General help for fvSchemes and fvSolution settings
Old   March 3, 2009, 20:16
Default Hi, I am playing around wit
Daniel Harlacher
harly is on a distinguished road
I am playing around with OpenFoam for quite a while now but I still have my problems when it comes to choosing the "order" and "schemes" for those files.
In general I understand what every entry does and what the influence should be - but lately I ran in trouble with a perfectly working set of files and I could not figure out why.
My question would be if you have any general tips you can give me or even just paste a fvSchemes file you are using.
Right know I try to get a very good result for the drag of a sphere in low Re number area (50 - 200) so far I am using IcoFoam, but I am open for any suggestion to improve my current results.
My current fvSchemes:
http://harly.de.vu/www/sphere/fvSchemes
My current fvSolutions:
http://harly.de.vu/www/sphere/fvSolution
These files worked great for me for Re=200 and Re=150, but on the same mesh and lower Re (50,100) the Drag is too high.
Thanks a lot
- harly
harly is offline   Reply With Quote
Old   March 4, 2009, 10:41
Default Hi Daniel, I would use back
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Hi Daniel,
I would use backward or CrankNicholson for ddt, limitedLinearV for convection, and I would tighten the tolerance a little both on p and U.
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   March 4, 2009, 15:02
Default Thanks for the input I will ru
Daniel Harlacher
Thanks for the input I will run a simulation with these settings and will report back - other comments are very welcome.
- harly
Old   March 4, 2009, 15:26
Default So, I am running now with t
Daniel Harlacher
So,
I am running now with the following modifications:
ddtSchemes
default CrankNicholson 0.5;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1.0 phi;
p PCG
preconditioner DIC;
tolerance 1e-07;
relTol 0;
U PBiCG
preconditioner DILU;
tolerance 1e-06;
relTol 0;
I will report back when I have some results.
Old   September 7, 2009, 11:31
Marco Turchi
zebu83 is on a distinguished road
Hi Daniel,
did you have a better results with the new settings?
Thank you
MT
zebu83 is offline   Reply With Quote
FvSolution pRefCell and pRefValue maka OpenFOAM Pre-Processing 5 February 17, 2015 04:00
FvSchemes sega OpenFOAM Running, Solving & CFD 2 February 15, 2010 12:07
Programmatically create fvSolution dictionary cliffoi OpenFOAM Running, Solving & CFD 14 February 12, 2009 03:50
FvSchemes from 12 to 11 fedegavo OpenFOAM Running, Solving & CFD 1 January 20, 2006 14:49
What must be defined in fvSolution Marco Kupiainen (Kupiainen) OpenFOAM Running, Solving & CFD 1 February 21, 2005 06:03
