August 21, 2013, 21:03 |
#281 |
胡长旭
Rep Power: 13 |
Hi, Thanks a lot. I have solved my question. I am so glad with your help. Thanks again! but now another question is appear. When I calculating the example of viscoelasticFluidFoam, I run this program, code: viscoelasticFluidFoam > log & the results show that: FOAM FATAL TO ARROR: Unkown asymmetric matrix solver BICGSTAB Valid asymmeyric matrix solvers are: ......... what is wrong? Have a nice day! |
August 21, 2013, 22:14 |
#282 | |
I didn't hear before about BICGSTAB matrix solver. go to solutionDict and look for which equation you used BICGSTAB solver. change it to a asymmetric matrix solver. it had guid you and had awared you about valid solvers in the last error. |
August 22, 2013, 03:58 |
#283 | |
胡长旭
Rep Power: 13 |
Have a nice day! |
August 23, 2013, 03:05 |
the same
#284 | |
k zhang
Rep Power: 14 |
How can i get the parameters of the Giesekus Model about one melt through rheological experiments, like etaS, etaP, alfar, lambda. I want to fit the parameters through the polymat module. |
August 23, 2013, 12:13 |
ViscoelasticInterFoam
#285 |
Erick Lorenzato
Rep Power: 13 |
Hello everyone,
I'm working with viscoelastic fluids in my thesis and i need compile viscoelasticInterFoam Jovani sent me the files. They were: Case (the turorial); Solver (Tutorial - Make folder with; viscoelasticTwoPhaseModels - folder with make, and viscoelasticLaws viscoelasticModel). I tried to install them as the tutorial viscoelasticFluidFoam (http://lists.cfd-online.com/pipermai...er/029862.html). So I can not. Is generating a lot of mistakes. Anyone have any tutorial or way to install it? I put the folders as viscoelasticFluidFoam, but when I do the command Wmake libso && && cd - Generates this error root @ admin-desktop: ~ / OpenFOAM/OpenFOAM-1.6-ext/src/transportModels/viscoelastic viscoelasticTwoPhaseModels # cd / && wmake libso && cd - wmakeLnInclude: linking include files to. / lnInclude make: *** No rule to make target `viscoelasticLaws / DCPP / DCPP.dep ', needed by` Make/linux64GccDPOpt/dependencies'. Stop. Thanks in advance! Erick |
August 26, 2013, 09:31 |
#286 | |
Sita Drost
Rep Power: 18 |
In constant/viscoelasticProperties, you just need to remove the "type multiMode" part and only define one mode. It's all rather straightforward, and I think you can even check the viscoelasticProperties-files in the tutorials; there are both single- and multi-mode tutorials. Furthermore, you need to substitute the taufirst, tausecond, etc. files under 0/ with a single tau file. Good luck, Sita |
August 26, 2013, 09:53 |
#287 | |
Sita Drost
Rep Power: 18 |
I think you should start with a basic rheology textbook. Some good ones are: Dynamics of Polymeric Liquids (Part I and II), by Bird, Armstrong and Hassager, Rheology: Principles, Measurements and Applications, by Macosko, and An Introduction to Rheology, by Barnes, Hutton and Walters. Also very instructive: Constitutive Equations for Polymer Melts and Solutions, by Larson. Good luck, Sita |
August 26, 2013, 10:18 |
#288 | |
Rep Power: 14 |
August 26, 2013, 11:47 |
Weird inlet flow
#289 |
Rep Power: 14 |
I ran a case w/ cylinder using Oldroyd-B model and specified the fully-developed velocity profile for the inlet and zeroGradient for outlet. The velocity magnitude and streamline was shown in the attache snapshot. It's quite weird to see two circulation zones near the inlet. Any idea for this problem?
August 26, 2013, 22:50 |
#290 | |
salame ama
Rep Power: 14 |
Hi, sita: Thanks! These days, i read some books you recommanded. If take the single-modle, I think just the alfar should be fitted. is that right? Great regards! salame |
August 27, 2013, 21:08 |
#291 |
胡长旭
Rep Power: 13 |
Hello, everyone!
Did anyone who used the S-MDCPP model in the OpenFoam. When I using this Model, the result is not good! maybe it is not converage! What is wrong ? Thanks! |
August 27, 2013, 21:13 |
#292 |
胡长旭
Rep Power: 13 |
Hi ,
Did you use the S-MDCPP model in the OpenFoam. When I using this model , the result is poor! Thanks |
August 28, 2013, 08:08 |
#293 |
Rep Power: 14 |
August 28, 2013, 21:28 |
#294 |
胡长旭
Rep Power: 13 |
Hi, Thanks for youe reply!
When I employing the S-MDCPP model to do this case, and I transfer the result file to Tecplot360, the result is serious. For example, U P and Tau. I think the pattern is not steady! Thanks a lot! |
August 29, 2013, 00:46 |
#295 |
how about the residuals and convergence?
August 29, 2013, 03:12 |
#296 |
胡长旭
Rep Power: 13 |
Hi
I used the default file. for p is 1*10-7, and for tau and U is 1*10-6. The controlDict file is also default. Thanks |
August 29, 2013, 03:13 |
#297 |
胡长旭
Rep Power: 13 |
August 29, 2013, 06:31 |
#298 |
August 29, 2013, 20:58 |
#299 |
胡长旭
Rep Power: 13 |
August 31, 2013, 21:58 |
About the S-MDCPP model
#300 |
胡长旭
Rep Power: 13 |
Hi, everyone
When I using the S-MDCPP model by the default to solve my question, The results of U, P and tau is serious. the pattern is riots. What is wrong with this problem? Maybe you can run it, and check the result. Can anyone help me with this question? Thanks a lot best wishes Have a nice day |
VOF simulation of a viscoelastic fluid | sinah | OpenFOAM Running, Solving & CFD | 11 | December 25, 2017 04:00 |
FREE SURFACE VISCOELASTIC FLOWS | Valdemir G. Ferreira | Main CFD Forum | 6 | December 18, 2009 07:14 |
Viscoelastic flow modeling in OpenFOAM | vulda | OpenFOAM Running, Solving & CFD | 1 | March 17, 2008 08:32 |
Polyflow & OpenFoam on Viscoelastic flow modeling | Sumeshen | Main CFD Forum | 0 | March 14, 2008 09:29 |
Viscoelastic fluid codes | joel davison | Main CFD Forum | 0 | November 6, 2001 06:09 |
