TurbFoam on snappyHexMeshGrid
Old   February 27, 2009, 10:56
Default Hi, I'm trying to run a aer
Christoph Scheit
chris_scheit is on a distinguished road
I'm trying to run a aerodynamic simulation using a model of a real car. I generate the mesh using snappyHexMesh, but while for a very coarse refinment
everything works, using a finer refinment level snappyHexMesh starts to mesh also inside. Since I have several STL-files, I also can not repair the mesh using admesh.
No I tried to run the simulation anyway, imagining that it will work but just generate "to much" elements (also inside the car). But when I run the problem using turbFoam it does not converge. The residual for the velocity are going up. I'm using a velocity field initialized with potentialFoam which still worked.
1) Is it a serious problem, that also inside the car a mesh is generated (except overhead)
2) If not, what to do in order to reach convergence?
PS: I'm using k-eps-modell with wall function, the Reynolds-Number is about 1 000 000 (rough guess)
Thanks in advance,
Christoph
chris_scheit is offline   Reply With Quote
Old   February 27, 2009, 11:31
Default Hi Christoph, it seems like
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Hi Christoph,
it seems like you have at least one gap between your different stl-files. Thats why your real car gets also meshed on the inside. - Try to avoid that!
I don't think it makes any sense to start a turbFoam computation as long as you don't have a suitable mesh. What my experience told me is that turbFoam is really dependent on mesh quality!
regards,
Andreas
lord_kossity is offline   Reply With Quote
HELP NEEDED with TURBFOAM dinonettis OpenFOAM Running, Solving & CFD 64 June 22, 2010 10:58
Problem with turbFoam skabilan OpenFOAM Running, Solving & CFD 2 September 29, 2008 18:43
Turbfoam error danie OpenFOAM Running, Solving & CFD 2 July 30, 2008 08:45
TurbFoam hsieh OpenFOAM Running, Solving & CFD 12 July 23, 2008 08:40
Some hints with turbFoam giampippetto OpenFOAM Running, Solving & CFD 0 March 9, 2006 03:21
