Water pump OpenFOAM 15 ANSYS CFX 110 comparation
Like Tree1Likes
Old   February 11, 2009, 05:37
Default hi Hrv: i am back.and here
  #21
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
hi Hrv:
i am back.and here is max residual plot of CFX and the interation procedure plot of total pressure difference of the inlet and outlet
waynezw0618 is offline   Reply With Quote
Old   February 11, 2009, 08:30
  #22
wayne.zhang
hi Hrv:
regards
wayne
Old   February 11, 2009, 08:54
Default Hi Dragos: the absolute vel
  #23
wayne.zhang
Hi Dragos:
the absolute velocity is below.would you mind tell me more?
regardz!
wayne
Old   February 11, 2009, 10:01
Default Ok, the velocity looks physica
  #24
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Ok, the velocity looks physical as it looked in the relative values.
My guess now goes the same direction as Hrv said before: the results are not converged.
Dragos
dmoroian is offline   Reply With Quote
Old   February 11, 2009, 10:29
Default Hi do you mean both CFX a
  #25
wayne.zhang
Hi
do you mean both CFX and OF result are not converged?how about the max residual of CFX?
how to determine if the result is converged?
can you give me some example residual plot of converged ??
wayne
Old   February 11, 2009, 10:40
Default hi i also show the interat
  #26
wayne.zhang
hi
i also show the interation procedure plot of total pressure difference of the inlet and outlet,
how about that?
wayne
Old   February 11, 2009, 11:38
Default here is the clear view of resi
  #27
wayne.zhang
here is the clear view of residual of OF result
Old   February 12, 2009, 08:43
Default How about my max residual plot
  #28
wayne.zhang
How about my max residual plot,and moniter pointing plot of CFX? and how about OF?
ara they all not converged?
Regards
wayne
Old   February 18, 2009, 08:27
Default Hi wayne, the CFX help tell
  #29
Marco Müller
marico is on a distinguished road
Hi wayne,
the CFX help tells: > 5e-4 for MAX Residuals means: very poor, global balances will be poor and quantitative data is largely unreliable. This is good enough for getting a rough idea of flow phenomena or making pretty pictures ;)
Did you run with double precision? Try this. MAX Residuals below 1e-3 is nearly impossible if you have some bad "elements" in your mesh... (Your RMS values look OK..)
Regards
Marco
RMF likes this.
marico is offline   Reply With Quote
Old   February 18, 2009, 23:24
Default Hi Marco thanks,but how abo
  #30
wayne.zhang
Hi Marco
thanks,but how about my OpenFOAM Residual plot? why residual of p is so large.and u,v,w is just smalller than 1e-3.you see i run OF in double precision but not of CFX.
btw ,where did you find that "
the CFX help tells: > 5e-4 for MAX Residuals means: very poor, "
.i have check for the help.but do not find it.
thanks
wayne
Old   February 19, 2009, 02:51
Default Hi Wayne, the topic I found
  #31
Marco Müller
Hi Wayne,
the topic I found it is called "Judging Convergence" if I remember rightly...
I have no experience in OF solving, I'm struggeling with mesh generation so far... ;)
Marco
Old   February 19, 2009, 07:42
Default Hi Wayne, well, the thing a
  #32
olivier braun
obraun is on a distinguished road
Hi Wayne,
well, the thing about convergence is that you cannot expect any solver to yield a time-independent solution on such a problem. We are talking about 25% of BEP flow rate, so massive flow separation will obviously occur and the fact that one of every two channels is stalled does not surprise me much. I know that in CFX you can easily monitor the torque you are looking for, might be interesting to know if this integrated quantity is fluctuating together with the high residuals.
Olivier
obraun is offline   Reply With Quote
Old   March 1, 2009, 07:51
Default Hi Oliver and everyone i
  #33
wayne.zhang
in the 25%BEP, there will be flow separation filled in passages.so it is hard to get a good result from time-independent solver.i just want to know ,what level will steady solver in CFX and OF will achieve,if there will be jobs could do to make improvement,and what i want to do now is using OF result to compare with CFX result.but it is bad news that both get a pool level convergence.as you can see before.
But it is for SST not for standard k-e with scalable wall function in CFX,and in standard k-e i will get smaller residual.that is smaller then 5e-7(RMS) and 3e-4(max),according to the CFX help it is good enough for engineering application.and the large residual is from the flow separation, and it could see as the error of turbulence model,not numerical tech.in other words,in my opinion,from the point of residual,the numerical error in CFX k-e model is relative small for my case,and the errors should be from the modeling error,that say the error was from k-e model.
So i turn to SST,for i want more accurate boundary force or moment calculation.Then i got a worse convergence then standard k-e in CFX,even worse in OF(seems).but both could get a pretty picture of follow pattern.and agree with the PIV result in reference paper.but the difference in definition of residual in CFX and OF let me don`t know if CFX and OF get a result in a similar accurate in numerical.and if the numerical level could not be considered compared with modeling error,and how i can i improve my result with SST in CFX and OF.
The other thing is, starting with ke result i do a LES simulation(it get a convergence in smaller then 1e-5 of RMS.poor values in separation area). SST in CFX get intergrate quantity between LES and standard ke,(for example if ke get moment coefficency number is 50%.then LES is 90%,and SST is 75%,the bad news is that OF get 45%..) so i want to know if the error is from numerical or from turbulence model. i wish it is from numerical.and i wish if the convergence will get the same level for SST in both CFX and OF similar to ke.so i could compared both of all.
i wish some one could give me some good ideas
wayne
Old   March 1, 2009, 09:05
Default and here is integrated quanti
  #34
wayne.zhang
and here is integrated quantity iteration plot
Old   March 1, 2009, 12:11
Default and here is integrated quantit
  #35
wayne.zhang
Old   March 2, 2009, 03:40
Default there must be something wrong
  #36
wayne.zhang
there must be something wrong with internet service here in hour school.
i will try again
Old   March 2, 2009, 04:04
Default Hi Wayne, maybe you can try
  #37
Marco Müller
Hi Wayne,
maybe you can try to visualize the residuals in CFX-Post by Isovolumes. (Writing residuals to .res-file has to be enabled in output settings before solving) If they are locally bad you can refine mesh there to ensure that you have no numerical errors...
Marco
Old   March 2, 2009, 07:07
Default Hi Marco thanks! i will try
  #38
wayne.zhang
Hi Marco
thanks!
i will try as soon as possible
and
here is torque plot in OF iteration
http://4ovewq.bay.livefilestore.com/y1paU9IyqdeXOCZ8_vychQT3ZQVdDsEV4hXiHoeGd4gv i_qGsxzzfjV5KZAfto1X5_CSeu2sQW8d8PLStQp8q_5WQ/Screenshot-1.png
here is torque plot in CF iteration
http://4ovewq.bay.livefilestore.com/y1p_5WFzeMOsw5DUi59pUP_2u8AhtcrIaJDF4lSodkhl UbwTUqKkfLt_6ANDKoAU56OrBV6Q8Y8LWnchDVlMx6CLg/SST_moment.png
wayne
Old   March 2, 2009, 09:48
Default Hi Marco i get the isovolumes
  #39
wayne.zhang
Hi Marco
i get the isovolumes of P mass residual with setting value =1e-8,you could find picture here:
http://4ovewq.bay.livefilestore.com/y1pZW9xQu2Vbt6gUbIJn5pIqSEfyPn26hG4x2zP7x_g2 sWQft_PahbDhRVlIyaTxh7wZMK8FFeeAyk/PmassRes.png
isovolumes of U/V/W mass residual with setting value =1e-6,you could find picture here:
U:
v:
http://4ovewq.bay.livefilestore.com/y1pPRjqG4JN9m3T3SZYsL38KoXBrXxj_PkOFt-c3NRNN o1UevzoY8Qf2nBkGhJMCF8UStbtdplo_rw/VmassRes.png
W:
http://4ovewq.bay.livefilestore.com/y1p12QArkUl1EJKaaFX9hGqTgy136YejAjDBwT9OlqxP aj_VOPQfqQARy3jZGcaFqSFx75G7xWbZnw/WmassRes.png
How about the result??
do you think it is good enough for engineer application of torque calculation??
in my opinion ,in the blade domain the P/U/V/W residual is small enough, so the torque at blade is nothing wrong.but at Hub the U/V/W may get a relative coarse value so the viscous torque at Hub may not quiet precise,for pressure torque at Hub is zero.as the viscous torque is relative small compared with total torque.the total value of torque is with very small numerical error ,and the conclusion may be made as following:
the error between this CFD result and real one is because of modeling error such as turbulent model.is that right?
Regards
wayne
Old   March 5, 2009, 13:57
Default Hi Wayne, in my opinion und
  #40
olivier braun
Hi Wayne,
in my opinion under these severe partial discharge conditions, it is neither the numerics, neither the choice amongst different flavours of RANS models that induce the most severe uncertainty but the general assumption of steadiness regarding simulation approach and boundary conditions. Did you use constant pressure outlet, or massFlow specified outlet? What was the experimental setup, what is the real one of engineering interest ? Impeller in infinite domain, I don't think so. At such conditions, all kind of stall in the impeller and diffuser can occur, the interaction with the tongue of a spiral casing / diffuser blades can induce torque and blade load peaks far beyond the average value that are more critical to the pump design than the steady value. Inlet recirculation far upstream of the impeller leading edges has been observed, can your b.c. take this into account.
I went to time dependent RANS for some simulations done during my phD and had to find this is not sufficient. Just have to wait for another few decades and we can go DES for the entire beast over hundreds of impeller revolutions to do meaningful statistical averages of the flow in these washing machines ...
Honestly, if I had to build a pump and needed to determine the torque at shutoff, I would rather believe in semi-empirical statistic-1D consideration mixes as published in pump design textbooks than in a time-independent CFD simulation of an impeller without volute/diffuser...
Cheers
Olivier
analysis of pump flow in ANSYS prakash CFX 3 September 10, 2008 07:13
[Gmsh] ANSYS GMSH OpenFOAM gtg627e OpenFOAM Meshing & Mesh Conversion 3 December 21, 2007 04:41
turbulence model for water pump Marcio Main CFD Forum 4 September 3, 2003 10:35
Water Pump to 10 year old kid Selina Tracy Main CFD Forum 1 February 11, 2003 23:19
CFD Package for Water Pump Design !!! John Sheng Main CFD Forum 7 September 4, 2001 10:29
