April 20, 2007, 12:04 |
http://www.cfd-online.com/Open
#21 |
Hrvoje Jasak
Rep Power: 33 |
What you are looking at is a 2-zone FVM flow solver, a FEM mesh motion solver and a finite area solver doing the surfactant transport. All with mesh motion, coupling etc (running in parallel!) - I still find it amazing.
This will all get merged with the new stuff that came out as 1.4 (in any case, this is just a part of the additions accumulated from 1.3). If you want to run it right now, just use the 1.3 I've pointed to; otherwise, give me some time and I'll announce the merge when I'm happy it is running correctly. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
April 23, 2007, 11:39 |
I'm having some trouble gettin
#22 |
Kester Gunn
Rep Power: 17 |
I'm having some trouble getting the interTrackFoam to run. I get the error "getApplication::Invalid application class name 'interTrackFoam'.". I assume something needs compiling. Any suggestions??
May 9, 2007, 10:04 |
I recently got back to this pr
#23 |
I recently got back to this problem, and was able to get Eugene's boundary conditions (surfaceWavePhase and surfaceWaveVelocity) working for a simple "wave-in-Box" test case.
I put both in OpenFOAM-1.3/src/finiteVolume/fields/fvPatchFields/derivedFvPatchFields and recompiled the finiteVolume library. After the fact, I realized that I probably should have done this using the foamUser lib. Anyway, I am able to access the b.c.'s when running interFoam, but now all of the post-processing tools are broken, for example, I get the following error when running foamToEnsight, --> FOAM FATAL ERROR : request for dictionary environmentalProperties from objectRegistry region0 failed available objects of type dictionary are 2 ( fvSolution fvSchemes ) From function objectRegistry::lookupObject<type>(const word&) const in file /home/egp11/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/objectRegistryTemplates .C at line 122. Given that I put these routines in the finiteVolume lib, does anyone have a suggestion how to fix the post-processing tools so that they recognize the output files? I should note that I can edit the gamma and U output files (change the type to fixedValue and delete depth, etc.) to make them readable by the tools, however, this is not a good solution! |
May 9, 2007, 14:26 |
Ok, the problem here is that I
#24 |
Eugene de Villiers
Rep Power: 21 |
Ok, the problem here is that I put the wind speed, ocean depth etc. in the environmentalProperties dictionary and then assumed (incorrectly) that any code which uses these boundaries would have this dictionary loaded into the objectRegistry.
What you have to do to make it work with post-processors and other utilities is to find the line in the boundary condition which is used to lookup the environmentalProperties dictionary in the object registry. Now modify it to check whether the environmentalProperties dictionary is available in the object registry. If its available, use it, if not, read it from file. |
May 18, 2007, 07:50 |
Eugene,
Can you be more exp
#25 |
Eugene,
Can you be more explicit on how to "check whether the environmentalProperties dictionary is available in the object registry. If its available, use it, if not, read it from file"? I looked for an example elsewhere (e.g. wallBuoyantPressure), but I couldn't find anything. Good news is that I my wave model is working. The reflection of waves at the outflow boundary is an issue, but fixable. |
May 18, 2007, 09:01 |
Nice pictures.
Re the envir
#26 |
Eugene de Villiers
Rep Power: 21 |
Nice pictures.
Re the environmental properties thing. Check the first entry in the main constructor for surfaceWaveVelocityFvPatchVectorField (line 157 in my copy). It is looking up the environmentalProperties dictionary from the database. Instead of "lookupObject", you can use "foundObject" to check whether "environmentalProperties" exists. If the environmentalProperties object doesn't exist, you will have to read it from file just like the top level code of interFoam does. Good luck with the wave outlets. If you get it working, I wouldn't mind a peek. |
November 1, 2007, 21:12 |
try InInclude -> lnInclude, wh
#27 |
Richard Kenny
Rep Power: 18 |
try InInclude -> lnInclude, where the first letter is a small "L".
Good luck, RGK. |
November 4, 2007, 22:29 |
Thank you very much Richa
#28 |
Christopher Cooper
Rep Power: 17 |
Thank you very much Richard, kind of a basic problem, but I'm just beginning in this. However I'm still having problems, when I compile, this error message comes out: surfaceWavePhasePatchScalarField.C:37: error: no match for 'operator+' in 'Foam::fvPatch::Cf() const() + Foam::operator*(const Foam::VectorSpace<form,>&, const Foam::dimensioned<type>&) [with Type = double, Form = Foam::Vector<double>, Cmpt = double, int nCmpt = 3](((const Foam::dimensioned<double>&)(&((const Foam::Time*)((const Foam::objectRegistry*)((Foam::surfaceWavePhaseFvPa tchScalarField*)this)->Foam::s urfaceWavePhaseFvPatchScalarField::<anonymous>.Foa m::mixedFvPatchField<double>:: <anonymous>.Foam::fvPatchField<type>::db [with Type = double]())->Foam::objectRegistry::time())->Foam::Time::<anonymous>.Foam::TimeSta te::<anonymous>)))' /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/dimensionedScalar.H:53 : note: candidates are: Foam::dimensionedScalar Foam::operator+(Foam::scalar, const Foam::dimensionedScalar&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/dimensionedScalar.H:52 : note: Foam::dimensionedScalar Foam::operator+(const Foam::dimensionedScalar&, Foam::scalar) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/labelField.H:52: note: Foam::tmp<foam::field<int> > Foam::operator+(const Foam::tmp<foam::field<int> >&, const Foam::label&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/labelField.H:52: note: Foam::tmp<foam::field<int> > Foam::operator+(const Foam::UList<int>&, const Foam::label&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/labelField.H:52: note: Foam::tmp<foam::field<int> > Foam::operator+(const Foam::label&, const Foam::tmp<foam::field<int> >&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/labelField.H:52: note: Foam::tmp<foam::field<int> > Foam::operator+(const Foam::label&, const Foam::UList<int>&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/dictionary.H:219: note: Foam::dictionary Foam::operator+(const Foam::dictionary&, const Foam::dictionary&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/scalarField.H:73: note: Foam::tmp<foam::field<double> > Foam::operator+(const Foam::tmp<foam::field<double> >&, const Foam::scalar&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/scalarField.H:73: note: Foam::tmp<foam::field<double> > Foam::operator+(const Foam::UList<double>&, const Foam::scalar&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/scalarField.H:73: note: Foam::tmp<foam::field<double> > Foam::operator+(const Foam::scalar&, const Foam::tmp<foam::field<double> >&) /home/cooper/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/scalarField.H:73: note: Foam::tmp<foam::field<double> > Foam::operator+(const Foam::scalar&, const Foam::UList<double>&) surfaceWavePhasePatchScalarField.C:39: error: '((Foam::surfaceWavePhaseFvPatchScalarField*)this)->Foam::fvPatchField<type>:: patch [with Type = double]' does not have class type surfaceWavePhasePatchScalarField.C:53: error: cannot convert 'Foam::dimensionedScalar' to 'double' for argument '1' to 'double sin(double)' surfaceWavePhasePatchScalarField.C: In constructor 'Foam::surfaceWavePhaseFvPatchScalarField::surface WavePhaseFvPatchScalarField( const Foam::fvPatch&, const Foam::Field<double>&)': surfaceWavePhasePatchScalarField.C:82: error: 'Type' was not declared in this scope Does this mean that I have to change something in surfaceWavePhasePatchScalarField.C?, or something is missing? Many thanks in advance. Best regards, Christopher |
November 5, 2007, 00:28 |
Looks like you've got a probl
#29 |
Richard Kenny
Rep Power: 18 |
Looks like you've got a problem of mismatched types at lines 37 and 53.
For lines 39 and 82: I suspect there's a missing ";" or some such before "Type". RGK |
November 23, 2007, 19:43 |
Hi, I've checked the programmi
#30 |
Christopher Cooper
Rep Power: 17 |
Hi, I've checked the programming, and it seems to be fine, so I'm guessing it might be a compiler problem. With what compiler were those compiled? 1.3.3 is the version of FOAM which has the compiler that was used? I'm using gcc-4.1.0, could this be the problem?
Thank you very much in advance Christopher |
November 26, 2007, 23:57 |
I see what you mean. I can get
#31 |
Richard Kenny
Rep Power: 18 |
I see what you mean. I can get rid of some of the errors (under OpenFoam 1.3 using gcc 4.0.1 on a Mac!)
but, really, these files should probably be embedded in an analogous structure to the "finiteVolume library" as suggested above by Eric i.e. "I put both in OpenFOAM-1.3/src/finiteVolume/fields/fvPatchFields/derivedFvPatchFields and recompiled the finiteVolume library. After the fact, I realized that I probably should have done this using the foamUser lib. " You could try something somewhat leaner. 1) copy&rename the whole finiteVolume directory to your apps folder (WM_PROJECT_USER_DIR/applications/myFiniteVolume) and include your new bdy condition as directed above. 2) throw out the many files you won't be using (cf. src/finiteVolume/Make/files) and then compile to LIB = $(FOAM_USER_LIBBIN)/libmyFiniteVolume. Assuming you have the patience. Good luck, RGK |
December 15, 2007, 17:08 |
#32 |
Christopher Cooper
Rep Power: 17 |
Thank you very much Richard, I'm really sorry for my delayed answer, but I've been really occupied and trying to figure it out on my own, but I haven't been able. I tried to do exactly what Eric did, and I still had the same problems. In fact, I tried to compile the surfaceWaveVelocity BC, and this appear in the end: surfaceWaveVelocityFvPatchVectorField.C.gnu.linkonce.t._ZNK4Foam17mixedFvPatchFieldINS_6V ectorIdEEE6snGradEv+0x6a): undefined reference to `Foam::fvPatch::deltaCoeffs() const' collect2: ld returned 1 exit status make: *** [OpenFOAM.out] Error 1 Which makes me more suspicious that its a compiler problem. I hope to hear from you soon. Thank you very much Best regards Christopher |
December 16, 2007, 04:18 |
did you try the above library
#33 |
Richard Kenny
Rep Power: 18 |
did you try the above library structure I wonder?
linker errors (collect2: ld ....) tend to occur (from what I've experienced with turbulence and thermophysical libraries) in the final step of compilation when the top-level solver is bound to the relevant libraries and binaries of any classes. For some reason the final step of this compilation process can't 'see' some of the constructors of classes which by themselves compile fine. The idea seems to be then to pack in as many related classes as possible into a library and hope it links correctly to the solver in the final compilation step. If you follow the OpenFoam library structure it should work. I'll have a go myself to see if it's as 'easy' in this case as I've made out (!) It worked (after some pain) with the thermo libraries, and also the turbulence-related ones too. I presume you want to bind in the lot to interFoam. Hopefully I'll be able to get back to you later this week. Richard |
December 24, 2007, 03:15 |
Hello,all.
I am new to OpenFO
#34 |
Bowlderster
Rep Power: 17 |
Hello,all.
I am new to OpenFOAM, and I want to set up a numerical wave tank by the interFoam solver. The first question appeared is that how the set the wave maker BC.Based on the wave theory, the U verying with time should be used as the wave maker BC. I know there is a kind of BC timeVaryingUniformFixedValue. Is it okay for the wave maker BC? Or which tutorial introducts this kind of BC? Thank you for your help. Regards. |
January 1, 2008, 14:25 |
Christopher, sorry, it took a
#35 |
Richard Kenny
Rep Power: 18 |
Christopher, sorry, it took a week longer to get around to doing this.
I followed my prescription above and indeed it does work out. In fact, I should've been bolder in throwing out many more items from "myfiniteVolume" but was a bit pressed for time to check on the many possibilities. If you like, you can have the solver+lib (compressed to 16M) which compile using OF 1.3. Richard K. |
February 7, 2008, 21:13 |
Hi, all of you,
I want to m
#36 |
xiuying
Rep Power: 17 |
Hi, all of you,
I want to model a wave tank, just like in the above case. I downloaded the bc's from this forum 'surfaceWavePhase' and 'surfaceWaveVelocity', but I'm having problems compiling them as follows. Could you inform me how to deal with this problem? Thank you so much. Regards, Xiuying [xiuying@kiwi ~]$ cd /share/kiwiraid/xiuying/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume [xiuying@kiwi finiteVolume]$ wmake SOURCE=fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScal arField.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/share/kiwiraid/xiuying/OpenFOAM/OpenFOAM-1.4.1/src/triSurface/lnInclude -I/share/kiwiraid/xiuying/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/share/kiwiraid/xiuying/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/surfaceWavePhaseFvPatchScalarField.o fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C: In member function 'void Foam::surfaceWavePhaseFvPatchScalarField::extrapol ateGradient()': fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:87: error: 'lookupPatchField' was not declared in this scope fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:87: error: expected primary-expression before ',' token fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:87: error: expected initializer before '>' token fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C: In constructor 'Foam::surfaceWavePhaseFvPatchScalarField::surface WavePhaseFvPatchScalarField(co nst Foam::fvPatch&, const Foam::Field<double>&)': fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:113: error: no matching function for call to 'Foam::mixedFvPatchField<double>::mixedFvPatchFiel d(const Foam::fvPatch&, const Foam::Field<double>&)' lnInclude/mixedFvPatchField.C:101: note: candidates are: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::DimensionedField<type,>&) [with Type = double] lnInclude/mixedFvPatchField.C:87: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&) [with Type = double] lnInclude/mixedFvPatchField.C:57: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::fvPatchFieldMapper&) [with Type = double] lnInclude/mixedFvPatchField.C:72: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::dictionary&) [with Type = double] lnInclude/mixedFvPatchField.C:41: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&) [with Type = double] fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C: In constructor 'Foam::surfaceWavePhaseFvPatchScalarField::surface WavePhaseFvPatchScalarField(co nst Foam::surfaceWavePhaseFvPatchScalarField&, const Foam::fvPatch&, const Foam::Field<double>&, const Foam::fvPatchFieldMapper&)': fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:138: error: no matching function for call to 'Foam::mixedFvPatchField<double>::mixedFvPatchFiel d(const Foam::surfaceWavePhaseFvPatchScalarField&, const Foam::fvPatch&, const Foam::Field<double>&, const Foam::fvPatchFieldMapper&)' lnInclude/mixedFvPatchField.C:101: note: candidates are: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::DimensionedField<type,>&) [with Type = double] lnInclude/mixedFvPatchField.C:87: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&) [with Type = double] lnInclude/mixedFvPatchField.C:57: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::fvPatchFieldMapper&) [with Type = double] lnInclude/mixedFvPatchField.C:72: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::dictionary&) [with Type = double] lnInclude/mixedFvPatchField.C:41: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&) [with Type = double] fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C: In constructor 'Foam::surfaceWavePhaseFvPatchScalarField::surface WavePhaseFvPatchScalarField(co nst Foam::fvPatch&, const Foam::Field<double>&, const Foam::dictionary&)': fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:158: error: no matching function for call to 'Foam::mixedFvPatchField<double>::mixedFvPatchFiel d(const Foam::fvPatch&, const Foam::Field<double>&)' lnInclude/mixedFvPatchField.C:101: note: candidates are: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::DimensionedField<type,>&) [with Type = double] lnInclude/mixedFvPatchField.C:87: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&) [with Type = double] lnInclude/mixedFvPatchField.C:57: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::fvPatchFieldMapper&) [with Type = double] lnInclude/mixedFvPatchField.C:72: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::dictionary&) [with Type = double] lnInclude/mixedFvPatchField.C:41: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&) [with Type = double] fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C: In constructor 'Foam::surfaceWavePhaseFvPatchScalarField::surface WavePhaseFvPatchScalarField(co nst Foam::surfaceWavePhaseFvPatchScalarField&, const Foam::Field<double>&)': fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:274: error: no matching function for call to 'Foam::mixedFvPatchField<double>::mixedFvPatchFiel d(const Foam::surfaceWavePhaseFvPatchScalarField&, const Foam::Field<double>&)' lnInclude/mixedFvPatchField.C:101: note: candidates are: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::DimensionedField<type,>&) [with Type = double] lnInclude/mixedFvPatchField.C:87: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&) [with Type = double] lnInclude/mixedFvPatchField.C:57: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::mixedFvPatchField<type>&, const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::fvPatchFieldMapper&) [with Type = double] lnInclude/mixedFvPatchField.C:72: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::dictionary&) [with Type = double] lnInclude/mixedFvPatchField.C:41: note: Foam::mixedFvPatchField<type>::mixedFvPatchField(c onst Foam::fvPatch&, const Foam::DimensionedField<type,>&) [with Type = double] fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C: In member function 'virtual void Foam::surfaceWavePhaseFvPatchScalarField::updateCo effs()': fields/fvPatchFields/derived/surfaceWavePhase/surfaceWavePhaseFvPatchScalarField .C:288: error: 'class Foam::surfaceWavePhaseFvPatchScalarField' has no member named 'lookupPatchField' make: *** [Make/linux64GccDPOpt/surfaceWavePhaseFvPatchScalarField.o] Error 1 [xiuying@kiwi finiteVolume]$ |
March 17, 2008, 15:30 |
Dear all,
I am trying to make
#37 |
Luca Liberti
Rep Power: 17 |
Dear all,
I am trying to make a wave flume simulation myself but I am mainly interested in solitary waves. Basically I need a moving mesh on one side of the flume where I can specify the motion of a piston providing its displacements in time. I have only been playing with OF and interFoam for a while and I found very difficult to get started with moving meshes (no changes in topology are required in my case) My questions are: 1) Is it possible to run interFoam with moving meshes (I suspect it is since there is a dynamicMeshDict in the interFoam tutorial folder) ? 2) Is it possible to specify a moving wall as a boundary and have its positions in time be read from an external file ? 3)Is there a reference material on moving meshes (i.e. a list of the mesh generation algorithms with their options) ? 4) Has anyone done a similar case? I would really appreciate any kind of help in the matter. Actually, if I ever figure out how this can work I am planning to write a basic tutorial. Thank you |
March 17, 2008, 15:53 |
Yeah, I have done lots of thos
#38 |
Hrvoje Jasak
Rep Power: 33 |
March 17, 2008, 17:07 |
Hi Luca and everyone else
S
#39 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Sounds very interesting! Should you by any chance be modeling tsunamis!?! Well, what is the reasoning behind wanting a moving boundary? Wouldn't that give much more computational time to overcome compared to a 'constant in time mesh'? From solitary theory you would know velocities, pressure gradient and surface elevation at a certain location. Thus it should be easily implemented in a stationary boundary approach (just doing a little advertising for my reasonly uploaded BC ... see: http://www.cfd-online.com/OpenFOAM_D...tml?1205695477) Actually I would very much like to hear what people have to say on the moving mesh vs. stationary approach. What are the benefits you are not getting from the stationary approach but is obtained in the moving mesh approach? Certainly if you are studying the paddle movement and shape to calculate how to evaluate certain wave types in a laboratory flume, then a moving mesh seems to be a proper way to go, but otherwise? Best regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
March 17, 2008, 17:34 |
Btw: Spectacular movie, Hrv!
#40 |
Rep Power: 37 |
/ Niels
wavetank |
Help! Compiled UDF problem 4 Wave tank tutorial | Shane | FLUENT | 1 | September 3, 2010 03:32 |
Numerical wave tank | michaelp | OpenFOAM Installation | 1 | December 17, 2008 09:27 |
Numerical wave tank | Bridget | FLUENT | 0 | March 27, 2006 17:09 |
Sea Waves/Wave tank | Phil | FLUENT | 3 | October 9, 2003 07:55 |
Virtual wave tank | Murali.K | Main CFD Forum | 1 | March 17, 1999 03:18 |
