January 28, 2015, 13:55 |
#381 | |
Rep Power: 14 |
January 28, 2015, 14:02 |
viscoelasticfluidfoam
#382 |
mojtaba
Rep Power: 12 |
Would you help me Hiroshiman casue im new on OpenFoam
January 28, 2015, 14:27 |
#383 |
Rep Power: 14 |
Here is all you need to start:
http://www.openfoam.org/docs/user/ |
February 2, 2015, 14:11 |
viscoelastic extension
#384 |
mojtaba
Rep Power: 12 |
Hi foamers. i want to simulate a viscoelastic fluid flow but i dont know which extension is appropriate for this 1.6ext or 3.1. i could not find any instruction for 1.6 on ubuntu 14.04. can anyone help me?
February 2, 2015, 16:33 |
#385 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
February 3, 2015, 06:49 |
#386 |
mojtaba
Rep Power: 12 |
Thank you so much Bruno and Hirosiman
February 12, 2015, 14:39 |
#387 |
mojtaba
Rep Power: 12 |
Hi Foamers.
Me again. i've already installed foam-extend 3.1 and viscoelastic tutorials run well. but when i change the geometry and update the boundaries of u,p,tau and phi with my new geometry this error shows up: "--> FOAM FATAL IO ERROR: keyword bottom_wall is undefined in dictionary "/home/sepinood/foam/foam-extend-3.1/tutorials/viscoelastic/viscoelasticFluidFoam/Leonov_2/0/p::boundaryField" file: /home/sepinood/foam/foam-extend-3.1/tutorials/viscoelastic/viscoelasticFluidFoam/Leonov_2/0/p::boundaryField from line 25 to line 45. " Note that i generated the geometry and mesh with Gambit and imported in tutorial case with fluentMeshToFoam command. These are my boundary and P file. p dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { cylinder { type zeroGradient; } top_wall { type zeroGradient; bottom_wall { type zeroGradient; } outlet { type fixedValue; value uniform 0; } inlet { type zeroGradient; } frontAndBack { type empty; } } boundary /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 6 ( cylinder { type wall; nFaces 46; startFace 7609; } top_wall { type wall; nFaces 45; startFace 7655; } bottom_wall { type wall; nFaces 45; startFace 7700; } outlet { type wall; nFaces 45; startFace 7745; } inlet { type wall; nFaces 45; startFace 7790; } frontAndBackPlanes { type empty; nFaces 7722; startFace 7835; } ) |
February 12, 2015, 15:31 |
#388 |
dear mojtaba,
you didn't close the bracket in top_wall boundary: Code:
p dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { cylinder { type zeroGradient; } top_wall { type zeroGradient; } bottom_wall { type zeroGradient; } outlet { type fixedValue; value uniform 0; } inlet { type zeroGradient; } frontAndBack { type empty; } } |
February 12, 2015, 16:51 |
#389 | |
mojtaba
Rep Power: 12 |
February 13, 2015, 12:03 |
#390 |
mojtaba
Rep Power: 12 |
Hi dear foamers. I've simulated a viscoelastic fluid with leonov model in a sudden expansion geometry in OF but i am not sure about the final results. I just want to know if there is any source to validate my data. and if any of you foamers have encountered with this problem or maybe solved it, i really want to know how. note that i'm using OF231 and foam-extend 3.1. these are my final results:
p.jpg sigma.jpg u.jpg tau.jpg |
February 14, 2015, 06:12 |
#391 |
Are you sure your solution is converged? it seems that there are some problems in convergence. what are the boundary conditions?
February 15, 2015, 05:12 |
#392 | |
mojtaba
Rep Power: 12 |
so these are my boundaries for P and U. P dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } bottom { type zeroGradient; } top { type zeroGradient; } bottexp { type zeroGradient; } topexp { type zeroGradient; } top2 { type zeroGradient; } bottom2 { type zeroGradient; } outlet { type fixedValue; value uniform 0; } frontAndBack { type empty; } } U dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0.03875 0 0); } bottom { type zeroGradient; } top { type zeroGradient; } bottexp { type zeroGradient; } topexp { type zeroGradient; } top2 { type zeroGradient; } bottom2 { type zeroGradient; } outlet { type zeroGradient; } frontAndBack { type empty; } } |
February 16, 2015, 06:39 |
#393 |
Dear Mojtaba,
Why did you use zero gradient velocity condition on your walls? can you tell me clearly what are u modeling? you can plot the residuals or you can save them in a log file and then see how the residuals change and if your solution is going to converge or not. you should specify a convergence criterion in fvSolution file. for plotting residuals see the below link; http://www.cfd-online.com/Forums/ope...tml#post238091 Regards, Mostafa |
February 16, 2015, 08:21 |
#394 | |
mojtaba
Rep Power: 12 |
Thanks |
February 16, 2015, 09:20 |
#395 | |
If you have a non-slip boundary conditions on your walls so you should specify a zero velocity at each wall. for example: Code:
boundaryField { floor { type fixedValue; value uniform (0 0 0); } . . . Regards, Mostafa |
May 3, 2016, 14:00 |
#396 |
Vitor Dal Bó Abella
Rep Power: 10 |
Does anyone know how to install viscoelasticfluidfoam on the latest openfoam 3.01??
May 4, 2016, 06:57 |
#397 |
Sita Drost
Rep Power: 18 |
I haven't used viscoelasticFluidFoam in a while, but as far as I'm aware, it's part of the OpenFOAM-Extend project: http://www.extend-project.de So if you install OpenFOAM-Extend (instead of, or next to OpenFOAM), viscoelasticFluidFoam should automatically be installed as part of that. Good luck, Sita |
May 11, 2016, 04:48 |
VOF simulation in viscoelastic fluid foam?
#398 |
mehdi
Rep Power: 16 |
Hi Foamers,
I was a user of viscoelasticfluidfoam about 3 years ago but recently have no experience with openfoam. my question is how can I implement a two-phase VOF simulation with Openfoam? is there any released solver which can do it without many difficulties? in addition do anybody know about the existence of this ability in any other softwares like polyflow? Thanks. |
June 13, 2016, 07:47 |
#399 |
ahmed
hello Jovani.
Thank you very much Jovani . these information very helpful . please can you help me in fitting experimental data of flow curve for polymeric melt. Regard |
June 13, 2016, 17:46 |
Divergens problem with shear thinning
#400 |
Hello foamers !
I need your help. I am trying to implement a pressure driven 2D flow in channel with Giesekus model. Geometry, model's parameters and boundary conditions in Geometry.png. My analytical solutions give a great shear thinning (very big shear rate) near boundary/fixedWalls but I cann't achieve this results in OpenFOAM. To be more exact a velocity profile begins to become a desirable form with big shear rate near fixedWalls (velocity.pdf) BUT the solution diverges. And I cann't reach a quantitative accordance. The residual graphic is in Residual.pdf The question is 1) why the problem diverges; 2) how can I avoid it? May be somebody can give me the cue.... I will be happy |
VOF simulation of a viscoelastic fluid | sinah | OpenFOAM Running, Solving & CFD | 11 | December 25, 2017 04:00 |
FREE SURFACE VISCOELASTIC FLOWS | Valdemir G. Ferreira | Main CFD Forum | 6 | December 18, 2009 07:14 |
Viscoelastic flow modeling in OpenFOAM | vulda | OpenFOAM Running, Solving & CFD | 1 | March 17, 2008 08:32 |
Polyflow & OpenFoam on Viscoelastic flow modeling | Sumeshen | Main CFD Forum | 0 | March 14, 2008 09:29 |
Viscoelastic fluid codes | joel davison | Main CFD Forum | 0 | November 6, 2001 06:09 |
