July 26, 2010, 10:30 |
#81 |
Emanuele
Rep Power: 17 |
The results are the same with buoyantPressure on the faces parallel to z axis (the same axis where g is defined)
July 29, 2010, 12:52 |
Floating point exception : first order wave
#82 |
Emanuele
Rep Power: 17 |
I have corrected the boundary condition according to generate a 1st order wave but i obtain a floating point exception
This is the case http://dl.dropbox.com/u/3617688/groo...Version.tar.gz SOLVED: it was a bad BC on U on atmosphere patch Last edited by nuovodna; July 29, 2010 at 15:55. Reason: problem solved |
August 17, 2010, 04:29 |
#83 |
yannH
Rep Power: 16 |
Hi nuovodna,
The link seems to be broken, can you re-post it please? best regards, Yann |
August 17, 2010, 06:37 |
fixed link
#84 |
Emanuele
Rep Power: 17 |
April 24, 2011, 11:54 |
#85 | |
binu kumar
Rep Power: 16 |
i have also run same case as yours, but unable to run it. can you help in this problem |
October 22, 2012, 10:23 |
#86 |
pedro gonzalez
Rep Power: 16 |
Any help would be appreciated:
I am using FLUENT to model a regular wave tank with linear theory and dynamic mesh. I am using a VOF multiphase model (water and air), with transitory regime. The length of the water tank is 200m, from th mobile wall, with 16 m depth. I want to measure the magnitude (amplitude) of the wave at at position x = 20 m from the mobile wall, through of the time, in the free surface (depth= 0m), . How to measure the magnitude (amplitude) in that distance?. |
October 22, 2012, 10:42 |
#87 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Pedro,
You have stumbled into the OpenFoam part of the forum, so I guess that we might not be able to helping you. You will probably get at lot more help, if you pose the same question in an appropriate thread. Kind regards, Niels |
October 22, 2012, 13:08 |
#88 |
pedro gonzalez
Rep Power: 16 |
Hi Niels
I have tried in several threads and I posted here too because It`s a topic related. Best regards, Pedro |
November 28, 2012, 15:57 |
#89 |
Sagun Tripathi
Rep Power: 14 |
Hello Eugene,
On a completely unrelated note, could you tell me how you have embedded those files in one of your first posts on this forum? Thanks, Sagun |
wavetank |
Help! Compiled UDF problem 4 Wave tank tutorial | Shane | FLUENT | 1 | September 3, 2010 03:32 |
Numerical wave tank | michaelp | OpenFOAM Installation | 1 | December 17, 2008 09:27 |
Numerical wave tank | Bridget | FLUENT | 0 | March 27, 2006 17:09 |
Sea Waves/Wave tank | Phil | FLUENT | 3 | October 9, 2003 07:55 |
Virtual wave tank | Murali.K | Main CFD Forum | 1 | March 17, 1999 03:18 |
