.com/Forums/openfoam/79757-fan-patch-acting-porous-jump.html I am actually looking at how to get an internal boundary from gambit mesh to get it in polymesh/boundary, in order to use cyclic BC, and i will try this "porous jump" Olivier |
September 14, 2010, 09:32 |
#19 |
maddalena
Rep Power: 23 |
Hello Olivier,
I noticed that post but none has replied yet. however, I always set the deltaP value positive or negative according to my mesh, and never had any problem in OF 1.6... Let me know how your test will go. Cheers, mad |
September 15, 2010, 07:14 |
#20 |
maddalena
Rep Power: 23 |
Hi everyone,
following the discussion of yesterday with Olivier and on the basis of some problems I have met, I played a bit with the tutorial fan case posted above. I studied the laminar case, to keep things simple. the solution is as in picture orig.png. First, I tried to invert the flow direction, i.e. instead of going from left to right, I wanted it to go from right to left. Thus, I exchanged the boundary conditions and changed sign (from positive to negative) to fan f coefficient. Results are shown in picture bc.png: the fan misbehaves. Another method of reversing the flow direction is to exchange boundary conditions and invert the order of the cyclic definition, using a positive f coefficient. Therefore, on a second set, I changed the master and slave face order on blockMeshDict: from: Code:
cyclic fan ( ( 1 2 6 5 ) //master ( 8 12 15 11 ) //slave ) Code:
cyclic fan ( ( 8 12 15 11 ) //master ( 1 2 6 5 )//slave ) Conclusion: on OF 1.6 and 1.7, the f coefficient must be positive, the flow direction is set by the master and slave face of the cyclic condition. Open point: can the fan BC be used to simulate local losses? What happens if the flow approaching the fan has a direction opposite to the supposed positive direction for the fan? mad Last edited by maddalena; September 15, 2010 at 08:23. |
CoupledFvScalarMatrix in OF15 | fisher | OpenFOAM Running, Solving & CFD | 9 | May 27, 2020 10:40 |
Forces in OF15 | richard | OpenFOAM Running, Solving & CFD | 180 | July 9, 2018 11:54 |
Bug in patchIntegrateC OF15 | anger | OpenFOAM Bugs | 8 | May 29, 2009 05:36 |
Is it a bug in Userbs Guide for OF15 | kai | OpenFOAM Bugs | 1 | October 2, 2008 09:07 |
Bug or a feature of OF15 | rafal | OpenFOAM Bugs | 5 | July 25, 2008 06:25 |
