New densitybased solver AeroFoam
Like Tree11Likes
Old   June 21, 2011, 07:17
Unhappy Stuck!!
  #41
Rachit Prasad
Rachit is on a distinguished road
Hi everyone!
I am a new of OpenFOAM and hence AeroFoam as well. In order to get familiar with it, I went to the following website and downloaded the Oblique Shock Test problem:
http://www.aero.polimi.it/freecase/?...:Oblique_shock
After uncompressing the folder, I tried to run it, but the following came on the terminal:
This is a start/*---------------------------------------------------------------------------*\
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-53b7f692aa41
Exec : AeroFoam
Date : Jun 21 2011
Time : 16:02:27
Host : rachit-desktop
PID : 5378
Case : /home/rachit/OpenFOAM/OpenFOAM-1.6/foam_run/compressible/ObliqueShock_B/ObliqueShock_B
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
// using new solver syntax:
cellDisplacement
solver PCG;
preconditioner DIC;
tolerance 1e-08;
relTol 0;
Reading Thermodynamic Properties...
gamma [-] = 1.4
Pr [-] = 0.72
R [J/KgK] = 287.05
Cp [J/KgK] = 717.625
Cv [J/KgK] = 1004.67
Reading Initial Conditions...
Reading field p
Reading field T
Reading field U
Creating conservative variables at t^(k)
Creating conservative variables at t^(k-1)
Creating conservative variables at t^(k-2)
Creating conservative variables fluxes at t^(k)
Creating primitive variables gradient fields (optional)
Creating Mesh Connectivity...
Using adaptive algorithm...
id_LL_i6500SIZE3100Loop on Internal Faces...
Nothing happens beyond this, as in the process is still continuing but no progress is being made.
Could anyone please tell me what mistake I am making?
Thanks in advance!
Rachit
Rachit is offline   Reply With Quote
Old   July 19, 2011, 11:20
Default AeroFoam problems
  #42
Vadim Vorobyov
Vorobus is on a distinguished road
Send a message via Skype™ to Vorobus
I've tried to use AeroFoam 1.7.1 solver for the OpenFoam 1.7.1 tutorial case ObliqueShock, and I 've done all the correctoins which are given in the AEROFOAM QUICK START paper www.aero.polimi.it/freecase/?download=AeroFoam_QuickStart.pdf
but after entering AeroFoam I see the following message:
vadim.vorobyov@oslo:~/OF171/compressible/aeroFoam/forwardStep$ AeroFoam
| \\ / O peration | Version: 1.7.x |
| \\ / A nd | Web: www.OpenFOAM.com |
Build : 1.7.x-3776603e4c6c
Exec : AeroFoam
Date : Jul 19 2011
Time : 18:00:56
Host : oslo
PID : 15382
Case : /home/vadim.vorobyov/OF171/compressible/aeroFoam/forwardStep
nProcs : 1
Create time
--> FOAM FATAL IO ERROR:
keyword R is undefined in dictionary "/home/vadim.vorobyov/OF171/compressible/aeroFoam/forwardStep/constant/thermodynamicProperties"
file: /home/vadim.vorobyov/OF171/compressible/aeroFoam/forwardStep/constant/thermodynamicProperties from line 18 to line 43.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
I've tried to put R universal gas constant into the corresponding file/ here is how my
"thermodynamicProperties" looks like
| \\ / O peration | Version: 1.7.1 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
// Note: these are the properties for a "normalised" inviscid gas
// for which the speed of sound is 1 m/s at a temperature of 1K
// and gamma = 7/5
mixture
specie
gamma 1.4;
R 287;
nMoles 1;
molWeight 11640.3;
thermodynamics
R 287;
Cp 2.5;
Hf 0;
transport
mu 0;
Pr 1;
R 287;
Does anyone has an idea why I have this error ?
Please, Help!
Thank you very much in advance!
Vorobus is offline   Reply With Quote
Old   September 27, 2011, 05:15
ThanhToan
trantoan2008 is on a distinguished road
Send a message via Yahoo to trantoan2008 Send a message via Skype™ to trantoan2008
Hi All,
I had the same problem like you when I tried to use AeroFoam solver to test that case. Is there anybody treat this problem?
trantoan2008 is offline   Reply With Quote
Old   December 5, 2011, 12:20
Default sourceForge AoeroFoam for OF1.7
  #44
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
Send a message via Skype™ to aerothermal
See that someone developed a 1.7.1 version.
I have not tested yet.
https://sourceforge.net/projects/aerofoam/
aerothermal is offline   Reply With Quote
Old   December 5, 2011, 15:43
Guilherme da Silva
I had same problem here when running the Onera M6 wing test case downloaded from AeroFoam site and using AeroFoam for OF1.7.1.
Originally Posted by Emilie View Post
Hello everybody,
I'm trying to use the solver AeroFoam with the 1.7.1 version of OF; it's part of an important project for my study. I downloaded the Aerofoam files at :
https://sourceforge.net/projects/aerofoam/files/Source/
And now I want to test this solver with a tutorial case : the oblique shock.
However, (after 'BlockMesh'), when I launch AeroFoam, I have :
Create time
gamma [-] = 1.4
Pr [-] = 0.72
R [J/KgK] = 287.05
Reading field p
Reading field T
Reading field U
id_LL_i7290SIZE3510Loop on Internal Faces...
i=0i=1i=2i=3i=4i=5i=6i=7i=8i=9i=10i=11i=1
until i=3509
Loop on Boundary Faces...
Mesh
# of Faces = 3510
# of Cells = 1800
# of BndPatch = 5
0) inlet @ top
1) supersonicInlet @ inlet
2) extrapolatedOutlet @ outlet
3) symmetryPlane @ bottom
4) empty @ frontAndBack
Numerical Scheme
flowType = Euler
timeScheme = RK2
CourantMax = 0.1
CourantSteps = 25
MonotoneFlux = Roe
HighResFlux = LW
fluxLimiter = VL
entropyFix = HH2
extrapolateBC = 1
residualNorm = L1
minResidual = -1
Does everything look fine? [y] to continue [n] otherwise
I type yes and get :
blf fx i=1
blf fx i=3509
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
at Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::word, Foam::word, Foam::word, Foam::word, double)
in "/home/emilie/OpenFOAM/bruno-1.7.1/applications/bin/linux64GccDPOpt/AeroFoam"
#5 __libc_start_main in "/lib/libc.so.6"
Segmentation fault
Thank you very much for your help !
Emilie
Old   October 8, 2013, 03:37
Arash Mahboubidoust
arashfluid is on a distinguished road
Send a message via Yahoo to arashfluid
Hi
Does anyone have a benchmark for AeroFoam Solver in OpenFOAM-1.7.x or 1.6-ext or newer versions?
arashfluid is offline   Reply With Quote
Old   October 30, 2015, 14:34
Default AeroFoam Solver in OpenFoam
  #47
Avani
avani is on a distinguished road
Hello all,
I am a student and I am pretty new to CFD and specially, OpenFoam. I am trying to install the AeroFoam solver in an OpenFoam 2.3.0 version. Does anyone know if this will work since the page I got the AeroFoam file from only lists 1.4.1 as the version to be used.
Also, if it works, how should I go about installing this feature?
Thank you for all your help!
avani is offline   Reply With Quote
Old   October 31, 2015, 07:35
Retired Super Moderator
Bruno Santos
Greetings Avani and welcome to the forum!
The source code made available here has two versions:
  • AeroFoam-v1.tar.gz, which is made to work with OpenFOAM 1.4.1
  • AeroFoam-v2.tar.gz, which is made to work with... OK, in the file "myOpenFOAM.H" says this:
    Cross-compatibility for OpenFOAM 1.5-dev, 1.6-ext, 1.7.1 and 2.0.0
With any luck, this works with OpenFOAM 2.3 and 2.4... But I would strongly suggest you first try using OpenFOAM 2.0.0 for testing if you can get any results with this in the first place.
As for installing it... see the description given inside the file "Make/files".
Best regards,
Bruno
PS: I've moved your post to the original thread dedicated to AeroFoam, for keeping everything on the same topic in the same thread.
Old   January 15, 2016, 09:20
tuananh
tuananhtran56 is on a distinguished road
Hi Giulio.
I have learnt about FSI using open-source software. I 'm very interested in your thesis. But my OpenFoam software 's version isn't 1.4.
Can you give me ubuntu deb pack openfoam 1.4 or AeroFoam for newest version of OpenFoam 3.0.1 to my email (tuananhtran.kthk56@gmail.com).
Thank you so much.
tuananhtran56 is offline   Reply With Quote
segregated solver vrs coupled solver sm FLUENT 0 November 6, 2007 02:24
Densitybased coupled compressible solver jojo OpenFOAM Running, Solving & CFD 0 July 19, 2006 13:43
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver dandes OpenFOAM Pre-Processing 0 March 22, 2006 22:06
AGM-SOLVER MANOJ FLUENT 5 August 1, 2005 05:49
coupled solver / uncoupled solver Jaan Unger Main CFD Forum 0 September 3, 2002 09:30
