November 3, 2009, 18:18 |
#21 |
Jacques
Rep Power: 17 |
Is this AeroFoam for v1.5 available yet ? If so where can I find it ?
November 16, 2009, 07:22 |
rhoCentralFoam
#22 |
Rep Power: 17 |
There is this code rhoCentralFoam, how does it differ from the newer AeroFoam?
May 26, 2010, 12:09 |
AeroFoam for OpenFoam 1.6
#23 |
KGN
Rep Power: 17 |
Hi all,
Is AeroFoam available for OpenFoam 1.6. If so where can i download the source code. thanks mecbe |
July 3, 2010, 07:47 |
Aerofoam for OpenFoam 1.6
#24 |
Gabriel D
Rep Power: 16 |
hello everybody,
i just wanted to know if AeroFoam is available for OF 1.6 . thank you |
July 3, 2010, 08:05 |
#25 |
KGN
Rep Power: 17 |
Unfortunately No.
Thanks mecbe |
October 3, 2010, 21:48 |
#26 |
October 14, 2010, 09:47 |
#27 |
Marta Lazzarin
Rep Power: 17 |
Hi all, i would like to use the 3D toolbox to make a movie of the AGARD wing of the tutorial. I have it activated, but i do not know how to use it.
Can someone tell me please? Thanks a lot! Marta |
October 14, 2010, 09:53 |
#28 |
Marta Lazzarin
Rep Power: 17 |
Dear all, i am trying to run the AGARD wing tutorial, but I do not know how to make the movie i saw on the website.
I have already activated the 3D toolbox and data are saved correctly, so everything is fine with the run. Thanks a lot, Marta |
October 20, 2010, 03:59 |
Problem regarding adding another monoflux scheme in Aerofoam
#29 |
Sathishwar Reddy SPD.
Hi Guilo,
I am trying to add a new monoflux scheme (KFVS) similar to that of AUSM, Roe fluxes, etc.,. I have made correction to include the file in header for Aerofoam.C (#include KFVSFlux.C) file and called successfully from build_fluxes.C, I got no compilation errors when I ran wmake in the AeroFoam folder through Terminal. But when I use the scheme to run a test case it gives the following error. Does everything look fine? [y] to continue [n] otherwise y Starting time loop... #0 Foam::error:: printStack(Foam::Ostream&) in "/home/xx/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/xx/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0x997400] #3 kfvs_flux(double, double, double, Foam::Vector<double>, Foam::Vector<double>, double, double, Foam::Vector<double>, double*, Foam::Vector<double>*, double*, double) in "/home/madhu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/AeroFoam" #4 build_fluxes(Foam::Field<double>*, Foam::word, Foam::dimensioned<double>*, Foam::dimensioned<double>*, Foam::dimensioned<double>*, Foam::fvMesh*, Foam::Field<int>*, Foam::Field<int>*, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>* at Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::word, Foam::word, Foam::word, Foam::word, double) #5 main in "/home/xx/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/AeroFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/i386/elf/start.S:122 Floating point exception Do I need to make changes in other places to incorporate the file. Thanks in advance, Eeshwar. Last edited by eeshwar; October 20, 2010 at 05:44. |
December 25, 2010, 10:42 |
AeroFoam
#30 |
senthilkumar.R
Rep Power: 16 |
Dear all,
Any body have updated AeroFoam solver which works on Open Foam 1.6 or higher version? Please reply...
Senthil Kumar. R Department of space Engineering and Rocketry, Birla Institute of Technology,Mesra. rock.senthilkumar@gmail.com |
December 26, 2010, 11:35 |
run open foam
#31 |
iman
Rep Power: 15 |
hi
I new user open foam and can generate mesh but I can't run it please help me. |
December 26, 2010, 12:50 |
#32 |
senthilkumar.R
Rep Power: 16 |
Hi Iman,
Explain how you generated mesh in OpenFOAM. If you generated with Mesh Conversion utilities , please go through the following link http://www.afs.enea.it/funel/CFD/Ope...shconvtest.htm and user guide .
December 31, 2010, 11:39 |
#33 |
iman
Rep Power: 15 |
dear Rock.Senthil Kumar
Its good thanks for help you |
February 4, 2011, 23:53 |
new version of AeroFOAM for OpenFOAM 1.7.1
#34 |
TCH
Rep Power: 16 |
AeroFoam-1.7-part1.zip
AeroFoam-1.7-part2.zip enjoy~! this is not my contribution, but I hope it is helpful! |
April 1, 2011, 03:39 |
#35 |
This is really helpful and I hope work continues in this area of OpenFOAM.
April 1, 2011, 08:44 |
#36 |
Thanks Solarberiden.
Is it not your contribution? I am sure that you contributed posting here... Do you know the author of the codes? Or a URL where it is located? |
April 6, 2011, 04:49 |
Problem with Aerofoam for OF1.7.1
#37 |
Emilie Garnier
Rep Power: 15 |
Hello everybody,
I'm trying to use the solver AeroFoam with the 1.7.1 version of OF; it's part of an important project for my study. I downloaded the Aerofoam files at : https://sourceforge.net/projects/aerofoam/files/Source/ And now I want to test this solver with a tutorial case : the oblique shock. However, (after 'BlockMesh'), when I launch AeroFoam, I have : ------------------------------------------------------------- // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 ======================================== Reading Thermodynamic Properties... ======================================== gamma [-] = 1.4 Pr [-] = 0.72 R [J/KgK] = 287.05 Cp [J/KgK] = 717.625 Cv [J/KgK] = 1004.67 ---------------------------------------- ======================================== Reading Initial Conditions... ======================================== Reading field p Reading field T Reading field U ---------------------------------------- Creating conservative variables at t^(k) Creating conservative variables at t^(k-1) Creating conservative variables at t^(k-2) Creating conservative variables fluxes at t^(k) Creating primitive variables gradient fields (optional) ---------------------------------------- ======================================== Creating Mesh Connectivity... ======================================== Using adaptive algorithm... id_LL_i7290SIZE3510Loop on Internal Faces... i=0i=1i=2i=3i=4i=5i=6i=7i=8i=9i=10i=11i=1 until i=3509 Loop on Boundary Faces... ---------------------------------------- ======================================== Mesh ======================================== # of Faces = 3510 # of Cells = 1800 # of BndPatch = 5 0) inlet @ top 1) supersonicInlet @ inlet 2) extrapolatedOutlet @ outlet 3) symmetryPlane @ bottom 4) empty @ frontAndBack ---------------------------------------- ======================================== Numerical Scheme ======================================== flowType = Euler timeScheme = RK2 CourantMax = 0.1 CourantSteps = 25 MonotoneFlux = Roe HighResFlux = LW fluxLimiter = VL entropyFix = HH2 extrapolateBC = 1 residualNorm = L1 minResidual = -1 ---------------------------------------- Does everything look fine? [y] to continue [n] otherwise ------------------------------------------------------------- I type yes and get : ------------------------------------------------------------- blf fx i=1 ... blf fx i=3509 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 at Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::word, Foam::word, Foam::word, Foam::word, double) #4 in "/home/emilie/OpenFOAM/bruno-1.7.1/applications/bin/linux64GccDPOpt/AeroFoam" #5 __libc_start_main in "/lib/libc.so.6" #6 in "/home/emilie/OpenFOAM/bruno-1.7.1/applications/bin/linux64GccDPOpt/AeroFoam" Segmentation fault ------------------------------------------------------------- Does anyone has an idea why I have this error ? Thank you very much for your help ! Emilie |
May 31, 2011, 02:44 |
#38 |
ZhengJJ
Rep Power: 15 |
is there any version can run in parallel?
June 17, 2011, 04:35 |
#39 |
TCH
Rep Power: 16 |
could you please rebuild your openfoam in debug mode and repost the error message? The final error message you posted didn't bring forwards any location about the error position information, which is a little bit difficult for other "depanner" , LOL.
by the way, the author of the version you are using and downloading from sourceforge JLight2010 had mentioned that http://www.cfd-online.com/Forums/ope...free-code.html he is not sure about the code correctness, further discuss would be depending your reply, I have tried some examples including the OneraM6 case and YF-17 case. |
June 17, 2011, 04:48 |
#40 |
TCH
Rep Power: 16 |
segregated solver vrs coupled solver | sm | FLUENT | 0 | November 6, 2007 02:24 |
Densitybased coupled compressible solver | jojo | OpenFOAM Running, Solving & CFD | 0 | July 19, 2006 13:43 |
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver | dandes | OpenFOAM Pre-Processing | 0 | March 22, 2006 22:06 |
AGM-SOLVER | MANOJ | FLUENT | 5 | August 1, 2005 05:49 |
coupled solver / uncoupled solver | Jaan Unger | Main CFD Forum | 0 | September 3, 2002 09:30 |
