Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
Like Tree44Likes
Old   May 22, 2009, 15:25
Jovani L. Favero
jovani is on a distinguished road
Send a message via Skype™ to jovani
Hello Wendy,
Any observations and work to you:
1) There are some obvious implementation errors, i.e., the T is not defined, the unit for some parameters are not correct ...
But forget it for this moment and lets see the model and you need search answer for 2 questions:
First:
obs.: etaEff=sqrt(2.0/3.0)*mag(symm(fvc::grad(U))); this is not etaEff, this is shear rate in your model!
shearRate=sqrt(2.0/3.0)*mag(symm(fvc::grad(U)));
and
etaEff=asinh(pow(Z/A,1.0/n))/(3*beta*shearRate);
Here is a good point to talk: shear rate can be zero in any place of the domain or in any cell. shearRate = 0, division by zero, etaEff-> infinity and numeric problems. What do in this case????
Who developed this model will need a solution for it, see what is it!! take a better look on all the modeling.
Second:
Where is D^d in momentum equation??
fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(eta_d, U)
fvm::laplacian(eta_d, U) is equal to 2*eta(D,T)D^d ?? or you need create D = symm(fvc::grad(U)) and then make 2*nuEff*dev(D) into momentum equation?? This take grad(U) explicitly into momentum equation!!
Best,
Jovani
jovani is offline   Reply With Quote
Old   May 27, 2009, 13:03
xianghong wu
wendywu is on a distinguished road
Jovani,
Thank you so much for your patience and time.
I have corrected my code according to your correction.
would you please check it again when you have time?
Thank you and have a nice day.
Best,
Wendy
File Type: doc how to solve viscoplastic contitutive problem.doc (46.5 KB, 287 views)
wendywu is offline   Reply With Quote
Old   May 27, 2009, 13:09
Jean-Luc Pelerin
jlpelerin is on a distinguished road
Hi Jovani,
Congratulations! It seems like you did some great job.
I am also interested in this kind of solver (for ice simulation).
Do you know when you will be able to release your solver?
I have tried to implement one myself but I clearly lack basic knowledge on this subject.
Thank you,
Regards,
Jean-Luc
jlpelerin is offline   Reply With Quote
Old   May 27, 2009, 13:13
xianghong wu
hi,
Do you talk to Javani or to me? I am wendy, but I received your reply from my email box.
thank you. I am a begginer and I am just learning from the beginning. we can study together anyway.
Wendy
Old   July 20, 2009, 09:45
Jovani L. Favero
Hello Foamers,
I want to announce the release of the solver for treatment of viscoelastic fluid flow (the viscoelasticFluidFoam solver) in the OpenFOAM-1.5-dev SVN repository. Together with the solver also was released three tools: the "PSD" tool to calculate the principal stress difference, the "stressDifferences" tool to calculate the stress differences (N1 and N2) and "stressSymmComponents" to extract the six individual components of the stress tensor tau. I think the information in the tutorial is enough to the user understand the solver (the use of all models, multimode simulation, ....), but I will be helping as far as possible users of the solver.
The theory, some comments or formulation for the implemented models can be found in http://hdl.handle.net/10183/16306 where is available my master thesis (Obs.: is in Portuguese).
I want to thank my advisors, Prof. Hrvoje Jasak and, Prof. Argimiro R. Secchi and Prof. Nilo S. M. Cardozo from UFRGS, for the great guidance on this work. I also want to thank Prof. Hrvoje for your code reviews.
Enjoy
Jovani
Old   August 11, 2009, 05:48
Disabled
anon_c is on a distinguished road
I just was looking for the solver and the modells and now i fiend even some tutorials
very very good woork good done you have to do you phd that is very important so you can work with me on some new material modells
i am just solving the tutoral of giesekus
ad it take a lot of time bcz of my laptop
anon_c is offline   Reply With Quote
Old   August 12, 2009, 18:51
Jovani L. Favero
You are rigth, is expensive for a laptop !! This is due not only because the number of cells in the mesh, but also for: in 3D geometry the stress tensor need to be solved to the 6 components and this case have 4 modes, then there are 6*4=24 equations for stress. It was to be a little expensive case
Jovani
Old   August 15, 2009, 14:22
Default ViscoElastic in OF 1.6
  #48
Ray
RayExt is on a distinguished road
Is it possible to run the viscoelastic solver in OF 1.6?
RayExt is offline   Reply With Quote
Old   August 17, 2009, 13:28
Jovani L. Favero
Yes, I PREFER the -dev version but I believe it is easy run in the 1.6 version. You need take the directory /viscoelastic (OpenFOAM-1.5-dev/src/transportModels/) and put into your OF. Add the line " wmake libso viscoelastic" in the "Allwmake" file. Now compile the library transportModels (./Allwmake). Take the solver viscoelasticFluidFoam in the OpenFOAM-1.5-dev/applications/solvers/viscoelastic/ directory. Go to the file Make/Options and remove the line " -llduSolvers" and the "\" of the line above. Then compile the solver with wmake. I do not tested it, try and post if this work.
Jovani
Old   August 18, 2009, 08:51
Question viscoelasticFluidFoam
  #50
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hello
When i try to use viscoelasticFluidFoam i confront with this error.
Unknown asymmetric matrix solver BiCGStab
Valid asymmetric matrix solvers are :
4
smoothSolver
PBiCG
BICCG
GAMG
Can any one help me?
Thanks
ata is offline   Reply With Quote
Old   August 18, 2009, 10:27
Jovani L. Favero
Ok, I believe you are using a OpenFOAM version that is not the -dev version, where this problem does not exists because only in OpenFOAM -dev there is the BiCGStab solver. You need adapt all the tutorial for it. Basically you need make changes in fvSolution to change the solvers for p, U and tau. For pressure you can use PCG and for U and tau use PBiCG. Follow any other case, as for example, the fvSolution of the cavity to guide you.
Jovani
Old   August 26, 2009, 07:52
Disabled
hello
so now i just run some cases with your models, till now every thing is ok thanks again
but i have a quastin
how to use interFoam with theses models is that posible?? or is it posilbe to geht the vischoelastichFoam recompiled??
did you do somthing in this direction
Old   September 10, 2009, 14:47
Jovani L. Favero
What you need is a multiphase solver with viscoelastic treatment. The viscoelasticFluidFoam solver doesn't do this, because your formulation is to closed flow of 1 only fluid. You cannot use interFoam too, because it doesn't support viscoelastic flow, only multiphase newtonian or GNF fluid.
I have a solver to treat multiphase viscoelastic flow, but a can't release it now.
Jovani
Old   September 10, 2009, 15:41
Disabled
would you be able to relase that in the next months or you dont want to or you are not alowed to do that!
i am interested on viscoelastic fluids and there mixing, i am also interested in mixing between newtoniean and nonnewtonian fluids
i would be really thankful if you would be able to do something in this direction and let us know about it
Old   September 11, 2009, 03:31
Default Two Phase Viscoelastic Fluid Flow
  #55
ata
ata's Avatar
ata kamyabi
Hello jovani
My request is similar to tajoooko request ane i'll be glad if you answer to his questions because his questions are my questions too.
Ata
Old   September 14, 2009, 10:21
Jovani L. Favero
I need to publish any paper with results of this new implementation before release. With that I can also to test better the solver and make some corrections or improvements if this is necessary. Let's say that is still under evaluation.
Jovani
Old   September 15, 2009, 04:19
  #57
ata
ata's Avatar
ata kamyabi
Hello Jovani
Thanks
Good luck
Ata
Old   September 16, 2009, 05:46
Default ViscoElasticFluid Foam In parallel
  #58
Prashobh
Prashobh is on a distinguished road
Hi Thanks for the posts,
I am trying to run the viscoelasticfluidfoam example on Bluegene in parallel. I modified the case to use the PCG,PBiCG solvers, since I could not compile the lduSolvers. Are there any major performance/accuracy impacts to using PCG, PBICG solvers instead of BiCGStab?
My fvSolution file looks like the following now.
p PCG
preconditioner DIC
tolerance 1e-07;
relTol 0.0;
minIter 0;
maxIter 800;
U PBiCG
preconditioner DILU
minIter 0;
maxIter 1000;
tolerance 1e-6;
relTol 0.0;
Best Regards,
Prashobh
Prashobh is offline   Reply With Quote
Old   September 18, 2009, 14:28
Default problems in installing the viscoelasticFluidFoam solver in OpenFOAM 1.6
  #59
Teresa Margarida Mata
tmata2002 is on a distinguished road
Hi Foamers, and in particular Jovani,
I have followed the instructions given by Jovani Favero in order to install the viscoelasticFluidFoam
in OpenFOAM-1.6. When I construtcted the viscoelasticTransportModels, there were some missing files errors,
that I was able to solve by copying the missing files from OpenFoam-1.5-dev to OpenFOAM-1.6.
I managed to compile the library. Then, I passed to the compilation of the solver itself, correcting
the options file in the Make directory. The compilation started well, but I got the following errors:
Making dependency list for source file viscoelasticFluidFoam.C
SOURCE=viscoelasticFluidFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/transportModels/viscoelastic/lnInclude -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/viscoelasticFluidFoam.o
/home/titio/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/home/titio/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readPISOControls.H:8: warning: unused variable ‘momentumPredictor’
/home/titio/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readPISOControls.H:11: warning: unused variable ‘transonic’
/home/titio/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readPISOControls.H:14: warning: unused variable ‘nOuterCorr’
g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/transportModels/viscoelastic/lnInclude -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/titio/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linuxGccDPOpt/viscoelasticFluidFoam.o -L/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt \
-lfiniteVolume -lviscoelasticTransportModels -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /home/titio/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/viscoelasticFluidFoam
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam::fvMatrix<double>::solve(Foam::Istream&)'
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam::dictionary::lookup(Foam::word const&, bool) const'
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam::lduMatrix::solver::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Istream&)'
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam::SLListBase::endIter'
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam::SLListBase::endConstIter'
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam::Ostream::writeKeyword(Foam::word const&)'
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam::regIOobject::regIOobject(Foam::IOobject const&)'
/home/titio/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libviscoelasticTransportModels.so: undefined reference to `Foam:olyMesh::directions() const'
collect2: ld returned 1 exit status
It seems that there are errors linked to ldumatrixes and SLListBase. This means that, although the library compiled well, i have to do more things.
Can anyone help me out here? Thanks in advance,
Teresa Mata
tmata2002 is offline   Reply With Quote
Old   September 18, 2009, 17:55
Jovani L. Favero
Hello Teresa,
As nobody post the results of:
"You need take the directory /viscoelastic (OpenFOAM-1.5-dev/src/transportModels/) and put into your OF. Add the line " wmake libso viscoelastic" in the "Allwmake" file. Now compile the library transportModels (./Allwmake). Take the solver viscoelasticFluidFoam in the OpenFOAM-1.5-dev/applications/solvers/viscoelastic/ directory. Go to the file Make/Options and remove the line " -llduSolvers" and the "\" of the line above. "
I made the test in OF1.6 in a 64 bits machine (m64) and all works fine for me. I compiled the viscoelasticTransportModels without warnings and no changes was necessary for this. Your machine is 32 bits but I think this is not the problem. After take a look in your messages I believe the problem you have to compile the solver is a problem with your libviscoelasticTransportModels.so library. Are you sure this was rigth compiled??? The directory -I$(LIB_SRC)/transportModels/viscoelastic/lnInclude are ok??
The option of copy files from OpenFoam-1.5-dev to OpenFOAM-1.6 is not a good ideia. I think your problem is here!! You need compile the library without changes and if you cannot do it is better take a look in why do you have problems and correct this.
Hello Prashobh,
The changes of the solver for the linear system impact on your performance and stability and not in accuracy, this is what I know. Is like solve a problem using Bisection method and Newton Rapson method.
Best,
Jovani
VOF simulation of a viscoelastic fluid sinah OpenFOAM Running, Solving & CFD 11 December 25, 2017 04:00
FREE SURFACE VISCOELASTIC FLOWS Valdemir G. Ferreira Main CFD Forum 6 December 18, 2009 07:14
Viscoelastic flow modeling in OpenFOAM vulda OpenFOAM Running, Solving & CFD 1 March 17, 2008 08:32
Polyflow & OpenFoam on Viscoelastic flow modeling Sumeshen Main CFD Forum 0 March 14, 2008 09:29
Viscoelastic fluid codes joel davison Main CFD Forum 0 November 6, 2001 06:09
