Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
Like Tree44Likes
Old   July 22, 2013, 04:33
Sita Drost
sita is on a distinguished road
Thanks, that seems to help!
hcx552362 likes this.
sita is offline   Reply With Quote
Old   July 22, 2013, 04:51
Sita Drost
Originally Posted by Raymond.Leoi View Post
In terms of an example of Verbeeten's data as shown in the attached snapshot, how to get the viscoelastic models' parameters such as etaS, etaP etc.?
Dear Raymond,
etaP = G*lambda = given in the table
etaS = solvent viscosity, you don't need that for a melt (the data in the table is for an LDPE melt). If you still need some value, you could try zero or some very small value.
Everything else you need is given in the table, it seems.
Good luck,
Sita
Old   July 22, 2013, 08:34
Raymond.Leoi is on a distinguished road
I see, Sita. Many thanks.
Originally Posted by sita View Post
Dear Raymond,
Good luck,
Sita
Raymond.Leoi is offline   Reply With Quote
Old   July 23, 2013, 17:48
Default viscoelasticInterFoam
  #264
mohamadreza
mohamadreza89 is on a distinguished road
Hi Jovani
I'm master student and for my thesis I need viscoelasticInterFoam solver, If you can help me I'm so glad,
mohammadreza
mohamadreza89 is offline   Reply With Quote
Old   July 23, 2013, 22:18
salame ama
salame is on a distinguished road
Hi, Sita:
The parameters which can get like you say are important to me, too. Thank you for your explain in details.
salame
Dear Raymond,
Good luck,
Sita
salame is offline   Reply With Quote
Old   July 24, 2013, 20:39
Unhappy About the N1
  #266
k zhang
skykzhang is on a distinguished road
i am interested in the viscoelasticFluid. But i feel uncerain about the N1, PSD and so on. ( N1=σ11-σ22) .
Like: If the N1 is greater , is that means the elastic characteristic of the poly melt powerfuler? Can someone help me clearly know the question? Or recommand any books or journals about these issues.
Best regards!
skykzhang is offline   Reply With Quote
Old   July 28, 2013, 16:36
Unhappy
  #267
mohamadreza
Hi friend,
can anyone help me to find viscoelasticInterFoam solver to simulate free surface problem?
thanks alot,
Old   July 29, 2013, 02:52
Sita Drost
Originally Posted by mohamadreza89 View Post
Hi friend,
thanks alot,
Dear Mohamad,
I think the viscoelasticInterFoam solver is not available for everyone yet. Last thing I heard was that Jovani was still working on it. Maybe you could contact him personally?
Best,
Sita
Old   July 29, 2013, 12:06
There are four modes for the default PTT-Exponential. If only one mode is concerned, how to disable the rest higher modes?
Old   August 13, 2013, 15:46
Exclamation icofoam nu , viscoelasticfluidfoam rho
  #270
ali jafari
ali jafari is on a distinguished road
hi
I solved a problem for Newtonian and decided to compared it with viscoelastic
so I need similar properties such as viscosity and density. in other hand B.Cs for P are cyclic.
is nu(newtonian.icoFoam)=(etaS+etaP)/rho(visco.) ? I think , these are not equal !!!
whats your idea ?
ali jafari is offline   Reply With Quote
Old   August 13, 2013, 16:52
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Originally Posted by ali jafari View Post
hi
whats your idea ?
Hi dear ali
In viscoelastic fluid, the summation of solvent and polymer viscisity is total viscosity that should be concider to calculate Re Number.
in netonian case, lambda should be near to zero. I suggest to set 10e-08 for this .
Best
desert_1250 is offline   Reply With Quote
Old   August 14, 2013, 07:20
Exclamation
  #272
ali jafari
Originally Posted by desert_1250 View Post
Hi dear ali
Best
thanks for useful and quick reply.
I want to know too , what should be I do for modeling a fluid properties that applied in icoFoam by viscoelasticfluidfoam .(specially about density nu(newtonian.icoFoam)=(etaS+etaP)/rho(visco.) !!!)
Old   August 14, 2013, 07:51
s.rasoul_varedi
Hi again
i hopethat get your mean correctly, ENSHA ALLA
nu is kinematic viscosity, divided solvent viscosity to density.
Note! polymer viscosity should be considered zero in Newtonian case.
Best
Old   August 14, 2013, 09:32
Red face questions
  #274
ali jafari
Hi again
Best
your explain come back to viscoelastic solver I understood it. my problem is about icoFoam. please help me , I have 4 questions :
1) icoFoam results and viscoelasticfluidfoam are different at a unique fluid. and do the difference refer to density role?( I vanished polymer effect in my case by decreasing lambda and other viscoelastic properties)
2) and how do I fix it?
3) I need nu for icofoam and eta , rho for viscoelastic solver (eta/rho = nu *true/false*?) .
4) (if #3 is false) is there a utilities that can present density of a case solved by icoFoam ?
thanks again and good luck.
Old   August 20, 2013, 06:04
胡长旭
hcx552362 is on a distinguished road
Originally Posted by sandipd View Post
Hi Foamers,
I followed this procedure and it is working fine nw -
1) The ported version of the viscoelasticFluidFoam solver downloaded from - http://sourceforge.net/projects/vffof21x/. And then extracted to /user/home/ folder. It had 3 directories and 1 file inside, which needs to put into the right place of openfoam dir. Mainly, the 'src' directory need to be in the right place because the compilation of the solver search for this inside src/transportModels, i.e. -
a) Copied 'src/transportModels/viscoelastic/' directory to 'opt/openfoam201/src/transportModel' directory.
b) Copied 'applications/solvers/viscoelastic/viscoelasticFluidFoam/' directory to 'opt/openfoam201/solver' directory.
c) Copied 'tutorials/viscoelastic' directory to 'opt/openfoam201/tutorials' directory.
d) Copied the file 'wmakeViscoelasticFluidFoam' to 'opt/openfoam201/wmake' directory.
2) The source with system files and compilation done with -
a) The source file linking to the solver directory can be generated by -
'cd opt/openfoam201/src/transport models/viscoelastic/&& wmake libso && cd -'
b) The solver directory need to be compile, and it can be done by -
'cd opt/openfoam201/applications/solvers/viscoelastic/viscoelasticFluidFoam/ && wmake && cd -'
c) The recompilation of Openfoam directory was needed, and it is done by -
'cd opt/openfoam201$ ./Allwmake
Note : It will recompile whole openfoam directory (including viscoelasticFluidFoam) and end up
with - '/opt/openfoam201/platforms/linux64GccDPOpt/bin/viscoelasticFluidFoam' is up to date.
hence, it is done..!!!
hi amin144
how did you solve your question about step 2. now i face it and I need your help ! thangks a lot
hcx552362 is offline   Reply With Quote
Old   August 20, 2013, 06:14
胡长旭
Originally Posted by jovani View Post
Hello Foamers,
My name is Jovani and I want announce that will soon be available a solver for treatment of viscoelastic fluid in OpenFOAM. I was working in the development of a viscoelasticFluidFoam solver (with the great orientation of the Dr. Hrvoje Jasak, thank you very much Hrvoje!!) to simulate viscoelastic flows.
The follow models are implemented: Maxwell, Oldroyd-B, Giesekus, PTT linear and exponential,
FENE-P, FENE-CR and DCPP. There are others models already implemented but not tested (Pom-Pom, SXPP, DXPP, WM ...).
The metodology used to obtain solutions in high We numbers was the DEVSS. The test geometry was mainly the 4:1 planar contraction. The solver are able to simulate multimode cases with n modes.
For the interested: A presentation that will soon be available on line to give more informations.
Jovani
hi jovani:
now i have installed the openfoam 2.1.1 succeed, of course i download your new viscoelasticFluidFoam files. but i do not kown how to add it in the openfoam. I think you can help me. Thanks a lot .
Have a nice day
Old   August 20, 2013, 06:57
胡长旭
Hi sita
Have a nice day
Old   August 20, 2013, 08:57
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Originally Posted by hcx552362 View Post
Hi sita
Have a nice day
just extract it in $WM_PROJECT_DIR and make sure that the wmakeViscoelasticFluidFoam file is exist in this directory.
then:
./wmakeViscoelasticFluidFoam
adambarfi is offline   Reply With Quote
Old   August 21, 2013, 05:12
Post viscoelastic
  #279
胡长旭
then:
Hi, adambarfi;
Thanks for your reply, i follow your advise, but it does not work. can you give me more information, Thanks a lot
Have a nice day!
Old   August 21, 2013, 05:44
adambarfi's Avatar
Mostafa Mahmoudi
Hi, adambarfi;
Have a nice day!
what do you mean of 'it doesn't work'?
any error?
VOF simulation of a viscoelastic fluid sinah OpenFOAM Running, Solving & CFD 11 December 25, 2017 04:00
FREE SURFACE VISCOELASTIC FLOWS Valdemir G. Ferreira Main CFD Forum 6 December 18, 2009 07:14
Viscoelastic flow modeling in OpenFOAM vulda OpenFOAM Running, Solving & CFD 1 March 17, 2008 08:32
Polyflow & OpenFoam on Viscoelastic flow modeling Sumeshen Main CFD Forum 0 March 14, 2008 09:29
Viscoelastic fluid codes joel davison Main CFD Forum 0 November 6, 2001 06:09
