Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
Like Tree44Likes
Old   September 13, 2012, 16:25
Amin Shariat KHah
amin144 is on a distinguished road
my problem solved by using "sudo bash" in my account terminal
now when I type these two lines:
cd src/transportModels/viscoelastic/ wmake libso && cd -
cd applications/solvers/viscoelastic/viscoelasticFluidFoam/ wmake && cd -
it says:
is up to date
but when I want to run the tutorials, It say:
Starting time loop
Courant Number mean: 6.54561e-07 max: 1.84912e-05
deltaT = 1.19999e-05
Time = 1.19999e-05
--> FOAM FATAL IO ERROR:
Unknown asymmetric matrix solver BiCGStab
Valid asymmetric matrix solvers are :
4
BICCG
GAMG
PBiCG
smoothSolver
file: /home/amin/OpenFOAM/amin-2.1.1/run/tutorials/viscoelastic/viscoelasticFluidFoam/Oldroyd-B/system/fvSolution::solvers::U from line 47 to line 56.
From function lduMatrix::solver::New
in file matrices/lduMatrix/lduMatrix/lduMatrixSolver.C at line 106.
FOAM exiting
I don't know Can I see I have new working OpenFOAM at last?
amin144 is offline   Reply With Quote
Old   September 13, 2012, 16:36
Amin Shariat KHah
I understand the problem!
It seems I should modify the tutorials according to OF2.1.1
But I can't do it completely because I don't know meaning of many expressions.
I can run the case but I don't know what is the best solver and preconditioner to use instead of old ones???
Anybody could upload a modified tutorial?
TanX very much
Old   September 14, 2012, 02:39
sandip desai
sandipd is on a distinguished road
Hay, you just refer the previous posts by Jovani and ata; i.e. you need make changes in fvSolution to change the solvers and preconditioner for p, U and tau.
1) For pressure you can use solver 'PCG', preconditioner 'DIC'
2) For U and tau use the solver 'PBiCG' and preconditioner 'DILU'..
Re,
amin144 and boldzman like this.
- Sandip Desai
sandipd is offline   Reply With Quote
Old   October 4, 2012, 02:45
sandip desai
Hi friends,
Anybody has worked for a blow molding problem using openFoam ( specially viscoelasticFluidFoam)? .. I am working on it, and needs the support for implementation with openfoam..
Thanks & Regards,
Sandip.
- Sandip Desai
Old   October 8, 2012, 07:42
Default What does tau mean? total or polymer?
  #205
Amin Shariat KHah
Hi dear FOAMers
I have basic questions, maybe very amateur questions.
1)What is tau in models like Giesekus? It's total stress or extra stress?
2)If I want calculate wall stress, can I use the utility "wallShearStress" or this give me only Newtonian part of stress?
3)what is best way to calculate eta and shear rate and plot diagram of them according to each other?
Best regards,
Amin
Old   October 9, 2012, 01:11
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody,
I'm trying to solve natural convection in a viscoelastic fluid. I added the temperature equation and Buossinesq assumption to the viscoelasticFluidFoam, but when I ran it after sum iteration the below errors appeared:
DICPCG:  Solving for p, Initial residual = 1, Final residual =  6.72375e-08, No Iterations 62
time step continuity errors : sum local =  4.77002e+25, global = -9.93552e+15, cumulative = -9.93552e+15 Model mode  1
#0  Foam::error::printStack(Foam::Ostream&) in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"  #1
Foam::sigFpe::sigHandler(int) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::PBiCG::solve(Foam::Field<double>&,  Foam::Field<double> const&, unsigned char) const in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4  Foam::fvMatrix<Foam::SymmTensor<double>  >::solve(Foam::dictionary const&) in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#5  Foam::fvMatrix<Foam::SymmTensor<double> >::solve() in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#6  Foam::Giesekus::correct() in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#7  Foam::multiMode::correct() in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#8  Foam::viscoelasticModel::correct() in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#9    in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/BuoyantBoussinesqViscoelasticFluidFoam"
#10  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #11    in  "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/BuoyantBoussinesqViscoelasticFluidFoam"
Floating point exception
anybody knows how can I solve this problem?
adambarfi is offline   Reply With Quote
Old   October 9, 2012, 07:54
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
To Amin
1- AFAIK it is extra stress tensor.
3-You can calculate them using fvc:: and write them in a file and then plot it.
To Adambarfi
Examine my previous mentioned tips one by one.
ata is offline   Reply With Quote
Old   October 9, 2012, 10:28
adambarfi's Avatar
Mostafa Mahmoudi
Dear Ata,
which tips?
I attach the fvScheme and fvSolution for you. please comment on them.
thank you so much.
Old   October 9, 2012, 11:02
ata
ata's Avatar
ata kamyabi
Hi
How much is your max. Courant number and delta T?
Old   October 9, 2012, 13:30
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by ata View Post
Hi
ohh!!! my God!!
the max Cournat number was 0.8.
I decreased it to 0.25 and my solver worked correctly. the delta T was 1.
Thank you Ata, I had forgotten the Cournat number, completely.
Old   October 9, 2012, 15:52
Amin Shariat KHah
Hi
To Amin
To Adambarfi
Dear Ata!
TanX for your quick reply.
Don't you know anuthing about WallShearStress?
If I want total shear stress, would I sum shear stress given from wallShearStress utility and what is in tau matrix?
I thought everybody know about computing wall shear stress very well and it' easy problem.
Old   October 10, 2012, 06:21
ata
ata's Avatar
ata kamyabi
Hi Amin
Unfortunately I have no experience in your problem. See the OF utilities. May be you can find a useful function.
Old   October 10, 2012, 07:54
Amin Shariat KHah
Hi Amin
TANX very much dear Ata
I appreciate your attention
I wish Jovani come here soon
Old   October 24, 2012, 07:14
Jovani L. Favero
jovani is on a distinguished road
Send a message via Skype™ to jovani
Hi Amin,
I never needed this yet. A possible way: If you have solvent viscosity (etaS != 0) sum up the solvent and polymer stress to get the total stress. The polymer is just tau returned back by the solver. So, create an utility to calculate solvent stress and sum up it with polymer stress and return the total stress as a post processing stage. When you got the total stress adapt the wallShearStress utility to return the wall shear stress for tauTotal instead of Reff.
Regards,
Jovani
amin144 and skykzhang like this.
jovani is offline   Reply With Quote
Old   October 30, 2012, 03:24
adambarfi's Avatar
Mostafa Mahmoudi
Hi to all,
anybody knows why my max. velocity in natural convection increased instead of dropping when I increased the relaxation time in Giesekus model?
thank you.
Old   November 3, 2012, 15:28
Default To turn-Off the stabilising technique (DEVSS) in the in the viscoelasticFluidFoam
  #216
Samir
samegypt is on a distinguished road
Dear Foamers
Kindly, I have two question,
1- if I want to turn-Off the stabilising technique (DEVSS) used in the viscoelasticFluidFoam solver , I will go to the the viscoelastic model for example the Oldroyd_B Model to modify the following lines (located at /OpenFOAM/OpenFOAM-2.1.0/src/transportModels/viscoelastic/viscoelasticLaws/Oldroyd-B/Oldroyd_B.C), Is that corrector wrong?
Foam::tmp<Foam::fvVectorMatrix>
Foam::Oldroyd_B::divTau(volVectorField& U) const
dimensionedScalar etaPEff = 0; //turn-On DEVSS, put etaPEff = etaP_
return
fvc::div(tau_/rho_, "div(tau)")
- fvc::laplacian(etaPEff/rho_, U, "laplacian(etaPEff,U)")
+ fvm::laplacian( (etaPEff + etaS_)/rho_, U, "laplacian(etaPEff+etaS,U)")
2- For activating the above lines in the Oldroyd_B.C Model, I will only save and close the file. Is that enough? or I also need to make recompilation of Openfoam directory by using the command line ./Allwmake
Thanks
samegypt is offline   Reply With Quote
Old   November 4, 2012, 05:49
ata
ata's Avatar
ata kamyabi
Hi
I think you only need to recompile oldroyd-b model library.
Old   November 4, 2012, 05:58
Samir
Hi
Dear Ata, thanks for your reply,
Please, what is the steps to recompile the oldroyd-b model library?
thanks
Old   November 4, 2012, 06:11
ata
ata's Avatar
ata kamyabi
Hi
Jovani has replied to this question in the previous posts (I asked from him) in this thread. See that.
Old   November 6, 2012, 14:22
Default viscoelastic implementation of EVSS methodology
  #220
Samir
Originally Posted by jovani View Post
First thank you Hrvoje!!
EVSS is very different, once is needed a change on the constitutive equation (in my master thesis is very clear this point).
And more, I tested the EVSS methodology too (I have an old solver with this implementation), but really what you have in hands
today with viscoelasticFluidFoam is much higher.
Dear Jovani,
I am interested to implementation the EVSS methodology in my viscoelastic code, is it possible to ask you to send me your old EVSS solver.
regards,
Samir
VOF simulation of a viscoelastic fluid sinah OpenFOAM Running, Solving & CFD 11 December 25, 2017 04:00
FREE SURFACE VISCOELASTIC FLOWS Valdemir G. Ferreira Main CFD Forum 6 December 18, 2009 07:14
Viscoelastic flow modeling in OpenFOAM vulda OpenFOAM Running, Solving & CFD 1 March 17, 2008 08:32
Polyflow & OpenFoam on Viscoelastic flow modeling Sumeshen Main CFD Forum 0 March 14, 2008 09:29
Viscoelastic fluid codes joel davison Main CFD Forum 0 November 6, 2001 06:09
