Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
Like Tree44Likes
Old   March 18, 2014, 11:07
Hrvoje Jasak
It runs fine here, the last change was
commit 6b50e03f4417291ba2c9184244d37e2630ef2dae
Author: Henrik Rusche <h.rusche@wikki-gmbh.de>
Date: Thu Dec 12 00:41:18 2013 +0100
Below is the fvSolution file:
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.0 |
| \\ / A nd | Web: http://www.extend-project.de |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
p
solver PCG;
preconditioner Cholesky;
tolerance 1e-07;
relTol 0;
minIter 0;
maxIter 800;
U
solver BiCGStab;
preconditioner ILU0;
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
tau
solver BiCGStab;
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
relaxationFactors
p 0.3;
U 0.5;
tau 0.3;
Hrvoje Jasak
Old   March 18, 2014, 11:33
Sita Drost
sita is on a distinguished road
Thanks for the information. How can I check what my last change was?
sita is offline   Reply With Quote
Old   April 1, 2014, 04:38
Sita Drost
OK, I give up: last Thursday I installed foam-extend-3.0 from source, tested it on the Oldroyd-B tutorial, AND IT WORKED!!! No problems with finding the Cholesky preconditioner or anything.
So today I tried to run a case of my own, but now suddenly foam seems to have forgotten everything it knew previously and it gives the same error I got earlier, about Cholesky being an unknown preconditioner. WHY?? I didn't change anything, as far as I know. Anyone?
Old   May 13, 2014, 11:46
Unhappy
  #344
litao
yxiong is on a distinguished road
i have the same problem,when i try smenon's example in the extend-3.0:
--> FOAM FATAL IO ERROR:
Unknown asymmetric matrix preconditioner Cholesky
Valid asymmetric matrix preconditioners are :
7
AMG
none
GAMG
diagonal
SymGaussSeidel
ILU0
DILU
file: /home/yxiong/FileOfYxiong/projectile/system/fvSolution::solvers::U from line 82 to line 90.
From function lduPreconditioner::New
const lduMatrix& matrix,
const FieldField<Field, scalar>& coupleBouCoeffs,
const FieldField<Field, scalar>& coupleIntCoeffs,
const lduInterfaceFieldPtrsList& interfaces,
const dictionary& dict
in file matrices/lduMatrix/lduMatrix/lduMatrixPreconditioner.C at line 141.
FOAM exiting
sita,did you have solved your problem?tell me,thank you!
yxiong is offline   Reply With Quote
Old   May 13, 2014, 12:01
Hrvoje Jasak
Just change the name from Cholesky to ILU0.
Hrvoje
Hrvoje Jasak
Old   May 13, 2014, 22:18
Smile
  #346
litao
Hrvoje
Thank you very much,Mr Hrvoje Jasak,it seems very nice now!
Old   May 14, 2014, 01:54
Sita Drost
Sorry, no, I haven't found a solution yet, maybe the Cholesky preconditioner just disappeared? Although some time ago I saw a post by Hvorje Jasak, who didn't have problems with Cholesky. I switched to using PAMG instead of Cholesky, that works.
Old   May 21, 2014, 06:45
Default divTau
  #348
Raymond.Leoi is on a distinguished road
I suppose the divergence of (tau_p + tau_s) should be returned for the momentum equation. However in the viscoelastic foam, it is
fvc::div(tau_/rho_, "div(tau)")
- fvc::laplacian(etaPEff/rho_, U, "laplacian(etaPEff,U)")
+ fvm::laplacian( (etaPEff + etaS_)/rho_, U, "laplacian(etaPEff+etaS,U)")
It is not identical to div(tau_/rho_ + tau_s), isn't it?
Raymond.Leoi is offline   Reply With Quote
Old   May 21, 2014, 13:25
Hrvoje Jasak
I am sorry: did you read the paper describing the methodology?
Hrvoje Jasak
Old   May 21, 2014, 18:39
what's the paper?
Old   May 22, 2014, 02:29
Hrvoje Jasak
Apologies: paper.
Hrvoje Jasak
Old   May 22, 2014, 05:24
I've gone through some papers for the theory. What paper do you mean, Hjasak?
Apologies: paper.
Old   May 22, 2014, 06:01
Hrvoje Jasak
Usually when I work on something in FOAM, there are papers published with the methodology, numerics and validation results.
Try googling Favero Jasak viscoelastic, or
http://scholar.google.co.uk/scholar?...ed=0CCUQgQMwAA
Does this help?
Hrv
Hrvoje Jasak
Old   May 22, 2014, 06:19
Cheers, Hrv. No luck. Anyway, I suppose that divTau is the key for the viscoleastic solver no matter what model it is. Anyone dig this part?
Does this help?
Hrv
Old   May 22, 2014, 07:59
Default Convection term in viscoelasticFluidFoam solver
  #355
Heliana Cardenas
heliana60 is on a distinguished road
Hi Hrvoje,
I am using a model similar to the White Metzner-Larson model in the visco solver, I want to study shear thinning.
I am studying star-up flow in a 2D channel.
The model looks like this:
fvSymmTensorMatrix tauEqn
fvm::ddt(tau_)
+ fvm::div(phi(), tau_)
etaP_/lambda_*twoD
+ twoSymm(C)
- fvm::Sp(1/lambdaM, tau_)
where:
lambdaM = (lambda_*gammaC_/(gammaC_+lambda_*sqrt(0.5)*mag(twoD)))
In few words, the relaxation time is in function of the shear rate (my gammaC_ is 0.1)
When I do this, the centerline velocity acts like if it was a almost a newtonian fluid, and it doesn't reach the steady state (analytical results).
I checked also the nonNewtonian and Newtonian stress on time at a quarter of the channel and it is like \tau_ doesn't "change" anymore with time, though the newtonianStress does.
I am attaching here the plot of the nonNewtonian and Newtonian shear stress at quarter of the channel vs time, so you can see how it actually goes.
If I actually remove the convective term (I was just trying to see what was affecting the costitutive equation), my results reach steady state.
How can this convective term affect my model, so when I use it it doesnt reach steady state like expected?
Thanks,
Heliana
heliana60 is offline   Reply With Quote
Old   July 23, 2014, 05:35
Default FENE model parameters
  #356
Sita Drost
Dear Jovani,
In your FENE-P and FENE-CR models, the values of etaS and etaP should be specified. What do these parameters mean physically? My first guess would be that etaS + etaP = eta_eff (i.e. effective viscosity of the solution = solvent viscosity + polymer contribution), but in the FENE-CR code, you use an eta_eff that's defined as eta_eff = etaP. So, is etaP then the viscosity of the polymer solution?
Thanks in advance for helping me out,
Sita
Old   July 31, 2014, 02:21
Ron
ron_OFuser is on a distinguished road
How to calculate drag coefficient on a cylinder for viscoelastic fluid?
ron_OFuser is offline   Reply With Quote
Old   July 31, 2014, 04:11
Sita Drost
Hi Ron,
Maybe this helps?
Viscoelastic flow past a cylinder: drag coefficient. Nhan Phan-Thien & Hua-Shu Dou (1999). Computer Methods in Applied Mechanics and Engineering, 180 (3-4), pp. 243-266.
Good luck,
Sita
Old   July 31, 2014, 05:20
Ron
Thank you Sita for the same.
Do you know how would I implement the drag coefficient equation for these fluids in OpenFOAM?
Old   July 31, 2014, 08:10
Ron
Anyone?
Any idea for the above post on implementation of drag coefficients for viscoelastic fluids?
VOF simulation of a viscoelastic fluid sinah OpenFOAM Running, Solving & CFD 11 December 25, 2017 04:00
FREE SURFACE VISCOELASTIC FLOWS Valdemir G. Ferreira Main CFD Forum 6 December 18, 2009 07:14
Viscoelastic flow modeling in OpenFOAM vulda OpenFOAM Running, Solving & CFD 1 March 17, 2008 08:32
Polyflow & OpenFoam on Viscoelastic flow modeling Sumeshen Main CFD Forum 0 March 14, 2008 09:29
Viscoelastic fluid codes joel davison Main CFD Forum 0 November 6, 2001 06:09
