FoamerrorprintStackFoam%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartproud gif%22 ALT%3d%22O%22 BORDER%3d0%3estreamamp |
October 30, 2007, 05:33 |
Hi everybody
I've got an e
Hi everybody
I've got an error,can somebody help me? /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : simpleFoam /home/gui/ essai2 Date : Oct 30 2007 Time : 11:24:50 Host : gui-desktop PID : 9927 Root : /home/gui/ Case : essai2 Nprocs : 1 Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon Starting time loop Time = 0.1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.027748, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0273727, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.027986, No Iterations 2 #0 Foam::error::printStack(Foam:stream&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 void Foam::fvc::surfaceIntegrate<double>(Foam::Field<do uble>&, Foam::GeometricField<double,> const&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #4 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::surfaceIntegrate<double>(Foam::Geometri cField<double,> const&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #5 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::div<double>(Foam::GeometricField<double ,> const&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #6 Foam::fv::gaussLaplacianScheme<double>::fvmLaplaci an(Foam::GeometricField<double ,> const&, Foam::GeometricField<double,>&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #7 Foam::fv::laplacianScheme<double>::fvmLaplacian(Fo am::GeometricField<double,> const&, Foam::GeometricField<double,>&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #8 Foam::tmp<foam::fvmatrix<double> > Foam::fvm::laplacian<double>(Foam::GeometricField< double,> const&, Foam::GeometricField<double,>&, Foam::word const&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #9 Foam::tmp<foam::fvmatrix<double> > Foam::fvm::laplacian<double>(Foam::GeometricField< double,> const&, Foam::GeometricField<double,>&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #10 Foam::tmp<foam::fvmatrix<double> > Foam::fvm::laplacian<double>(Foam::tmp<foam::geome tricfield<double,> > const&, Foam::GeometricField<double,>&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #11 main in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #12 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #13 Foam::regIOobject::readIfModified() in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" Exception en point flottant (core dumped) Best regards |
October 30, 2007, 09:21 |
i have change the pressure and
i have change the pressure and now i 've got
Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon Starting time loop Time = 0.1 GAMG: Solving for Ux, Initial residual = 1, Final residual = 0.025826, No Iterations 1 GAMG: Solving for Uy, Initial residual = 1, Final residual = 0.0253025, No Iterations 1 GAMG: Solving for Uz, Initial residual = 1, Final residual = 0.0478088, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0498682, No Iterations 3 time step continuity errors : sum local = 3.8636, global = 1.01475, cumulative = 1.01475 #0 Foam::error::printStack(Foam:stream&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccSPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccSPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::tmp<foam::geometricfield<float,> > Foam::magSqr<foam::symmtensor<float>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<foam::geometricfield<foam ::symmtensor<float>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccSPOpt/libincompressibleTurbulence Models.so" #4 Foam::turbulenceModels::kEpsilon::correct() in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccSPOpt/libincompressibleTurbulence Models.so" #5 main in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccSPOpt/simpleFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 Foam::regIOobject::readIfModified() in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccSPOpt/simpleFoam" Exception en point flottant (core dumped) somebody can help me? regards |
October 30, 2007, 09:48 |
You have messed up your bounda
Hrvoje Jasak
Rep Power: 33 |
You have messed up your boundary conditions on the pressure and ve;ocity and the solver is blowing up on you. If you specify p on the boundary, you cannot specify U.
Just to make sure, run checkMesh on your case - if this does not report any errors, you need to look into 0/p and 0/U - that's where the problem is. A bit unusual choice of momentum solver - why? Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 13, 2009, 13:44 |
Hi there
I got the same err
Ali Mansouri
Rep Power: 17 |
Hi there
I got the same error, I am ruuning simpleFoam and I checked most of the points mentioned on the board but still I get the following...pls help. /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : simpleFoam /home/openfoam2/OpenFOAM/openfoam2-1.4.1/run/tutorials/simpleFoam elbow Date : Jan 13 2009 Time : 11:42:37 Host : spidy3123.cluster.novachem.com PID : 17477 Root : /home/openfoam2/OpenFOAM/openfoam2-1.4.1/run/tutorials/simpleFoam Case : elbow Nprocs : 1 Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 0.11164, Final residual = 0.00421292, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 0.0522537, Final residual = 0.000490851, No Iterations 3 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00992171, No Iterations 63 time step continuity errors : sum local = 0.0017069, global = -2.55781e-05, cumulative = -2.55781e-05 #0 Foam::error::printStack(Foam:stream&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 __restore in "/lib/tls/libpthread.so.0" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbulenc eModels.so" #5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::GeometricField<double,> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbulenc eModels.so" #6 Foam::turbulenceModels::kEpsilon::correct() in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbulenc eModels.so" #7 main in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #8 __libc_start_main in "/lib/tls/libc.so.6" #9 Foam::regIOobject::readIfModified() in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" |
January 13, 2009, 17:39 |
I'm betting on the old "k or e
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I'm betting on the old "k or epsilon is 0 (either internally or on some patch)"-bug
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 3, 2009, 10:19 |
I am new to OpenFoam
I am new to OpenFoam and am trying to test run a working solver for a new blockMeshdict file. I am learning as fast as possible to make my way around openFoam, but not sure where to go for debug help so specific. Any advice would be appreciated. --Lori -----------------------message----- DILUPBiCG: Solving for StressTensor_2zz, Initial residual = 0, Final residual = 0, No Iterations 0 #0 Foam::error::printStack(Foam:stream&) in "/home/pec/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/pec/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7fe0400] #3 main in "/home/pec/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/laminarPTTMultim od" #4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #5 _start in "/home/pec/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/laminarPTTMultim od" Segmentation fault |
