March 6, 2009, 04:05 |
Hi Vishal,
can you give me
#41 |
Tian
Rep Power: 17 |
Hi Vishal,
can you give me a hint where did you find in the OpenFOAM code T.relax()? Thanks Bye Thomas
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance. |
March 6, 2009, 08:28 |
Hello Thomas
it seems that
#42 |
Leonardo Honfi Camilo
Rep Power: 17 |
Hello Thomas
it seems that I got here a little late, the link that you have posted has reached its limit, could you perhaps mail me the file? thanks leo |
March 6, 2009, 08:40 |
try this one:
http:/
#43 |
Tian
Rep Power: 17 |
March 6, 2009, 08:47 |
thanks
#44 |
Rep Power: 17 |
thanks
March 6, 2009, 12:40 |
Hi Tian,
I found such a rel
#45 |
Vishal Nandigana
Rep Power: 18 |
Hi Tian,
I found such a relaxation technique mentioned by Prof Hrv.. in this forum I would like to know precisely what each one exactly does in openFOAM... and which is more advantageous... http://www.cfd-online.com/cgi-bin/Op...ow.cgi?1/10111 Regards Vishal |
July 30, 2009, 07:28 |
#46 |
J. Cai
Rep Power: 17 |
Hi, dear Foamers, I also meet the same problem when use simpleFoam to do a simple case. I have try some suggestions in this thread, but fails. any other comments?
Thank you very much. have a nice day. Chiven Time = 8 DILUPBiCG: Solving for Ux, Initial residual = 0.0154965, Final residual = 3.56285e-05, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.00436824, Final residual = 3.31732e-05, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.00323331, Final residual = 3.00037e-05, No Iterations 1 GAMG: Solving for p, Initial residual = 0.961782, Final residual = 0.00929941, No Iterations 3 time step continuity errors : sum local = 1.72947e+25, global = 2.12055e+19, cumulative = 2.12055e+19 DILUPBiCG: Solving for epsilon, Initial residual = 0.999551, Final residual = 0.0140238, No Iterations 1 bounding epsilon, min: -1.97709e+32 max: 1.13481e+50 average: 7.81416e+44 DILUPBiCG: Solving for k, Initial residual = 0.999999, Final residual = 0.0180508, No Iterations 1 bounding k, min: -1.56134e+22 max: 6.46051e+40 average: 1.40592e+36 ExecutionTime = 72.457 s ClockTime = 73 s Time = 9 DILUPBiCG: Solving for Ux, Initial residual = 0.258312, Final residual = 0.00394438, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.322752, Final residual = 0.00548298, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.134508, Final residual = 0.00229101, No Iterations 1 GAMG: Solving for p, Initial residual = 0.999988, Final residual = 0.00957924, No Iterations 10 time step continuity errors : sum local = 6.46819e+24, global = 6.00802e+18, cumulative = 2.72135e+19 DILUPBiCG: Solving for epsilon, Initial residual = 0.0935502, Final residual = 1.68919e-17, No Iterations 1 bounding epsilon, min: -5.66454e+59 max: 1.62366e+65 average: 4.84566e+60 DILUPBiCG: Solving for k, Initial residual = 0.271442, Final residual = 0.00498093, No Iterations 1 bounding k, min: -4.51792e+38 max: 2.46246e+56 average: 5.53053e+51 ExecutionTime = 83.2949 s ClockTime = 84 s Time = 10 DILUPBiCG: Solving for Ux, Initial residual = 0.213457, Final residual = 0.000426911, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.194438, Final residual = 0.000360278, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.140209, Final residual = 0.000161624, No Iterations 1 GAMG: Solving for p, Initial residual = 0.00575245, Final residual = 5.53957e-05, No Iterations 1 time step continuity errors : sum local = 6.46819e+49, global = 8.29418e+43, cumulative = 8.29418e+43 DILUPBiCG: Solving for epsilon, Initial residual = 2.16312e-18, Final residual = 2.16312e-18, No Iterations 0 bounding epsilon, min: 1.59155e-21 max: 2.55066e+77 average: 2.55902e+72 DILUPBiCG: Solving for k, Initial residual = 0.00017126, Final residual = 6.14596e-07, No Iterations 1 bounding k, min: -9.10313e+53 max: 3.20352e+90 average: 3.67758e+85 ExecutionTime = 90.6045 s ClockTime = 91 s Time = 11 DILUPBiCG: Solving for Ux, Initial residual = 0.0174846, Final residual = 0.000301742, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.00157757, Final residual = 2.24617e-05, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.0368666, Final residual = 0.000505577, No Iterations 1 #0 _ZN4Foam5error10printStackERNS_7OstreamE-0xb383f0 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #1 _ZN4Foam6sigFpe13sigFpeHandlerEi-0xb01820 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xa0000000000107e0] #3 _ZN4Foam17DICPreconditioner15calcReciprocalDERNS_5 FieldIdEERKNS_9lduMatrixE-0xef5f6e in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #4 _ZN4Foam11DICSmootherC1ERKNS_4wordERKNS_9lduMatrix ERKNS_10FieldFieldINS_5FieldEdEESB_RKNS_8UPtrListI KNS_17lduInterfaceFieldEEE-0xefe2d0 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #5 _ZN4Foam9lduMatrix8smoother30addsymMatrixConstruct orToTableINS_11DICSmootherEE3NewERKNS_4wordERKS0_R KNS_10FieldFieldINS_5FieldEdEESE_RKNS_8UPtrListIKN S_17lduInterfaceFieldEEE-0xeb2c00 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #6 _ZN4Foam9lduMatrix8smoother3NewERKNS_4wordERKS0_RK NS_10FieldFieldINS_5FieldEdEESB_RKNS_8UPtrListIKNS _17lduInterfaceFieldEEERNS_7IstreamE-0xf1a020 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #7 _ZNK4Foam10GAMGSolver10initVcycleERNS_7PtrListINS_ 5FieldIdEEEES5_RNS1_INS_9lduMatrix8smootherEEE-0xedc9e0 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #8 _ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h-0xed4f70 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so" #9 _ZN4Foam8fvMatrixIdE5solveERNS_7IstreamE-0x1f46d20 in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libfiniteVolume.so" #10 main in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxIA64GccDPOpt/simpleFoam" #11 __libc_start_main-0x739090 in "/lib/tls/libc.so.6.1" #12 _start in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxIA64GccDPOpt/simpleFoam" |
August 22, 2009, 11:27 |
#47 |
Krzysztof Przysowa
Rep Power: 17 |
Hi chiven,
there is obviously something causing time step continuity errors being sky high. I recall that I had a similar problem when, by mistake, in boundary definition velocity direction was from outlet to inlet. Of course it should be other way around. So, I would recommend to check your boundary conditions. Cheers |
August 23, 2009, 06:13 |
#48 |
J. Cai
Rep Power: 17 |
Hello, Krzysztof, thanks a lot for your reply. You are right, and now the problems are over.
Best regards, Chiven |
November 27, 2009, 08:16 |
#49 |
Michael Schwarz
Rep Power: 17 |
Hey Guys!!
I have the same problemes changing my solvers to GAMG like mayol had. FOAM FATAL IO ERROR : expected 'true' or 'false', found yes file: /opt/OpenFOAM/caelinux-1.4.1/run/BLENDE/system/fvSolution:::scaleCorrection at line 41. From function operator>>(Istream&, bool&) in file primitives/bool/boolIO.C at line 72. FOAM exiting I just started working with OpenFoam and still be playing arround a bit. Here is my checkMesh log: Create polyMesh for time = constant Time = constant Mesh stats points: 27304 edges: 172646 faces: 283432 internal faces: 268924 cells: 138089 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 138089 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface In 122 77 ok (not multiply connected) Out 172 102 ok (not multiply connected) Walls 14214 7137 ok (not multiply connected) Checking geometry... Domain bounding box: (-0.6 0 -0.6) (0.6 5 0.6) Boundary openness (4.08264e-17 2.77916e-17 3.03938e-17) OK. Max cell openness = 1.48446e-16 OK. Max aspect ratio = 4.30296 OK. Minumum face area = 1.32319e-05. Maximum face area = 0.028895. Face area magnitudes OK. Min volume = 2.50715e-08. Max volume = 0.00159632. Total volume = 5.60409. Cell volumes OK. Mesh non-orthogonality Max: 51.4236 average: 15.1122 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.791886 OK. Min/max edge length = 0.00478093 0.295993 OK. All angles in faces OK. All face flatness OK. Mesh OK. To me, it seems that the mesh-scale is fine. Any idea what causes the problems? Thanks for Help! |
November 28, 2009, 05:32 |
#50 | |
Gijsbert Wierink
Rep Power: 18 |
Hi Michael,
Regards, Gijs |
November 29, 2009, 13:28 |
#51 |
Michael Schwarz
Rep Power: 17 |
Hi Gijs,
sorry for the late reply. Have been away for the weekend... I tried to Put "true" there but the same errors occure. It is the same error for U,p,k and epsilon.... No idea what to do |
January 26, 2010, 07:46 |
time step continuity errors...remain
#52 |
George Pechlivanoglou
Rep Power: 17 |
Hello everyone!
I also get the time step continuity error and I am having a hard time solving the problem. My grid is built with gmsh and engrid (extrusion, boundary conditions, OpenFOAM export). It is unstructured, quasi 2D (i.e. sides are BL type = empty) and represents a multi element airfoil. the grid works perfectly with simpleFoam and komegaSST until 16° AoA. When I try computations at 25° AoA I get the time step continuity errors. I have tried all the proposals from this thread (e.g. reduction of relaxation factors, high initial epsilon, smaller time step) it still crashes. I am pretty sure that the problem has to do with the massive separation due to high AoA...but I have no idea what to do next. Any proposals ?? Thanx a lot for you help! cheers George |
January 28, 2010, 15:20 |
#53 |
Gijsbert Wierink
Rep Power: 18 |
Hi George,
I'm not an aerodynamicist or anything, but could it be related to the pressure correction method? SimpleFoam uses the SIMPLE algorithm (of course ), which can be quite sensitive to relaxations factors and time step. The PISO algorithm may be less sensitive and contains an extra correction for skewness (do you have a more skewed mesh for higher angle of attack?). Have you tried e.g. pisoFoam (or turbFoam) to test this or do you need to use simpleFoam? Well, don't know if this is of any help, but it just comes to mind.
Regards, Gijs |
January 28, 2010, 16:53 |
SimpleFoam, Time step continuity errors
#54 |
Rep Power: 17 |
gwierink thanks for the tips
I am actually building my unstructured grids with Gmsh and then extrude them with EnGrid...meaning that the whole process is more or less standard for any airfoil I use. I therefore think that the grid itself is not really problematic. My checkMesh does not give me any errors...and the aspect ratios and expansion ratios are good. It might be the sensitivity of simpleFoam to relaxation and time step....but maybe I try to find some other possible solutions as well before I change the model. The problem is that I am running the computations via script which goes from one AoA to the other in order to get the airfoil polar at the end. I suspect that is I change solver between AoA then my polar will have sort of..random errors. Anyway, thanx again for the tips!! cheers George |
February 10, 2010, 22:57 |
#55 | |
Jonathas Assunção de Castro
Rep Power: 17 |
Could you send to me the following files, please? initConvergenceCheck.H convergenceCheck.H pEqn.H UEqn.H Tnahks |
April 11, 2010, 07:29 |
#56 |
Rep Power: 16 |
Hello All,
I am trying to simulate an impingingjet using the simpleFoam in OF1.6.x. I am trying to follow the threads and tried different things. But I am still getting the same error. I am posting my error and attaching my initial bc. Your support will be greatly appreciated. Time = 759 DILUPBiCG: Solving for Ux, Initial residual = 0.364807, Final residual = 0.0331038, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.401396, Final residual = 0.0185339, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.439448, Final residual = 0.0046591, No Iterations 1 GAMG: Solving for p, Initial residual = 0.569614, Final residual = 0.00428777, No Iterations 66 time step continuity errors : sum local = 3.14096e+42, global = 3.09629e+39, cumulative = 6.80133e+40 DILUPBiCG: Solving for epsilon, Initial residual = 1.08298e-09, Final residual = 1.08298e-09, No Iterations 0 DILUPBiCG: Solving for k, Initial residual = 0.000115294, Final residual = 2.84805e-06, No Iterations 2 ExecutionTime = 47327.3 s ClockTime = 48069 s Time = 760 DILUPBiCG: Solving for Ux, Initial residual = 0.506818, Final residual = 0.00973123, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.603294, Final residual = 0.0122224, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.280386, Final residual = 0.00518198, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0695246, Final residual = 0.000686704, No Iterations 30 time step continuity errors : sum local = 1.41992e+43, global = 4.71133e+41, cumulative = 5.39147e+41 DILUPBiCG: Solving for epsilon, Initial residual = 3.87187e-11, Final residual = 3.87187e-11, No Iterations 0 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0894909, No Iterations 1 bounding k, min: -7.27376e+51 max: 5.05817e+89 average: 5.17561e+84 ExecutionTime = 47386.5 s ClockTime = 48159 s Time = 761 DILUPBiCG: Solving for Ux, Initial residual = 0.417362, Final residual = 0.0145424, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.51114, Final residual = 0.0224704, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.376437, Final residual = 0.0288099, No Iterations 1 GAMG: Solving for p, Initial residual = 0.629327, Final residual = 0.00528483, No Iterations 8 time step continuity errors : sum local = 1.11456e+78, global = 4.87405e+75, cumulative = 4.87405e+75 DILUPBiCG: Solving for epsilon, Initial residual = 4.23728e-09, Final residual = 4.23728e-09, No Iterations 0 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #7 main in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #8 __libc_start_main in "/lib/libc.so.6" #9 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception thanks regards jish |
February 21, 2016, 06:44 |
#57 | |
swaps
October 11, 2017, 12:06 |
#58 | |
Andrea
Rep Power: 9 |
I found that this solution helped keep the run stable. Thanks! |
July 15, 2018, 20:09 |
#59 |
Cristina Hernandez
Rep Power: 8 |
I am running an incompressible case of a flow past a cube with rounded edges in order to calculate the drag coefficient (I use komegasstsas as turbulence model). So far, I have used pimpleFoam but the simulations take too long so I want to use a steady-state solver such as simpleFoam to speed up the process. However, my simulation is not converging. I am getting incredibly high values for the forces and also getting high time step continuity errors before the simulation stops: time step continuity errors : sum local = 9.01619e+17, global = 7.91561e+15, cumulative = 8.6525e+15 I have tried with different relaxationFactors for p (starting with 0.3 and down to 0.05) but nothing changes. I have checked my mesh and everything is OK. Does anyone know what I may be doing wrong? This are my fvSolution file Code:
solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } pFinal { $p; tolerance 1e-06; relTol 0; } "(U|k|omega)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-05; relTol 0; } "(U|k|omega)Final" { $U; relTol 0; } } SIMPLE //PIMPLE* { nCorrectors 4; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } relaxationFactors { p 0.05; U 0.7; k 0.7; omega 0.7; } Code:
ddtSchemes { default steadyState; //antes Euler, específico de simpleFoam } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; //añadido en base a div(phi,k) y a tutorial de internet FLow_past_a_cylinder div(phi,nuTilda) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Any help or suggestion would be welcome. Please let me know if you need any other files. Thanks in advance, Cristina |
July 19, 2018, 20:40 |
#60 |
Çağatay Emre Ayhan
Rep Power: 9 |
Hello Cristina. Can I see your mesh quality. Do you have 0 area faces. You can set minimum face area to some reasonable value. You should get rid of skew and nonorthogonal faces. You can play with included angle setting in surfaceFeatureExtractDict. Resolve feature angle in SnappyHexMeshDict works with includedAngle setting in terms of curvature (edge) refinement. You can use cell limited schemes. You can use bounded Gauss upwind schemes. you can increase snapping iterations. How is your stl geometry quality ?
Time step size and max iterations per time step | pUl| | FLUENT | 31 | October 23, 2020 23:50 |
Time step continuity | anja | OpenFOAM Running, Solving & CFD | 37 | June 22, 2020 12:16 |
SELECTING TIME STEP SIZE, NUMBER OF TIME STEP | NITUL KALITA | FLUENT | 2 | November 22, 2012 09:28 |
Speedup with GAMG for simplefoam forward Step | tutlhino | OpenFOAM Running, Solving & CFD | 9 | June 24, 2007 22:44 |
Relation of computational time step with real time | Salman | Main CFD Forum | 2 | August 3, 2005 15:13 |
