Convective outlet boundary condition for Unsteady flows |
August 17, 2012, 22:43 |
#101 |
Well,
Well I tried waveTransmissive BC. I have somewhat similar case which Daniel has talked about in some previous posts (O mesh for a simulation over a cylinder). waveTransmmissive BC seems to work for me with LES but I don't know how to justify it. I don't completely understand the mathematics involved. In OF documentation it says that it is supposed to work with involving shocks (specially supersonic). If you see the pitzDaily tutorial for LES in rhoPimpleFoam it also uses the waveTransmissive BC. I don't understand that under which circumstances this waveTransmissive BC would be more appropriate or attractive for a simulation. I don't need the whole explanation, but some pointer in terms of physics (not mathematics) could help me a lot. Regards, Awais |
August 28, 2012, 13:11 |
#102 |
saeid oqaz
Rep Power: 14 |
hi.
any body know convective outlet B.C work with openfoam 1.6 ext? thanks |
August 28, 2012, 14:13 |
#103 |
saeid oqaz
Rep Power: 14 |
this B.C compile with no error on openfoam 1.6.ext. work fine for me
September 18, 2012, 23:53 |
#104 |
Albert Tong
Rep Power: 16 |
Hi Foamers,
Can anyone post a new version of the convective outlet b.c. again (works in in 1.6 or 1.7+++)? It seems the previous links are out of date and cannot be downloaded. Thanks very much.
Kind regards, Albert |
October 9, 2012, 17:24 |
#105 | |
Mohsen KiaMansouri
Rep Power: 16 |
you can download the original Takuya code from the post #36 just rename the file to .tar after download & extract it askjak also changed this code for OF 1.5 ++ that you can download from the post #77 including pitzDaily test case All the download links work fine for me |
October 9, 2012, 18:02 |
#106 | |
Mohsen KiaMansouri
Rep Power: 16 |
Thanks for sharing your code I have seen the page: potentialWaveFoam that you created in the folllowing url: http://openfoamwiki.net/index.php/Co...entialWaveFoam which has convectiveOutlet-YYYYMMDD/ a convection BC code inside it I have some questions: 1) is it the same code that you have posted in here? because it requires username&password for downloading it from: https://www.openacoustics.org/svn-re...entialWaveFoam can you attach it here in the foroum? 2)I have read all the posts regarding OpenFOAM advective outlet B.C. in this thread and other posts but I still have some doubts: 2-1) can we use advective outlet B.C. instead of convective outlet B.C. for incompressible flows? 2-2) is it reliable? 2-3) is there any example in the OpenFoam tutorial or other sources that can help us adjusting the related parameters for using this B.C.? Best Regards |
February 18, 2013, 08:41 |
#107 |
Hrushi
Rep Power: 13 |
Hi All,
I am a noob in Openfoam. Could any of you explain me how this convective boundary condition code exactly works? I tried going through it a number of times, but I could not figure out where does the d/dt term come from and where does the gradient term comes from? Thanks and regards, Hrushikesh |
July 3, 2013, 10:46 |
#108 |
Ehsan
Rep Power: 27 |
in which situations this BC(Convective BC) is applicable?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
July 3, 2013, 10:57 |
#109 |
Ehsan
Rep Power: 27 |
and can it be used for OpenCFD Ltd version too?
November 28, 2016, 11:53 |
boundary condition for Blade-plane configuration
#110 |
Sachin
Rep Power: 10 |
Hello all,
I am new in openfoam. I would like to implement boundary condition for Blade-plane configuration in electrostatic problem. I want to implement potential value V= sin(2*π*f*t) at inlet. Can anyone help me for this problem. Thank you. |
convective boundary condition | Mani | CFX | 8 | March 21, 2017 10:59 |
Convective boundary condition | andrea_barbera | OpenFOAM Running, Solving & CFD | 4 | March 4, 2010 05:36 |
Convective Boundary Condition | garni | FLUENT | 0 | September 25, 2005 14:00 |
Convective boundary condition | STN | Main CFD Forum | 5 | May 29, 2002 09:47 |
convective boundary condition | frederic felten | Main CFD Forum | 1 | April 25, 2001 02:20 |
