June 13, 2016, 20:55 |
Giesekus model
#401 |
ahmed
HI member
Depending in my experience the using of Giesekus model reveal divergence result with large shear rate value and this is one of drawback in using this model. I really search in the source of divergence and try to find suitable approach . I would like to know detail information about your geometry so I can more helpful in this issue. you are free to message me on my G Mail . engineer.alqayssi@gmail.com Best Regard |
June 15, 2016, 03:10 |
#402 |
Thanks for your reply, Ahmed.
I am very glad to know that anybody tries to help me because I am at a nonplus. What detail information about geometry do you need? I have already specified geometry, model's parameters and boundary conditions in previous reply (file Geometry.jpg). |
February 18, 2017, 11:54 |
viscoelastic model + free convection
#403 |
A. Min
Rep Power: 12 |
Dear jovani
Thanks for developping OF for viscoelastic fluids. I'm a new foamer. I want to solve "free convection flow and heat transfer of viscoelastic fluid by Buossinesq approximation" Could you plz help me how to do that? |
June 8, 2017, 19:18 |
viscoelasticFluidFoam for dynamic mesh
#404 | |
Rep Power: 13 |
Hi everyone! I am interested in applying viscoelasticFluidFoam to a dynamic mesh. Frorian, have you succeded in developing interViscoDyMFoam? The code (cited in the quoted post) is no more linked. Could you please make it available? Any other help in combining viscoelasticFluidFoam and interDyMFoam would be highly appreciated! Thank you!! |
December 3, 2017, 06:22 |
#405 |
Rep Power: 10 |
Hi, I've got a question concerning the calculated stresses of the Leonov model. Since OF uses kinematic viscosity and kinematic pressure, are the displayed stresses from tau and sigma also divided by rho?
December 25, 2017, 03:35 |
vortex in 3D channel
#406 |
farhad
Rep Power: 8 |
Hello
How can I form a vortex in a square-shaped channel? Or how can I see vortices? In all the papers, a vortex pair is seen at the corners of the channel with the Giesekus model. How can this be modeled with open foam? what is the properties flow ? B.C ? please help me? my Email: farhadhoseinbor@gmail.com Telegram id: @bfzah |
December 25, 2017, 04:10 |
#407 | |
First of all, welcome to CFD-online. Let me explain a little bit when some vortices are formed in fully developed laminar viscoelastic flow. Having corner in the cross section of a channel in fully developed viscoelstic fluid flow results in a pair of elastic vortices. So, in a channel with square cross section we can see eight elastic vortices, very similar to the vortices in the fully developed turbulent flow of a Newtonian fluid in the same geometry. The intensity of these eight vortices in fully developed laminar viscoelastic flow is around 3 percent while in fully developed turbulent flow of a Newtonian fluid it is around 30%. I cannot remember if the Weissenberg number may affect the intensity of these vortices, but I certainly know that non-newtonian model such as Oldroyd-B, power-law, etc cannot simulate these vortices. the boundary conditions are simple. An uniform velocity intet, pressure outlet, and non-slip boundary condition for the walls. The flow should reach the fully developed state in the channel. Just use the viscoelastic properties provided by Jovani in the tutorial case. Have fun Mostafa |
December 25, 2017, 04:36 |
#408 | |
farhad
Rep Power: 8 |
i'm very happy that answer my question's. But I can not do it. All the details that the rest of the researchers did in their previous work, I did. I do not know why I can not see the vortex |
December 25, 2017, 04:45 |
#409 |
farhad
Rep Power: 8 |
this is my file.
December 25, 2017, 05:04 |
#410 |
December 26, 2017, 03:45 |
#411 |
farhad
Rep Power: 8 |
Re=rho*u*D/etha
rho=1000, u=0.2, D=0.02, etha=etha(s)+etha(p)=4 Assume a long channel, but I'm not sure that the flow has been developed! |
December 26, 2017, 04:29 |
#412 | |
Did u assume the flow is steady state? If yes, it is not a concern how the outlet velocity is changing during your simulations. Just let it solve the geometry completely and then draw the secondary flows on a surface at the fully developed section of your duct (NOT at the outlet surface). On the other hand, plotting the secondary flows is tricky, too. You can google it how to draw secondary flows in paraFoam. Good luck! |
December 26, 2017, 05:00 |
#413 | |
farhad
Rep Power: 8 |
thanx |
January 5, 2018, 09:34 |
#414 |
Rep Power: 10 |
Hi, I've got a question about the PISO algorithm used in viscoelasticFluidFoam. The official statement in the OF documentation is that it does not use underrelaxation, but the example cases all implement relaxation factors. I therefore assume that the PISO algorithm has been modified to allow their usage, but is a description available somewhere describing this exactly? Edit: I've found it in the source code, but is there a diagram or other explanation available?
Also, does the solver use the complete Navier Stokes equations or only Stokes? |
January 7, 2018, 11:16 |
#415 |
Hrvoje Jasak
Rep Power: 33 |
The solver solves the Navier-Stokes equations
I do not think you need an entire book just for the fact that PISO under-relaxaes the momentum equation to improve stability. In any case, we are moving to coupled solvers - see recent work from Prof Nobrega. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 8, 2018, 07:19 |
#416 |
Rep Power: 10 |
Great, thank you for your reply Prof. Jasak.
March 4, 2018, 11:52 |
#417 |
farhad
Rep Power: 8 |
How to create a transient fluid flow in the channel?
What conditions are required in a viscoelasticfluidfoam solver to generate a transient fluid flow? |
March 4, 2018, 12:00 |
#418 |
A. Min
Rep Power: 12 |
March 6, 2018, 09:33 |
#419 |
farhad
Rep Power: 8 |
March 24, 2018, 12:34 |
relaxation factors in viscoelasticfluidfoam
#420 |
A. Min
Rep Power: 12 |
Hi foamers
I'm working with viscoelasticfluidfoam. We know that this solver is written based on PISO algorithm and this algorithm doesn't have relaxation factor. So why did they use relaxation factors in many examples of tutorials? What should I do? I'v solved some problems with relaxation factors (e.g. 0.3 , 0.5) and now some of my friends tell me that they are wrong! please help me if you are confident about this issue. |
VOF simulation of a viscoelastic fluid | sinah | OpenFOAM Running, Solving & CFD | 11 | December 25, 2017 04:00 |
FREE SURFACE VISCOELASTIC FLOWS | Valdemir G. Ferreira | Main CFD Forum | 6 | December 18, 2009 07:14 |
Viscoelastic flow modeling in OpenFOAM | vulda | OpenFOAM Running, Solving & CFD | 1 | March 17, 2008 08:32 |
Polyflow & OpenFoam on Viscoelastic flow modeling | Sumeshen | Main CFD Forum | 0 | March 14, 2008 09:29 |
Viscoelastic fluid codes | joel davison | Main CFD Forum | 0 | November 6, 2001 06:09 |
