Forces in OF15
Like Tree6Likes
Old   September 23, 2010, 07:20
paka is on a distinguished road
Problem solved: http://www.cfd-online.com/Forums/ope...-v1-6-a-3.html
foamiste likes this.
paka is offline   Reply With Quote
Old   October 3, 2010, 19:15
Default keyword nu is undefined in dictionary...
  #162
inkarbekov medet
meddd is on a distinguished road
hi!!!!!
i have problem, after icoFoam:
--> FOAM FATAL IO ERROR:
keyword nu is undefined in dictionary "/home/medet/OpenFOAM/medet-1.7.1/run/tutorials/multiphase/interFoam/laminar/damBreak/constant/transportProperties"
file: /home/medet/OpenFOAM/medet-1.7.1/run/tutorials/multiphase/interFoam/laminar/damBreak/constant/transportProperties from line 20 to line 62.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
transportProperties :
phase1
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-06;
rho rho [ 1 -3 0 0 0 0 0 ] 1000;
CrossPowerLawCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
m m [ 0 0 1 0 0 0 0 ] 1;
n n [ 0 0 0 0 0 0 0 ] 0;
BirdCarreauCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 0.0142515;
k k [ 0 0 1 0 0 0 0 ] 99.6;
n n [ 0 0 0 0 0 0 0 ] 0.1003;
phase2
nu nu [ 0 2 -1 0 0 0 0 ] 1.48e-05;
rho rho [ 1 -3 0 0 0 0 0 ] 1;
CrossPowerLawCoeffs
BirdCarreauCoeffs
sigma sigma [ 1 0 -1 0 0 0 0 ] 0.07;
Please help!!!
meddd is offline   Reply With Quote
Old   January 14, 2011, 18:10
Default drag coeff
  #163
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Hi oll of foamers
I hope that you are well.
I have one question:
I want to calculate dragCoefficient over a cylinder with 0.025 diameter with viscoelasticFluidFoam solver. ( I use Kubuntu, OF 1-5 decv) . I add the code below in controlDict file
application viscoelasticFluidFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 300;
deltaT 1e-5;
writeControl adjustableRunTime;
writeInterval 1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
graphFormat raw;
runTimeModifiable yes;
adjustTimeStep on;
maxCo 0.8;
maxDeltaT 0.001;
functions
forces
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
outputControl runTime;
outputInterval 1;
patches (cylinder); // change to your patch name
PName p;
Uname U;
rhoInf 803.87097; //Reference density for fluid
CofR (0 0 0); //Origin for moment calculations
forceCoeffs
type forceCoeffs;
outputInterval 1;
patches (cylinder); //change to your patch name
PName p;
Uname U;
log true;
rhoInf 803.87097;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 0.036;
lRef 0.025;
Aref 0.025;
, but when run it,after one step, this error appear :
Courant Number mean: 3.24445e-07 max: 5.10534e-06 velocity magnitude: 0.000421808
deltaT = 1.43997e-05
No valid model for viscous stress calculation.
From function forces::devRhoReff()
in file forces/forces.C at line 306.
FOAM exiting
*** glibc detected *** viscoelasticFluidFoam: double free or corruption (fasttop): 0x0902a378 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6(+0x6b591)[0x52c591]
/lib/tls/i686/cmov/libc.so.6(+0x6cde8)[0x52dde8]
/lib/tls/i686/cmov/libc.so.6(cfree+0x6d)[0x530ecd]
/usr/lib/libstdc++.so.6(_ZdlPv+0x21)[0x7b3741]
/usr/lib/libstdc++.so.6(_ZNSs4_Rep10_M_destroyERKSaIcE+0x1d )[0x78fc2d]
/usr/lib/libstdc++.so.6(_ZNSsD2Ev+0x4c)[0x79163c]
/usr/lib/OpenFOAM-1.5-dev/lib/libfiniteVolume.so(_ZN4Foam4wordD1Ev+0x1d)[0xcf2efd]
/lib/tls/i686/cmov/libc.so.6(+0x2f1bf)[0x4f01bf]
/lib/tls/i686/cmov/libc.so.6(+0x2f22f)[0x4f022f]
/usr/lib/OpenFOAM-1.5-dev/lib/libOpenFOAM.so(_ZN4Foam5error4exitEi+0x1f9)[0x3f5d2f9]
/usr/lib/OpenFOAM-1.5-dev/lib/libforces.so(_ZNK4Foam6forces10devRhoReffEv+0xf54)[0x65315f4]
/usr/lib/OpenFOAM-1.5-dev/lib/libforces.so(_ZNK4Foam6forces10calcForcesEv+0x32)[0x652c852]
======= Memory map: ========
00110000-0024a000 r-xp 00000000 00:10 16478 /usr/lib/OpenFOAM-1.5-dev/lib/libviscoelasticTransportModels.so
0024a000-0024b000 ---p 0013a000 00:10 16478 /usr/lib/OpenFOAM-1.5-dev/lib/libviscoelasticTransportModels.so
0024b000-0024d000 r--p 0013a000 00:10 16478 /usr/lib/OpenFOAM-1.5-dev/lib/libviscoelasticTransportModels.so
0024d000-0024e000 rw-p 0013c000 00:10 16478 /usr/lib/OpenFOAM-1.5-dev/lib/libviscoelasticTransportModels.so
0024e000-00410000 r-xp 00000000 00:10 16479 /usr/lib/OpenFOAM-1.5-dev/lib/libmeshTools.so
00410000-00413000 r--p 001c1000 00:10 16479 /usr/lib/OpenFOAM-1.5-dev/lib/libmeshTools.so
00413000-00415000 rw-p 001c4000 00:10 16479 /usr/lib/OpenFOAM-1.5-dev/lib/libmeshTools.so
00415000-00416000 rw-p 00000000 00:00 0
1) can u guide me What is the problem?
2) did I enter Aref number truly? how Lref ? ( my diameter cylinder is 0.025 & 2D)
3) If needed to complile forceCoeffs, can you tell me how complie it successfully?
Thank a lot, Rasoul
desert_1250 is offline   Reply With Quote
Old   January 14, 2011, 18:41
I'm not 100% sure, but I think OF1.5 did not allow you to calculate forces through this library. My advise, update to OF1.7.
K
Old   January 15, 2011, 11:39
s.rasoul_varedi
thanks paka for your reply,
i try to do my case with OF 1.7 and tell what happen
do every one know a bout this error that appear in the error massege?
No valid model for viscous stress calculation "
Rasoul
best regards
Old   January 15, 2011, 15:41
Forget about this error. Get the new version and start again.
Focusing on this error is like driving a car from 2010, but trying to fix it based on what people drove in 1936.
What it seems for me, I would advise a bit of reading about programming structures and C++.
Best!
Old   September 17, 2011, 04:24
s.rasoul_varedi
dear foamers, i wanna to calculate the forces formulated that was present in the attachment over a cylinder. my solver is viscoelasticFluidFoam and the forces calculation be deferent with newtonians' one, so when i wanna use forces function in OpenFOAM, this error apears :
"No valid model for viscous stress calculation "
can every one help me how do it? tnx
Old   June 18, 2016, 07:04
Viraj Belekar
viraj20feb is on a distinguished road
Originally Posted by mgz1985 View Post
hi Ivan
i am able to get the coefficients but they are very weird values
when I use Aref=1, I get Cd=7e-05 and Cl=1.38e-04
so i tried it by reducing Aref to 0.00001 (i know it is wrong) i get the order correct for Cd but Cl is still one order low.
can anyone tell me where could be the possible error?
thanx
Hello friend,
Did you get the correct values of force co-efficients? I am also getting absurd values in the range of 10^5. I don't know what mistake I am doing
viraj20feb is offline   Reply With Quote
Old   November 14, 2017, 12:51
A. Min
alimea is on a distinguished road
Hi
I have this error too!
Did you find how to solve this problem?
Thanks
alimea is offline   Reply With Quote
Old   July 8, 2018, 03:49
Default error : no valid model for viscous stress calculation
  #170
mortezanayebi
mortezanayebi is on a distinguished road
Originally Posted by alimea View Post
Hi
Thanks
hello
I have this error ( no valid model for viscous stress calculation) too!
Thanks
mortezanayebi is offline   Reply With Quote
Old   July 8, 2018, 09:47
P.A.
blaise is on a distinguished road
Did you set a suitable RASmodel in constant/RASProperties (or in turbulenceProperties in newer OF versions)?
Cheers,
Pascal.
blaise is offline   Reply With Quote
Old   July 8, 2018, 09:55
A. Min
Originally Posted by mortezanayebi View Post
hello
Thanks
Dear Morteza
I had had this problem some month ago!! So I have forgotton that. Please explain more about what you want to do. Maybe I can help you.
Old   July 9, 2018, 09:35
Default Further explanation
  #173
mortezanayebi
Dear Morteza
To calculate the forces and the their coefficients, I added a function to the end of controlDict file of the problem. After applying the solver (viscoelasticFluidFoam), this error poped up; "No valid model for viscous stress calculation in force.c file"
You are kindly asked to find the "error" and the "function added to controlDict" in the attachement.
Thank you very much for your help!
Kind Regards!
Old   July 9, 2018, 09:41
A. Min
Kind Regards!
Dear Morteza
Unfortunately forces function isn't written for viscoelasticFluidFoam! You should write it yourself and add it to forces code.
I have done that a couple of months ago. it needs to learn C++ and openFoam language.
Regards,
Ali
Old   July 9, 2018, 09:55
mortezanayebi
Cheers,
Pascal.
I don't understand what an RASmodel is. Would you please explain it further?
Old   July 9, 2018, 10:07
A. Min
What is the relation between RASmodel and your last question (forces in viscoelasticFluidFoam)?!
RASmodel is related to turbulent flow and the model that you want to use. viscoelasticFluidFoam is written based on laminar flow.
Old   July 9, 2018, 10:09
mortezanayebi
Dear Morteza
Regards,
Ali
thank you very much for your help
alimea likes this.
Old   July 9, 2018, 10:17
mortezanayebi
thanks. I didn't know that.
Old   July 9, 2018, 10:19
A. Min
No problem
Ali
mortezanayebi likes this.
Old   July 9, 2018, 10:36
P.A.
Sorry for the confusion I caused... it was just a shot in the dark, as I thought I remembered seeing the same error when I registered forces via a function object and had the line
simulationType  laminar;
accidentally in constant/RASProperties (or constant/turbulenceProperties in other OF versions)...
But anyway, apparently the error comes from missing implementation of forces function...
Best regards,
Pascal.
CoupledFvScalarMatrix in OF15 fisher OpenFOAM Running, Solving & CFD 9 May 27, 2020 10:40
Fan type BC in OF15 hsieh OpenFOAM Running, Solving & CFD 31 July 30, 2015 13:22
Bug in patchIntegrateC OF15 anger OpenFOAM Bugs 8 May 29, 2009 05:36
OpenFOAMdev migration to OF15 fisher OpenFOAM Installation 1 November 25, 2008 15:39
Bug or a feature of OF15 rafal OpenFOAM Bugs 5 July 25, 2008 06:25
