May 1, 2011, 03:52 |
#141 |
ata kamyabi
Rep Power: 18 |
It seems that the problem of the code has been solved.
Enjoy |
May 2, 2011, 03:15 |
#142 |
Maryam Mousazadeh
Rep Power: 16 |
hello;
yes, it does well; I extremely thankful for your kindness; kind regards |
May 2, 2011, 11:04 |
#143 |
Maryam Mousazadeh
Rep Power: 16 |
hello M.r kamyabi;
excuse me; I did some change in the solver's code and compiled it eventually, but it seems has main problem when running a case; It doesn't do well and gives this error: nano.zip I don't know what to do ; would you guide me? thanks; |
May 3, 2011, 04:14 |
#144 |
ata kamyabi
Rep Power: 18 |
It seems that the problem of the transportProperties file has been solved.
Enjoy /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // transportModel Newtonian; nuF nuF [0 2 -1 0 0 0 0] 9.772e-4; kF kF [1 1 -3 -1 0 0 0] 0.6047; rhoF rhoF [1 -3 0 0 0 0 0] 9.9778e2; muF muF [1 -1 -1 0 0 0 0] 9.7937e-7; CpF CpF [0 2 -2 -1 0 0 0] 4076; DTF DT [0 2 -1 0 0 0 0] 1.4868e-7; Kb Kb [1 2 -2 -1 0 0 0] 1.4868e-7; kP kP [1 1 -3 -1 0 0 0] 401; rhoP rhoP [1 -3 0 0 0 0 0] 8933; dP dP [0 1 0 0 0 0 0] 0.00002; CpP CpP [0 2 -2 -1 0 0 0] 385; //************************************* nu nu [0 2 -1 0 0 0 0] 9.772e-4; //************************************* // ************************************************** *********************** // |
May 3, 2011, 13:17 |
#145 |
Maryam Mousazadeh
Rep Power: 16 |
hello;
thank you for reply;I want it read the nu from that formula which determined in the createFields not from transportProperties; If I change it's name there would be no problem? thanks |
May 4, 2011, 04:50 |
#146 |
ata kamyabi
Rep Power: 18 |
Hi
I think you should use "IOobject::NO_READ" for it. Good luck |
May 9, 2011, 07:44 |
#147 |
ata kamyabi
Rep Power: 18 |
Hi dear FOAMers
I have two questions about viscoelasticFluidFoam solver. 1. What does "p.boundaryField().updateCoeffs();" do? 2. I think after the line "p.relax();" the line "p.correctBoundaryConditions();" must be added. Am I true? Best regards Ata |
May 9, 2011, 08:30 |
#148 | |
Ra
How far is the developmentof the multiphase viscoelastic solver? Would you be releasing is sometime?
May 10, 2011, 03:19 |
#149 |
ata kamyabi
Rep Power: 18 |
Hi
I have a two phase viscoelastic solver too. I will release it after the end of my Ph.D. Any response to my question? Good luck |
May 10, 2011, 04:21 |
#150 |
Ra
Ata,
What methodology are you using for your solver? When will you finish your Ph.D.? We tried some development here but it didn't work at least for high Weissenberg numbers. How does your solver perform? |
May 13, 2011, 04:14 |
Two phase viscoelastic fluid flow
#151 |
ata kamyabi
Rep Power: 18 |
Hi
I used VOF method. I used two solvers interFoam and viscoelasticFluidFoam for creating my new solver. I will finish my Ph.D. about 2012. Use low tolerance for tau equation (e.g. 1e-15). May be this solve your problem. Good luck Ata |
August 1, 2011, 17:33 |
#152 |
Youse Keyghobadi
Rep Power: 15 |
hi
any body have the PTT-Linear Model of viscoelasticfluidFoam paper? PTT-Linear used in above solver is many different to another same of this model i cant understand " taufirst" please help me. thank you |
August 2, 2011, 01:27 |
Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
#153 |
ata kamyabi
Rep Power: 18 |
Hi
taufirst and tausecond and ... are used for multy mode constitutive equations. Good luck Ata |
August 2, 2011, 07:04 |
#154 |
Youse Keyghobadi
Rep Power: 15 |
Hi
Dear Ata in Constitutive Equation used just tau foe example LPTT model (1+(ε_k λ_k)/(ηp_k ) tr(τp_κ ) )τp_κ+λ_k τp_k=2ηp_k D tau first? |
August 2, 2011, 07:06 |
#155 |
Youse Keyghobadi
Rep Power: 15 |
Hi
August 2, 2011, 07:47 |
#156 |
Dear yosof,
tua is the summation of tau at each mode of viscoelastic fluid because of its relaxation spectra best regard ___________ Rasoul Last edited by desert_1250; August 3, 2011 at 01:56. |
August 2, 2011, 15:49 |
#157 |
Youse Keyghobadi
Rep Power: 15 |
August 3, 2011, 01:56 |
#158 |
August 21, 2011, 20:12 |
VicoelasticFluidFoam and OF2.0.0
#159 |
mmam
Rep Power: 15 |
Dear Fomers
I am trying to compile VicoelasticFluidFoam in OpenFoam2.0.0 I read the instruction which proposed in forum but It was not compiled. could you please let me know is this solver work with this version of Openfoam (2.0.0) or i have to downgrate it to OF1.5. If your answer is yes could you tell me how I can compile it. Regards |
August 22, 2011, 05:46 |
#160 |
ata kamyabi
Rep Power: 18 |
Hi
It is possible. Tell me what is your problem in detaile? Good luck Ata |
VOF simulation of a viscoelastic fluid | sinah | OpenFOAM Running, Solving & CFD | 11 | December 25, 2017 04:00 |
FREE SURFACE VISCOELASTIC FLOWS | Valdemir G. Ferreira | Main CFD Forum | 6 | December 18, 2009 07:14 |
Viscoelastic flow modeling in OpenFOAM | vulda | OpenFOAM Running, Solving & CFD | 1 | March 17, 2008 08:32 |
Polyflow & OpenFoam on Viscoelastic flow modeling | Sumeshen | Main CFD Forum | 0 | March 14, 2008 09:29 |
Viscoelastic fluid codes | joel davison | Main CFD Forum | 0 | November 6, 2001 06:09 |
