February 19, 2009, 13:38 |
Hi Jianying and Ning,
I jus
#41 |
Cedric DUPRAT
Rep Power: 17 |
I just want to add that the reference DNS calculation we used to compare our calculation was done with a second order code (in both time and space). So if you use (real) second order scheme with an accurate mesh, there are no reason to get DNS data. You can check easily your mesh (close to the wall) but for the numerics .... I don't know. Cedric |
February 19, 2009, 17:53 |
Hi Cedric:
Obviously if you
#42 |
Ning Yang
Rep Power: 17 |
Hi Cedric:
Obviously if you refine the grid, you should be able to get better results. I compared my data with Moser's data, published in physics of fluids. I don't think they use a second-order code. Ning |
February 19, 2009, 17:54 |
Hi Cedric:
Obviously if you
#43 |
Ning Yang
Rep Power: 17 |
Hi Cedric:
Obviously if you refine the grid, you should be able to get better results. I compared my data with Moser's data, published in physics of fluids (1999). I don't think they use a second-order code. Ning |
February 19, 2009, 21:39 |
Hi Ning
I tried the one equat
#44 |
Jianying Jiao
Rep Power: 17 |
Hi Ning
I tried the one equation model, smagorinsky, and dynsmagorinsky, but above my results used the dynsmagorinsky model, not smagorinsky model. my results of dynsmagorinsky model is better than one equation model. my mesh is poorer than yours, but others are the same as yours. Hi Cedric My results isn't better than DNS data, I know my mesh is poor. If increasing mesh, the time of computation increases. If a third-order of the temporal discretization term is used, the time of computation is less than the time of computation of a second-order of the temporal discretization term and increasing mesh. gave me some advices. Jianying |
February 19, 2009, 21:57 |
Hi Ning
#45 |
Jianying Jiao
Rep Power: 17 |
Hi Ning
February 26, 2009, 21:45 |
Has anybody tried Re_tau = 180
#46 |
Sung-Eun Kim
Rep Power: 17 |
Has anybody tried Re_tau = 180?
February 26, 2009, 23:07 |
Just Curious... I'm a complete
#47 |
Santosh KC
Just Curious... I'm a complete newbie out here.. Is there any tutorial to get started with DNS/LES of Channel Flow?? What machines do you guys run your code on???
May 13, 2009, 01:49 |
#48 |
N/A
Rep Power: 17 |
I tried the Re_tau=180 case and it produced acceptable results. I did some analysis at Re_tau=395 using one eq eddy and dyn one eq model. The results obtained using the localized dynamic one equation model was much better than the one eq case with Van Driest damping on a 64 cube grid with 2pi*2*pi domain and the same numerical discretization as the tutorial. Has anyone tried using their own filter width expression instead of the smooth/cuberoolvol filter ? Also majority of the papers which i came across used higher order schemes with LES and that can be another reason for the problem.
May 27, 2009, 08:21 |
#49 | |
Sebastian Gatzka
Rep Power: 20 |
You say you are NOT using limitedLinear 1 for the two terms mentioned. Can you tell me which one you are using? Ore actually post your fvSchemes dictionary? I'm having some problem using oneEqEddy in a square duct LES. My results are poor and Smagorinsky is far better ... I don't think thats correct ... Have a nice day. Sebastian
Schrödingers wife: "What did you do to the cat? It's half dead!" |
May 29, 2009, 05:54 |
#50 |
Sebastian Gatzka
Rep Power: 20 |
Hello World.
As mentioned above I am doing the channel flow simulation in a square duct with cyclic bc's for in- and outflow. My Resolution is 56x56x70 with refined mesh towards the wall so there are 7 cells within y+ < 10. I'm using two different LES models, namely
I'm even experiencing that the velocity profile is not symmetric. Unfortunately the asymmetry looks to be getting worse when simulation longer and thus doing longer averaging. Important information on how these plots are obtained: I'm using my own post-processing tool for averaging in the flow-direction (with MATLAB). I'm not primary doubting my own tool, but is there an OpenFOAM tool for post-processing a square duct channel? Any ideas why the One Equation model is so bad compared to both DNS and Smagorinsky? Well, I expected vice versa.
May 31, 2009, 13:48 |
#51 | |
Sebastian Gatzka
Rep Power: 20 |
Is this the averaged pressure gradient at the end of the simulation?
June 3, 2009, 09:20 |
#53 |
Sebastian Gatzka
Rep Power: 20 |
Which is written in the last uniform sub-directory of the last time-step?
Just to make sure ...
June 3, 2009, 10:03 |
#55 |
Sebastian Gatzka
Rep Power: 20 |
I think you have read my previous posts and know I'm having some difficulties with my LES simulations. Just to make sure I'm not getting something wrong on the way (for example how and where to read gradP to get utau) I'm just asking.
June 3, 2009, 10:16 |
#56 |
Daniel WEI (老魏)
Rep Power: 21 |
Am I missing something??? As I remember, I have never used gradP to get U_tau.
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
June 3, 2009, 10:25 |
#57 | |
Sebastian Gatzka
Rep Power: 20 |
utau = sqrt( -D/(4*rho) * gradP ) with D beeing the diameter of the Duct.
June 3, 2009, 10:41 |
#58 |
Daniel WEI (老魏)
Rep Power: 21 |
I see. ......
I calculate u_taw from a wallShearStress utility, of cause in an averaging sense. ^^^^^^^^^ I guess they are the same, since the essence are the same, right?
June 3, 2009, 11:14 |
#59 |
Sebastian Gatzka
Rep Power: 20 |
I hope so ...
June 16, 2009, 04:26 |
#60 |
Daniel WEI (老魏)
Rep Power: 21 |
Hi, can anyone tell me how did you get the U+ versus y+ data?
My results is wrong, so I lost my idea about the procedure... 1. Get wall shear stress Code:
wallShearStress.boundaryField()[patchi] = sqrt ( nuEff.boundaryField()[patchi] *mag(U.boundaryField()[patchi].snGrad()) ); Code:
uTau= Foam::sqrt(wSS); Code:
scalarField UMeanXPValues = UMeanXvalues/uTau; makeGraph(y*uTau/nuTmp, UMeanXPValues, "UP", UMean.path(), gFormat);
Pressure inlet boundary conditions for open channel flows | jack2000 | OpenFOAM Running, Solving & CFD | 5 | December 6, 2018 12:00 |
LES In Turbulent in channel flow | pankaj saha | Main CFD Forum | 18 | November 20, 2014 06:49 |
LES In Turbulent in channel flow | pankaj saha | Main CFD Forum | 8 | April 15, 2009 12:34 |
Turbulent channel flow | roberthino | OpenFOAM Running, Solving & CFD | 5 | August 15, 2007 09:35 |
Bc for turbulent channel flow | roberthino | OpenFOAM Running, Solving & CFD | 0 | August 13, 2007 09:12 |
