How to output the process of the calculation
Old   February 8, 2009, 01:08
Default hi, i finish the calculation
weihong yao
ivanyao is on a distinguished road
hi,
i finish the calculation of my case(i can see the process of calculation in the terminal window),now i have to output all the time-steps of the calculation.
what can i do?
ivanyao is offline   Reply With Quote
Old   February 8, 2009, 04:09
Default If you are using OpenFOAM-1.5
vof_user
asaha is on a distinguished road
You can execute inside your case dir
foamJob icoFoam
The solver runs in background with the log file generated in your case dir.
Hope this helps.
asaha is offline   Reply With Quote
Old   February 8, 2009, 06:16
Default You can also use a command lin
Jesse
bigcarrot23 is on a distinguished road
You can also use a command line as follows:
icoFoam > log
and then use
tail -f log
to have a look in real-time
bigcarrot23 is offline   Reply With Quote
Old   February 9, 2009, 03:05
Default hi, thank you very much.i wil
weihong yao
hi,
thank you very much.i will have a try!
Old   February 12, 2009, 03:17
Default hi, i can not output the pr
weihong yao
hi,
i can not output the process of the calculation.i am use OF1.4.1.is there another way to solve problem?
Old   February 12, 2009, 07:13
Default hi, what exactly do you wan
Wolfgang Heydlauff
wolle1982 will become famous soon enough
hi,
what exactly do you want to output? in realtime or in a log file.
if you have written to a logfile (icoFoam >log) you can afterwards extract the log-file date with the command foamLog [logfilename]
if you mean the residuals or the convergency of the calculation i use the "forces" tool (see other thread) and let the file plot in gnuplot. there you can easily see in realtime how convergent your calculation is. for this, it doesn't matter wheather you're interested in the forces afterwards or not.
wolle1982 is offline   Reply With Quote
Old   February 13, 2009, 00:15
Default hi, i want to output the resi
weihong yao
hi,
i want to output the residuals or the convergency of the calculation.but i can not fix it from your advice.could you describe in detail?
thank you very much!
Old   February 16, 2009, 04:17
Default hi, i see. since your using
Wolfgang Heydlauff
hi,
i see. since your using OF 1.4.1 you'll have to use the liftdragTool (see other thread) cause there is no forces-function in OF 1.4.1 yet.
Old   March 2, 2009, 04:00
Default hi Wolfgang Heydlauff sir i
NAVEEN.K.M
naveen is on a distinguished road
i am solving NACA 0012 Airfoil case in simple foam solver....can anybody tell me how wil u know that the solution is converged or not..
naveen is offline   Reply With Quote
Old   March 2, 2009, 04:47
Default output the forces of a patch w
Wolfgang Heydlauff
output the forces of a patch with forces-function (search forum) and plot with gnuplot "on-the-fly". if forces don't change, solution is converged.
don't call me "sir" again..!
Old   March 2, 2009, 06:46
Default hi I AM USING OPENFOAM 1.4
  #11
NAVEEN.K.M
hi
I AM USING OPENFOAM 1.4.1...
can "output control " output Nu in expression? prayskyer CFX 3 July 7, 2006 20:37
Easy way for a last output at the end of an calculation andimb OpenFOAM 1 April 28, 2006 05:21
calculation process problem with CFD Hellen Main CFD Forum 2 May 27, 2005 05:06
the process of CFX beginer CFX 2 November 7, 2001 11:39
Time Taken for the Whole CFD Process David Main CFD Forum 1 March 20, 2000 17:47
