Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
Like Tree44Likes
Old   February 19, 2021, 04:06
Shubham Goswami
goswami is on a distinguished road
Originally Posted by hjasak View Post
Starting a post with an insult isn’t good. Foam-extend is not buggy and I put a lot of effort into doing things right. Perhaps the problem is somewhere else.
For a periodic channel, use pressure jump boundary conditions: this is a much more stable way of dealing with the flow. You change one boundary condition in one file.
Regarding validation and Re numbers, kindly read - and quote - the papers! We make sure the cases used in papers are publicly available and all results are reporoducable.
Hrvoje Jasak
I apologize if it seems like an insult Dr. Jasak, but personally my experience with foam-extend isn't really good. But that's not what I want to discuss here.
Regarding the validation, I agree, the tutorial cases in viscoelasticFluidFoam solver are well validated. But the problem is they're at a very low Reynolds number. The same concern is posted in another post here by someone else, that there is a lack of literature at high Reynolds numbers using this solver.
Thank you for the periodic pressure jump boundary condition. I should try that.
goswami is offline   Reply With Quote
Old   August 26, 2021, 11:33
Default dimensions error
  #462
Asanda
Grace1 is on a distinguished road
Hello everyone,
May you kindly assist me, I have modified the viscoelastic solver by adding a temperature equation.
fvm::ddt((rho*Cp),T)
+ fvm::div((rho*Cp*phi),T)
- fvm::laplacian(k,T) ==
gamma*(visco.tau() && fvc::grad(U))
+ (1.0-gamma)*(1.0-beta)*(symm(fvc::grad(U)) && symm(fvc::grad(U)))
- fvm::Sp(hc,Tw)+hc*T
where Tw is wall temperature and T fluid temperature
and these are the dimensions of the coefficients used
rho rho [1 -3 0 0 0 0 0]
gamma gamma [0 0 0 0 0 0 0]
beta beta [0 0 0 0 0 0 0]
k k [1 1 -3 -1 0 0 0]
Cp Cp [0 2 -2 -1 0 0 0]
hc hc [1 0 -3 -1 0 0 0]
when I run the case file I keep getting this error
--> FOAM FATAL ERROR:
LHS and RHS of + have different dimensions
dimensions : [1 -1 -3 0 0 0 0] + [0 0 -2 0 0 0 0]
From function operator+(const dimensionSet& ds1, const dimensionSet& ds2)
in file dimensionSet/dimensionSet.C at line 407.
Not sure how to resolve this issue or where the dimension problem is coming from, may you kindly assist me
thanks
Grace1 is offline   Reply With Quote
Old   August 27, 2021, 04:12
A. Min
alimea is on a distinguished road
Originally Posted by Grace1 View Post
Hello everyone,
thanks
Dear Asanda
As you can see in the error the dimensions of the two terms are different in the energy eqn. I saw that all your first term dimension is [1 -1 -3 0 0 0 0], the same as the other erms. But the dimension of (1.0-gamma)*(1.0-beta)*(symm(fvc::grad(U)) && symm(fvc::grad(U))) is [0 0 -2 0 0 0 0]. You should check the reference from that you found the equation. There are some other dimensioned parameters before (symm(fvc::grad(U)) && symm(fvc::grad(U))) that you might forget to consider.
Regards,
Ali
alimea is offline   Reply With Quote
Old   August 28, 2021, 06:48
Asanda
Dear Ali
Firstly thank you for your response,
Thank you, with your assistance and guidance I was able to resolve my problem. And yes indeed there was a dimensioned parameter - the polymeric viscosity- which I needed to multiply with this term (symm(fvc::grad(U)) && symm(fvc::grad(U))).
alimea likes this.
Old   September 2, 2021, 03:28
Default Floating point exception (core dumped) error
  #465
Asanda
Hello Everyone
I am using viscoelasticFluidFoam solver and the Giesekus Model to simulate a flow in a pipe. And have modified both by adding temperature.
Now every time I run my simulation it gives me the below error and have tried to reduce delta T, Max Co. number and even check velocity value but nothing seems to be working
Courant Number mean: 8.19815e-06 max: 0.0016354 velocity magnitude: 0.336024
deltaT = 0.000121669
Time = 0.000730166
DILUPBiCG: Solving for Ux, Initial residual = 0.00475588, Final residual = 9.01518e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.00477491, Final residual = 5.60245e-09, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.00153646, Final residual = 3.99944e-09, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.202343, Final residual = 9.65702e-08, No Iterations 322
time step continuity errors : sum local = 1.74596e-13, global = -1.10905e-14, cumulative = -1.43122e-14
Model mode 1
DILUPBiCG: Solving for taufirstxx, Initial residual = 0.00504237, Final residual = 2.64016e-15, No Iterations 1
DILUPBiCG: Solving for taufirstxy, Initial residual = 0.00719778, Final residual = 1.69566e-15, No Iterations 1
DILUPBiCG: Solving for taufirstxz, Initial residual = 0.00372445, Final residual = 1.81474e-17, No Iterations 1
DILUPBiCG: Solving for taufirstyy, Initial residual = 0.00513511, Final residual = 2.97488e-15, No Iterations 1
DILUPBiCG: Solving for taufirstyz, Initial residual = 0.00372444, Final residual = 2.90091e-18, No Iterations 1
DILUPBiCG: Solving for taufirstzz, Initial residual = 0.00360069, Final residual = 9.85626e-17, No Iterations 1
Model mode 2
DILUPBiCG: Solving for tausecondxx, Initial residual = 0.00901374, Final residual = 4.5788e-16, No Iterations 1
DILUPBiCG: Solving for tausecondxy, Initial residual = 0.011415, Final residual = 3.71279e-16, No Iterations 1
DILUPBiCG: Solving for tausecondxz, Initial residual = 0.00373582, Final residual = 1.74955e-17, No Iterations 1
DILUPBiCG: Solving for tausecondyy, Initial residual = 0.00924354, Final residual = 6.99518e-16, No Iterations 1
DILUPBiCG: Solving for tausecondyz, Initial residual = 0.00373581, Final residual = 1.75101e-17, No Iterations 1
DILUPBiCG: Solving for tausecondzz, Initial residual = 0.00294321, Final residual = 5.88967e-17, No Iterations 1
Model mode 3
DILUPBiCG: Solving for tauthirdxx, Initial residual = 0.00929762, Final residual = 1.30313e-16, No Iterations 1
DILUPBiCG: Solving for tauthirdxy, Initial residual = 0.0117061, Final residual = 4.89053e-17, No Iterations 1
DILUPBiCG: Solving for tauthirdxz, Initial residual = 0.00373792, Final residual = 1.78278e-17, No Iterations 1
DILUPBiCG: Solving for tauthirdyy, Initial residual = 0.00953793, Final residual = 1.59044e-16, No Iterations 1
DILUPBiCG: Solving for tauthirdyz, Initial residual = 0.00373792, Final residual = 1.9548e-17, No Iterations 1
DILUPBiCG: Solving for tauthirdzz, Initial residual = 0.0026507, Final residual = 5.17534e-18, No Iterations 1
Model mode 4
DILUPBiCG: Solving for taufourthxx, Initial residual = 0.00940334, Final residual = 3.38134e-17, No Iterations 1
DILUPBiCG: Solving for taufourthxy, Initial residual = 0.0118159, Final residual = 1.53916e-17, No Iterations 1
DILUPBiCG: Solving for taufourthxz, Initial residual = 0.00373861, Final residual = 7.48391e-18, No Iterations 1
DILUPBiCG: Solving for taufourthyy, Initial residual = 0.00964937, Final residual = 8.37758e-17, No Iterations 1
DILUPBiCG: Solving for taufourthyz, Initial residual = 0.00373861, Final residual = 1.28578e-17, No Iterations 1
DILUPBiCG: Solving for taufourthzz, Initial residual = 0.00246207, Final residual = 8.77819e-17, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 0.45522, Final residual = 7.40274e-09, No Iterations 5
DILUPBiCG: Solving for Tw, Initial residual = 0.0828233, Final residual = 1.66062e-08, No Iterations 4
CHECKMESH :
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
all points: 222101
live points: 222101
all faces: 654000
live faces: 654000
internal faces: 642000
cells: 216000
boundary patches: 3
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 216000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Area [m^2] Surface topology
inlet 3600 3641 0.00196148 ok (non-closed singly connected)
outlet 3600 3641 0.00196148 ok (non-closed singly connected)
pipewall 4800 4880 0.392598 ok (non-closed singly connected)
Checking geometry...
This is a 3-D mesh
Overall domain bounding box (-0.025 -0.025 0) (0.025 0.025 2.5)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Mesh (non-empty, non-wedge) dimensions 3
Boundary openness (2.02337e-16 2.16504e-16 4.25812e-17) Threshold = 1e-06 OK.
Max cell openness = 2.74096e-16 OK.
Max aspect ratio = 195.315 OK.
Minumum face area = 3.67922e-07. Maximum face area = 8.17913e-05. Face area magnitudes OK.
Min volume = 1.53301e-08. Max volume = 2.95413e-08. Total volume = 0.00490369. Cell volumes OK.
Mesh non-orthogonality Max: 37.1451 average: 5.71625 Threshold = 70
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.569773 OK.
Mesh OK.
CONTROL DICT:
startFrom startTime;
startTime 0.0;
stopAt endTime;
endTime 2;
deltaT 1e-16;
writeControl adjustableRunTime;
writeInterval 1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
graphFormat raw;
runTimeModifiable yes;
adjustTimeStep on;
maxCo 0.25;
maxDeltaT 0.001;
I am not sure on how else to resolve this issue . May you kindly assist me or provide some guidance on how to resolve this problem
Thanks in advance
Old   September 2, 2021, 03:48
Default Floating point exception with Giesekus model
  #466
Sita Drost
sita is on a distinguished road
Hi Grace,
Without having seen your geometry, mesh, boundary conditions, etc. I can't say much I'm afraid. However, from working with viscoelasticFluidFoam myself (ages ago...) I remember that the mesh close to walls should be extremely fine. Did you try your adapted Giesekus model on the tutorial geometry included by Jovani Favero?
Sita
EDIT: Oh, and also I remember using very small (adaptive) time steps, something on the order of 1e-5. But again, without having seen your case, I'm not sure whether that'll help you
P.S. Tip: when including OpenFOAM code or output, you can wrap it in [CODE] tags, using the #-button in your toolbar, so that it won't take up as much space. Like so:
Time = 0.000730166
Model mode 1
Model mode 2
Model mode 3
Model mode 4
CHECKMESH :
Create time
Time = 0
Mesh stats
all points: 222101
live points: 222101
all faces: 654000
live faces: 654000
cells: 216000
boundary patches: 3
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 216000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Point usage OK.
Face vertices OK.
This is a 3-D mesh
Face pyramids OK.
Mesh OK.
CONTROL DICT:
startTime 0.0;
stopAt endTime;
endTime 2;
deltaT 1e-16;
writeInterval 1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
graphFormat raw;
adjustTimeStep on;
maxCo 0.25;
maxDeltaT 0.001;
sita is offline   Reply With Quote
Old   September 2, 2021, 05:50
  #467
Asanda
Dear Sita
Firstly, thank you for your response
Yes I did try it on the Giesekus tutorial geomerty and it gave me the same error
Courant Number mean: 0.000545927 max: 0.292199 velocity magnitude: 0.197535
deltaT = 4.2993e-05
Time = 0.000197973
BiCGStab:  Solving for Ux, Initial residual = 1, Final residual = 1.44448e-27, No Iterations 1
BiCGStab:  Solving for Uy, Initial residual = 1, Final residual = 1.65226e-25, No Iterations 1
CholeskyCG:  Solving for p, Initial residual = 0.99999, Final residual = 9.58303e-08, No Iterations 131
time step continuity errors : sum local = 2.33923e+87, global = 6.5963e+74, cumulative = 6.5963e+74
Model mode 1
BiCGStab:  Solving for taufirstxx, Initial residual = 1, Final residual = 2.87295e-11, No Iterations 2
BiCGStab:  Solving for taufirstxy, Initial residual = 1, Final residual = 1.65959e-08, No Iterations 1
BiCGStab:  Solving for taufirstyy, Initial residual = 1, Final residual = 5.09339e-07, No Iterations 1
BiCGStab:  Solving for taufirstzz, Initial residual = 0, Final residual = 0, No Iterations 0
Model mode 2
BiCGStab:  Solving for tausecondxx, Initial residual = 1, Final residual = 2.87303e-11, No Iterations 2
BiCGStab:  Solving for tausecondxy, Initial residual = 1, Final residual = 1.6596e-08, No Iterations 1
BiCGStab:  Solving for tausecondyy, Initial residual = 1, Final residual = 5.09339e-07, No Iterations 1
BiCGStab:  Solving for tausecondzz, Initial residual = 0, Final residual = 0, No Iterations 0
Model mode 3
BiCGStab:  Solving for tauthirdxx, Initial residual = 1, Final residual = 2.87304e-11, No Iterations 2
BiCGStab:  Solving for tauthirdxy, Initial residual = 1, Final residual = 1.6596e-08, No Iterations 1
BiCGStab:  Solving for tauthirdyy, Initial residual = 1, Final residual = 5.09339e-07, No Iterations 1
BiCGStab:  Solving for tauthirdzz, Initial residual = 0, Final residual = 0, No Iterations 0
Model mode 4
BiCGStab:  Solving for taufourthxx, Initial residual = 1, Final residual = 2.87304e-11, No Iterations 2
BiCGStab:  Solving for taufourthxy, Initial residual = 1, Final residual = 1.6596e-08, No Iterations 1
BiCGStab:  Solving for taufourthyy, Initial residual = 1, Final residual = 5.09339e-07, No Iterations 1
BiCGStab:  Solving for taufourthzz, Initial residual = 0, Final residual = 0, No Iterations 0
For the pipe geometry mesh file that I used: Tw - wall temperature & T- fluid temperature
this is the first mesh that I tried
scale   0.025;
vertices
    //block0 vertices
    (-0.25 0.25 0)            //0
    (-0.707106 0.707106 0)    //1
    (0.707106 0.707106 0)     //2
    (0.25 0.25 0)             //3
    (-0.25 0.25 100)          //4
    (-0.707106 0.707106 100)  //5
    (0.707106 0.707106 100)   //6
    (0.25 0.25 100)           //7
    //block1 new vertices
    (0.25 -0.25 0)            //8
    (0.707106 -0.707106 0)    //9
    (0.25 -0.25 100)          //10
    (0.707106 -0.707106 100)  //11
    //block3 new vertices
    (-0.25 -0.25 0)           //12
    (-0.707106 -0.707106 0)   //13
    (-0.25 -0.25 100)         //14
    (-0.707106 -0.707106 100) //15
xcells 20;
ycells 40;
zcells 60;
xcells1 20;
ycells1 20;
zcells1 60;
stretch 0.25;
blocks
    //block0
    hex (0 3 2 1 4 7 6 5)       ($xcells $ycells $zcells)    simpleGrading (1 $stretch 1)
    //block1
    hex (3 8 9 2 7 10 11 6)     ($xcells $ycells $zcells)    simpleGrading (1 $stretch 1)
    //block2
    hex (8 12 13 9 10 14 15 11) ($xcells $ycells $zcells)    simpleGrading (1 $stretch 1)
    //block3
    hex (12 0 1 13 14 4 5 15)   ($xcells $ycells $zcells)    simpleGrading (1 $stretch 1)
    //block4
    hex (0 12 8 3 4 14 10 7)    ($xcells1 $ycells1 $zcells1) simpleGrading (1 1 1)
edges
    //block0 arc
    arc 1 2 (0 1 0)
    arc 5 6 (0 1 100)
    //block1 arc
    arc 2 9 (1 0 0)
    arc 6 11 (1 0 100)
    //block2 arc
    arc 9 13 (0 -1 0)
    arc 11 15 (0 -1 100)
    //block3 arc
    arc 1 13 (-1 0 0)
    arc 5 15 (-1 0 100)
boundary
    inlet
     type patch;
         faces
              (0 1 2 3)
              (2 3 8 9)
              (8 9 13 12)
              (13 12 0 1)
              (0 3 8 12)
    outlet
         type patch;
         faces
             (4 5 6 7)
             (6 7 10 11)
             (15 11 10 14)
             (15 14 4 5)
             (4 7 10 14)
    pipewall
       type wall;
       faces
           (1 5 6 2)
           (2 6 11 9)
           (9 11 15 13)
           (13 15 5 1)
mergePatchPairs
which gave me the above output. Tried to modify the mesh by reducing the stretching and the length of the pipe but got the same error
Boundary conditions:
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 0.336);
    pipewall
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            zeroGradient;
 class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 200;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 100;
    pipewall
        type            zeroGradient;
   outlet
        type            zeroGradient;
    object      Tw;
internalField   uniform 150;
boundaryField
     inlet
        type            zeroGradient;
    pipewall
        type            zeroGradient;
   outlet
        type            zeroGradient;
boundary conditions for tau , tau first to forth, N1,N2 and p those I did not change, are exactly as what they have in the tutorial.
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default                  none;
    div(phi,U)               Gauss upwind;
    div(((rho*Cp)*phi),T)    Gauss upwind;
    div(phi,taufirst)          Gauss upwind;
    div(phi,tausecond)         Gauss upwind;
    div(phi,tauthird)          Gauss upwind;
    div(phi,taufourth)         Gauss upwind;
    div(tau)                 Gauss linear;
    div(phi,k)               Gauss upwind;
laplacianSchemes
    default                      none;
    laplacian(etaPEff,U)         Gauss linear corrected;
    laplacian(etaPEff+etaS,U)    Gauss linear corrected;
    laplacian((1|A(U)),p)        Gauss linear corrected;
    laplacian(k,T)               Gauss linear corrected;
    laplacian(k,Tw)              Gauss linear corrected;
interpolationSchemes
    default           linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         corrected;
solvers
    p
         solver          CG;
        preconditioner  Cholesky;
        tolerance        1e-07;
        relTol           0;
        minIter          0;
        maxIter          800;
    T
       solver           BiCGStab;
        preconditioner   DILU;
        tolerance        1e-7;
        relTol           0;
     Tw
       solver           BiCGStab;
        tolerance        1e-7;
        relTol           0;
    U
        solver           BiCGStab;
        preconditioner   ILU0;
        tolerance         1e-6;
        relTol            0;
        minIter           0;
        maxIter           1000;
    taufirst
        solver            BiCGStab;
        tolerance         1e-6;
        relTol            0;
        minIter           0;
        maxIter           1000;
    tausecond
        solver            BiCGStab;
        tolerance         1e-6;
        relTol            0;
        minIter           0;
        maxIter           1000;
    tauthird
        solver            BiCGStab;
        tolerance         1e-6;
        relTol            0;
        minIter           0;
        maxIter           1000;
    taufourth
        solver            BiCGStab;
        tolerance         1e-6;
        relTol            0;
        minIter           0;
        maxIter           1000;
PISO
    nCorrectors    2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    p                   0.3;
    U                   0.5;
    T                   0.5;
    Tw                  0.5;
    taufirst            0.3;
    tausecond           0.3;
    tauthird            0.3;
    taufourth           0.3;
Thank you in advance for your assistance and guidance
Old   September 2, 2021, 06:10
A. Min
Hello Everyone
Time = 0.000730166
Model mode 1
Model mode 2
Model mode 3
Model mode 4
CHECKMESH :
Create time
Time = 0
Mesh stats
all points: 222101
live points: 222101
all faces: 654000
live faces: 654000
cells: 216000
boundary patches: 3
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 216000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Point usage OK.
Face vertices OK.
This is a 3-D mesh
Face pyramids OK.
Mesh OK.
CONTROL DICT:
startTime 0.0;
stopAt endTime;
endTime 2;
deltaT 1e-16;
writeInterval 1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
graphFormat raw;
adjustTimeStep on;
maxCo 0.25;
maxDeltaT 0.001;
Thanks in advance
Hello Grace
What are the Reynolds number and Deborah number in your case?
The viscoelasticFluidFoam is unstable numerically in high De numbers.
You may use rheoHeatFoam, which is a stable solver of the rheoTool package. It can be download from GitHub:
https://github.com/fppimenta/rheoTool
regards,
Ali
Old   September 2, 2021, 06:17
  #469
Sita Drost
Hi Grace,
Hm, in that case I'd go back to the original Gieskus tutorial case, see if you can get that to run, and then take baby steps from there. For example, is there a way to cancel the influence of temperature in your adapted model, say, by choosing the same value for the wall and fluid temperatures? And what happens if you change your BCs to achieve very low Re and Wi numbers, e.g. by setting the inlet velocity to a very low value?
I know this process can be frustrating sometimes, but usually there's a perfectly sensible, usually physical reason that things don't work in OpenFOAM.
Hope this helps,
Sita
EDIT: Another quick test would be to plug in the standard Giesekus model in your pipe flow case. If that works, the problem should be in your implementation of the temperature-dependent Giesekus model, if it blows up as well, the problem is more likely to be in your mesh or BCs.
Old   September 2, 2021, 11:18
  #470
Asanda
Dear Sita and Ali
Re is around 500 and De 0.005, I will rework these values . Thank you for this point
Viscoelastic Property:
 type multiMode;
        models
            first
            type Giesekus_WLF;
            rho               rho [1 -3 0 0 0 0 0] 803.87097;
            C1                C1  [0  0 0 0 0 0 0] 17.44;
            C2                C2  [0  0 0 1 0 0 0] 51.6;
            T0                T0  [0  0 0 1 0 0 0] 100;
            etaS0             etaS0 [1 -1 -1 0 0 0 0] 0.002;
            etaP0             etaP0 [1 -1 -1 0 0 0 0] 0.04;
            lambda0           lambda0 [0 0 1 0 0 0 0] 0.6855;
            alpha             alpha [0 0 0 0 0 0 0] 0.5;
            second
            type Giesekus_WLF;
            etaP0             etaP0 [1 -1 -1 0 0 0 0] 0.2324;
            lambda0           lambda0 [0 0 1 0 0 0 0] 0.1396;
            alpha             alpha [0 0 0 0 0 0 0] 0.2;
            third
            type Giesekus_WLF;
            etaP0             etaP0 [1 -1 -1 0 0 0 0] 0.5664;
            lambda0           lambda0 [0 0 1 0 0 0 0] 0.0389;
            alpha             alpha [0 0 0 0 0 0 0] 0.3;
            fourth
            type Giesekus_WLF;
            T0                T0  [0  0 0 1 0 0 0] 100 ;
            etaP0             etaP0 [1 -1 -1 0 0 0 0] 0.5850;
            lambda0           lambda0 [0 0 1 0 0 0 0] 0.0059;
Okay thank you, I will try this
Another question can my source code add to the problem as well ? I modified the Giesekus Model using WLF model
Thank you for your guidance
Old   October 8, 2022, 10:38
Default I am geeting an error while following the procedure for compiling viscoelastic fluidf
  #471
Orissa
pratyush_6174 is on a distinguished road
cd openfoam2206/src/transportModels/viscoelastic/&& wmake libso && cd -
wmake libso (viscoelastic)
g++ -std=c++14 -m64 -pthread -DOPENFOAM=2206 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude -iquote. -IlnInclude -I/usr/lib/openfoam/openfoam2206/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2206/src/OSspecific/POSIX/lnInclude -fPIC -c viscoelasticModel/viscoelasticModel.C -o Make/linux64GccDPInt32Opt/viscoelasticModel/viscoelasticModel.o
In file included from /usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude/lduPrimitiveMeshAssemblyTemplates.C:31,
from /usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude/lduPrimitiveMeshAssembly.H:236,
from /usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude/fvMatrix.H:54,
from /usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude/fvmDdt.H:41,
from /usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude/fvm.H:45,
from lnInclude/viscoelasticLaw.H:45,
from viscoelasticModel/viscoelasticModel.H:43,
from viscoelasticModel/viscoelasticModel.C:27:
/usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:42:10: fatal error: cyclicAMILduInterface.H: No such file or directory
42 | #include "cyclicAMILduInterface.H"
compilation terminated.
make: *** [/usr/lib/openfoam/openfoam2206/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/viscoelasticModel/viscoelasticModel.o] Error 1
pratyush_6174 is offline   Reply With Quote
Old   January 12, 2023, 18:29
hari
Saicharan is on a distinguished road
Hi sita,
does openfoam 8 has any solver like viscoElasticFluidfoam?
Saicharan is offline   Reply With Quote
Old   January 13, 2023, 02:28
Sita Drost
Sorry, I haven't used OpenFOAM in a while, so I wouldn't know for sure. As far as I'm aware, you need foamExtend to run viscoelasticFluidFoam.
If you take a look at the standard solvers in the the OpenFOAM-8 user guide, you can see that there's nonNewtonianIcoFoam, which might suit your needs:
https://doc.cfd.direct/openfoam/user...andard-solvers
I never tried this solver myself, but you could take a look at that as well.
Good luck,
Sita
Old   January 13, 2023, 06:11
hari charan
saicharan662000@gmail.com is on a distinguished road
Hi sita,
Can i know which version has viscoelasticfluidfoam?
saicharan662000@gmail.com is offline   Reply With Quote
Old   January 13, 2023, 06:54
Sita Drost
Hi Hari,
As I wrote earlier, I haven't used viscoelasticFluidFoam in a while (since 2015!), so I wouldn't know. Have you tried an online search? I just did, and the first hit I got is:
https://sourceforge.net/projects/vffof21x/
So apparently they've moved from foamExtend to OpenFOAM-2.1.x (that's the commercial version if I'm correct, to be found under openfoam.com instead of openfoam.org).
I'm afraid I can't help you any further with this.
Sita
Old   January 13, 2023, 09:21
hari charan
Thank you for the reply sita. I will look into it
VOF simulation of a viscoelastic fluid sinah OpenFOAM Running, Solving & CFD 11 December 25, 2017 04:00
FREE SURFACE VISCOELASTIC FLOWS Valdemir G. Ferreira Main CFD Forum 6 December 18, 2009 07:14
Viscoelastic flow modeling in OpenFOAM vulda OpenFOAM Running, Solving & CFD 1 March 17, 2008 08:32
Polyflow & OpenFoam on Viscoelastic flow modeling Sumeshen Main CFD Forum 0 March 14, 2008 09:29
Viscoelastic fluid codes joel davison Main CFD Forum 0 November 6, 2001 06:09
