Integrated conjugate heat transfer solver in OpenFOAM |
#161 | |
Rep Power: 14 ![]() |
Can you tell me how you solved the problem with the error: Unknown polyPatch type ? I tried to create my own boundary but blockMesh can't find the library i created with wmake libso. Thanks a lot |
#162 |
Rep Power: 15 ![]() |
Hi Mike
I could run the code in parallel with 2 processors in the x direction, but when I tried reconstructPar I got Reconstructing FV fields Reconstructing volScalarFields EP --> FOAM FATAL ERROR: request for polyMesh solid from objectRegistry liquidprocessor0 failed available objects of type polyMesh are 1 ( region0 ) From function objectRegistry::lookupObject<Type>(const word&) const in file /build/buildd/openfoam-1.6-ext-1.6.0/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140. FOAM aborting Aborted --------------------------------------------------------------------- I am really surprise that reconstrucPar looks for the directory liquidprocessor0 my main directory is liquid Any comments are welcome! |
#163 | |
Hi Aram
Did you solve your problem? Could you please tell what did you do? Thanks Alberto Quote:
#164 |
Aram Amouzandeh
Rep Power: 17 ![]() |
Hi!
I think this problem was solved with OF 1.6. Concerning your problem with reconstructPar, you can only reconstruct fields from specific regions, e.g. reconstructPar -region <regionName>. Hope that helps! Cheers, Aram |
#165 |
Hello Foamers
I am trying to use decomposePar for the geometry sketched below, fluid domain with a solid domain which length is a third of the liquid length, until now I can only run conjugateHeatFoam solver using 2 processor for the liquid and 2 for the solid (x-direction), is there a way to use at least 6 processors for the liquid and 2 for the solid (or more), I have found the instruction globalFaceZones ( nameofzone1 nameofzone2 ); but I do not know how it works or if it is useful for my problem, Using more than 2 processors I have observed that theres is not regioncouple between processor L0 and S0, how can I solve this issue? Please let me know your opinion about this problem Any help is welcome. Thanks in advance. Alberto |
#166 | |
A.R.Sangtabi
#167 | |
reza
thanks |
#168 |
Maosong Cheng
Hi FOAMer,
How to implement a steady conjugateHeatTransfer solver? |
#169 |
Rep Power: 0 ![]() |
Has anyone succeded building conjugateHeatFoam solver in OpenFoam other than 1.6-ext? |
#170 |
Hesam
Rep Power: 11 ![]() |
Hi Foamers,
How i can define temperature dependent diffusivity in fluid region in conjugateHeatFoam solver? for example DT=a+bT ??? ![]() |
#171 |
Hesam
In conjugateHeatFoam solver that released in OpenFoam 3.1 ext in polyMesh section there are bridge over lap and master,anybody know what do they mean??? another question is that how can i define a constant temperature piece that cooling down with a fluid? in 1.6 ext version with internalField i can do this but in 3.1 ext i can't!!! |
#172 |
Yağmur GÜLEÇ
Rep Power: 12 ![]() |
Dear Hrvoje Jasak,
It is a very good concept that I would like to use for multiphase flow. Thanks for the implementation. I tried to understand the boundary conditions chtTemperature and chtRcThermalDiffusivity in foam extended 4.1. The first boundary condition asks me diffusivity field other than remote field. The problem for multiphase flow is that conductivity of solid is diffusing which makes the diffused conductiivity in the liquid-gas mixture since they are coupled. I could not find the exact piece of code that makes this diffused conductivity(because of harmonic mean you implemented or from thermodynamic libraries?). I would like to keep the solid conductivity uniform everywhere. However as the liquid-gas interface moves, I would like to couple it with solid domain. Could you give me any idea? Thanks, Best Regards, |
#173 | |
Dibyendu Rana
Rep Power: 3 ![]() |
conjugate heat transfer | ajay chandra | FLUENT | 3 | October 26, 2010 17:14 |
heat transfer in conjugate heat problems | cirilo | Siemens | 1 | April 18, 2006 09:16 |
What's conjugate heat transfer? | Larva-nymph | Main CFD Forum | 7 | March 16, 2005 07:27 |
Conjugate Heat Transfer | A. Roy | Phoenics | 1 | June 26, 2002 18:35 |
Conjugate Heat Transfer | Thomas P. Abraham | Main CFD Forum | 11 | May 7, 1999 10:46 |
