Forces in OF15
Like Tree6Likes
Old   March 9, 2009, 11:30
Default I everybody. Just a quick q
  #101
antonio segalini
antonio_ing is on a distinguished road
I everybody.
Just a quick question: if I have a 2d geometry with a single cell with thickness 2.5mm in the Z direction and I run the forces utility, the torque will be the one generated by those 2.5 mm. So, if I want the torque generated for 1 meter depth, I have to multiply for 400. Is that correct?
antonio_ing is offline   Reply With Quote
Old   March 9, 2009, 19:41
Default hei, Antonio, My experiment w
  #102
Hai Yu
yuhai is on a distinguished road
hei, Antonio,
My experiment with depth 0.1M leads to a 1/10 torque comparing with Fluent.
I think most times, it is right.
yuhai is offline   Reply With Quote
Old   March 19, 2009, 00:42
Default error in lift drag compilation
  #103
leo paul
leopaul is on a distinguished road
hi,
I was following Srinath's procedure for compilation of liftdrag tool in of1.4.everything went ok till step 6 where after executing ./Allwmake i find that all other files except liftdrag.o are created and i get the following error message..its quite long! but since i've very little knowledge in o.f or ubuntu for that matter i decided to put the whole thing in..please help me out!!
P.S:the entire error message was too long ..i've taken bits from the start and the end..i hope this is a relevant post cause it deals with forces!ive searched the forum and no ones got this error
leopaul is offline   Reply With Quote
Old   March 20, 2009, 09:41
Default error in liftdrag compilation
  #104
leo paul
hi,
this is the entire error message.
thanks.
leo
Old   March 20, 2009, 13:29
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Leo
You are missing your headers files. Install using:
sudo apt-get install build-essential
and you should be able to compile.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   March 20, 2009, 16:00
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
I think you have your answer now :-)
msrinath80 is offline   Reply With Quote
Old   March 21, 2009, 12:53
Default Thank you
  #107
leo paul
hi,
Thanks a lot guys...will try that out..
Leo
Old   March 21, 2009, 14:51
leo paul
hi,
compiled succesfully..had to copy that foamutil file frm of1.2 as said in 1 of the posts after step7 tho..nw i've t fix the bug i guess and start off..thanks again guys..
Leo.
Old   March 27, 2009, 04:43
Marco Müller
marico is on a distinguished road
Richard Samuel: Why is the the forceCoeff for an axisymmetric case calculated wrong? For example a infinite long circular cylinder in 2D as a half model?!
And how is your patch executed??
Thanks,
Marco
marico is offline   Reply With Quote
Old   April 8, 2009, 15:17
Default interFoam forces
  #110
Tomislav Maric
tomislav_maric is on a distinguished road
Hello everyone,
I'm trying to do a simulation of a ship on a free surface using interFoam and calculate the forces. I'm running 32bit Ubuntu 8.10 on Hp Compaq 6820s laptop with latest OpenFOAM-1.5-dev from the repo. This is what I've added to my controlDict:
functions
forces
type forces;
functionObjectLibs ("libforces.so");
patches (Hull_OBJECT);
rhoInf 1000;
CofR (0 0 0);
and this is the error I get:
(snipped the header)
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
time step continuity errors : sum local = 3.71483e-07, global = 4.68522e-11, cumulative = 4.68522e-11
PCG: Solving for pcorr, Initial residual = 1, Final residual = 8.66164e-11, No Iterations 204
time step continuity errors : sum local = 3.21776e-17, global = 2.07916e-19, cumulative = 4.68522e-11
Courant Number mean: 0.0005283 max: 0.00883279 velocity magnitude: 7.49691
Starting time loop
Courant Number mean: 0.010566 max: 0.176656 velocity magnitude: 7.49691
deltaT = 0.02
Time = 0.02
MULES: Solving for gamma
Liquid phase volume fraction = 0.790868 Min(gamma) = -6.562e-19 Max(gamma) = 1
Liquid phase volume fraction = 0.790866 Min(gamma) = -1.18035e-18 Max(gamma) = 1
PCG: Solving for pd, Initial residual = 0.999223, Final residual = 0.023873, No Iterations 3
PCG: Solving for pd, Initial residual = 0.0133212, Final residual = 0.000661896, No Iterations 13
PCG: Solving for pd, Initial residual = 0.00127542, Final residual = 9.36798e-08, No Iterations 150
time step continuity errors : sum local = 1.18414e-07, global = 4.01111e-10, cumulative = 4.47963e-10
ExecutionTime = 40.54 s ClockTime = 46 s
Courant Number mean: 0.0118945 max: 0.811429 velocity magnitude: 57.9195
deltaT = 0.01
keyword nu is undefined in dictionary "/home/tomislav/OpenFOAM/tomislav-1.5-dev/run/semestralniProjekt/brod_interFoam/constant/transportProperties"
file: /home/tomislav/OpenFOAM/tomislav-1.5-dev/run/semestralniProjekt/brod_interFoam/constant/transportProperties from line 21 to line 32.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 213.
FOAM exiting
tomislav@icarus:brod_interFoam$ *** glibc detected *** /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/interFoam: double free or corruption (fasttop): 0x0adb26b0 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6[0xb6be6454]
/lib/tls/i686/cmov/libc.so.6(cfree+0x96)[0xb6be84b6]
/home/tomislav/Software/gcc-4.3.3/lib/libstdc++.so.6(_ZdlPv+0x21)[0xb6dd4271]
/home/tomislav/Software/gcc-4.3.3/lib/libstdc++.so.6(_ZNSs4_Rep10_M_destroyERKSaIcE+0x1d )[0xb6db27cd]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libinterfaceProperties.so(_ZN4Foam4wordD1Ev+0x63)[0xb7ed26f3]
/lib/tls/i686/cmov/libc.so.6(exit+0x89)[0xb6ba5d89]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam7IOerror4exitEi+0x20a)[0xb6f437ba]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZNK4Foam10dictionary11lookupEntryE RKNS_4wordEb+0xec)[0xb6f8df7c]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZNK4Foam10dictionary6lookupERKNS_4 wordEb+0x2c)[0xb6f8dfbc]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libforces.so(_ZNK4Foam6forces10devRhoReffEv+0xee5)[0xb0bee085]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libforces.so(_ZNK4Foam6forces16calcForcesMomentEv+ 0xc8)[0xb0bee528]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libforces.so(_ZN4Foam6forces5writeEv+0x52)[0xb0bec112]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libforces.so(_ZN4Foam26OutputFilterFunctionObjectI NS_6forcesEE7executeEv+0x56)[0xb0c0e176]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam18functionObjectList7execut eEv+0x6b)[0xb6fb136b]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam4TimeppEv+0x48)[0xb6fb93d8]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam4TimeppEi+0x11)[0xb6fb9131]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/interFoam[0x80641bb]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb6b8d685]
/home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/interFoam[0x8061551]
======= Memory map: ========
08048000-080da000 r-xp 00000000 08:03 7358876 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/interFoam
080da000-080dc000 rw-p 00091000 08:03 7358876 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/interFoam
09c63000-0b537000 rw-p 09c63000 00:00 0 [heap]
aba96000-abec3000 rw-p aba96000 00:00 0
ac6f5000-acf27000 rw-p ac6f5000 00:00 0
ad352000-ad77f000 rw-p ad352000 00:00 0
adbac000-aedb5000 rw-p adbac000 00:00 0
af8e3000-afce8000 rw-p af8e3000 00:00 0
b0115000-b026c000 rw-p b0115000 00:00 0
b03c3000-b07f0000 rw-p b03c3000 00:00 0
b0b3a000-b0bd9000 r-xp 00000000 08:03 18745 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libLESfilters.so
b0bd9000-b0bdb000 rw-p 0009e000 08:03 18745 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libLESfilters.so
b0bdb000-b0c1b000 r-xp 00000000 08:03 18755 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libforces.so
b0c1b000-b0c1c000 rw-p 00040000 08:03 18755 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libforces.so
b0c1c000-b0c1d000 rw-p b0c1c000 00:00 0
b0ecb000-b144f000 rw-p b0ecb000 00:00 0
b18cc000-b19cd000 r-xp 00000000 08:03 18748 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libcompressibleLESModels.so
b19cd000-b19d1000 rw-p 00100000 08:03 18748 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libcompressibleLESModels.so
b19d1000-b1b4f000 r-xp 00000000 08:03 18744 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libcompressibleRASModels.so
b1b4f000-b1b52000 rw-p 0017e000 08:03 18744 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libcompressibleRASModels.so
b1b52000-b1ca9000 rw-p b1b52000 00:00 0
b1e30000-b1e56000 r-xp 00000000 08:03 18746 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libLESdeltas.so
b1e56000-b1e57000 rw-p 00026000 08:03 18746 /home/tomislav/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libLESdeltas.so
b1e57000-b1e97000 r-xp 00000000 08:03 18728 /home/tomislav
... and so on....
I've tried using forces in icoFoam as a test and everything worked ok, as with simpleFoam. I even have a Python script somewhere that extracts the data for nice plots of calculated magnitudes of both forces and moments. Email me and I'll send what I have.
The forces directory is written, but since the simulation stops before first timeStep it contains only the title comment of the forces and moments components.
From what little I understand C++ i think that the code is having trouble seeing through nested dict-s in transport properties. But if so, why doesn't it complain in the start at "reading transportProperties"? Should I tamper with the source code to adjust it for interFoam? Has anyone seen this before? What's with the glibc error? I've had the same error using other solvers, but they ended normaly, and the forces directory was written.
I've tried to build it using wmake, and it was up to date (as expected, since it works fine with other solvers). I've deleted the functions entry in controlDict and the simulation is running fine for a whole day.
Tomislav
tomislav_maric is offline   Reply With Quote
Old   April 8, 2009, 16:49
Tomislav Maric
to answer myself: forces lib has trouble finding the right nu in the transportProperties dict for interFoam cases.
in the
~/OpenFOAM/OpenFOAM-1.5-dev/src/postProcessing/forces/forces.C
go to line number 101 and look around
else if (obr_.foundObject<dictionary>("transportProperties "))
const dictionary& transportProperties =
obr_.lookupObject<dictionary>("transportProperties ");
// This is really stupid: it presumes that the water is the
// phase1 (just like damBreak tutorial), and takes it's
// viscosity for reference calculation.
dimensionedScalar nu(transportProperties.lookupEntry("phase1").dict( ).lookup("nu"));
// ORIGINAL line is this one below
//dimensionedScalar nu(transportProperties.lookup("nu"));
const volVectorField& U = obr_.lookupObject<volVectorField>(Uname_);
return -rhoRef_*nu*dev(twoSymm(fvc::grad(U)));
I've commented the original troublesome part:
//ORIGINAL line
because it tries to search for "nu" in transportProperties, and "nu" is nested within "phase1" or "phase2" subdictionary, so I've added this:
and it works now (writes the forces in forces directory). The downside to this stupid solution is that you write forces for the phase1. In my case it's the forces imposed by the water, because these forces are kind of important for a ship (at least i think so ).
Does anyone have any suggestion or comment on this? I think this solves my problem for now, but I'm not even sure of that.
Awaiting for floating point exception error,
Tomislav
Old   May 6, 2009, 09:46
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
oops, I'm late again to join the discussion.
libforces.so works fine for me, I think it's better than the old liftDrag utility, very flexible and dynamic!
Thanks to OF developers.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   May 7, 2009, 05:35
Default Totally wrong drag forces in OF
  #113
P.A.
blaise is on a distinguished road
Dear Foamers,
I hope this thread is still alive. I am fairly new to OpenFOAM, but have some experience with CFX. I am using OpenFOAM1.5-dev on a selfmade exercising case, which is a wedge like case but with some cells in circumferential direction (common three dimensional case in turbo machinery, I think). So it is rotationally symmetric. In the center of the wedge there is a section of a small torpedo like body. The whole is somehow similar to a piece of cake with a small bite of it taken away from the tip. :-)
I am trying to calculate the steady drag force on this body section in water with a speed of about 6m/s (Re=10^7) using the simpleFoam solver, but compared to the CFX results, I get wrong results for x pressure force from OF, and I am lost now. Strange enough, all other components are fairly eqal to the CFX results. I used the same grid for the calculations.
The setup is as follows (I will give only the essentials):
INLET
type patch;
nFaces 459;
startFace 173842;
OUTLET
type patch;
nFaces 459;
startFace 174301;
AUSSEN // outer boundary of domain
type slip;
nFaces 1071;
startFace 174760;
SB1 // first patch of axial symmetric wedge
type cyclicGgi;
separationOffset (0 0 0);
rotationAxis (1 0 0);
rotationAngle 10;
shadowPatch SB2;
bridgeOverlap false;
nFaces 6761;
startFace 175831;
SB2 // second patch of axial symmetric wedge
type cyclicGgi;
rotationAngle -10;
shadowPatch SB1;
nFaces 6761;
startFace 182592;
GONDEL1 // surface patch of the body to retrieve forces of
type wall;
nFaces 990;
startFace 189353;
In the controlDict I use:
application simpleFoam
and forces by:
functions
forces
type forces;
patches (GONDEL1);
rhoInf 1025.87;
CofR (0 0 0);
In RASProperties I set:
RASModel kOmegaSST;
In transportProperties:
transportModel Newtonian;
nu nu [0 2 -1 0 0 0 0] 1.1883e-06;
rho rho [1 -3 0 0 0 0 0] 1025.87;
Originally, the density is not set in this file (in the tutorials), but I found this in some posting, and tried it. Anyway, it does not seem to cause any change in the results.
So, in what cases is it useful to set it?
Values for boundary conditions are:
U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (6.0923 0 0);
boundaryField
INLET
type fixedValue;
value uniform (6.0923 0 0);
SB1
type cyclicGgi;
SB2
type cyclicGgi;
OUTLET
type zeroGradient;
AUSSEN
type zeroGradient;
GONDEL1
type fixedValue;
value uniform (0 0 0);
p:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
INLET
type zeroGradient;
SB1
type cyclicGgi;
SB2
type cyclicGgi;
OUTLET
type fixedValue;
value uniform 0;
AUSSEN
type zeroGradient;
GONDEL1
type zeroGradient;
omega (using epsilon and k, which I calculated in the same way as is done in the user guide):
dimensions [0 0 -1 0 0 0 0];
internalField uniform 0.015;
boundaryField
INLET
type turbulentMixingLengthFrequencyInlet;
mixingLength 4;
k k;
value 0.015;
k:
internalField uniform 0.004865;
boundaryField
INLET
type fixedValue;
value 0.004865;
RESULTS:
The results from OF are (only forces):
2750 ((11.1798 152.876 13.3751) (4.76695 0.254509 0.0178232))
The results from CFX are (ordered in the same manner):
1924 ((0.77298 133.43 11.674) (3.6813 0.21366 0.018662))
The pressure distribution on the GONDEL1 patch looks very similar in CFX and OF, but the value ranges differ slightly (p, not p*):
CFX: -4284 to 18850
OF: -5223 to 24892
Due to our long term experience with CFX I can almost certain exclude the possibility of a mistake in the CFX setup. I suppose I missed something very basic in OF, but I cannot figure it out.
Any hint is warmly appreciated!
Thanks,
Pascal.
blaise is offline   Reply With Quote
Old   May 12, 2009, 05:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I have a question about the forces.c which generates the file forces.dat
if I plot the result vs Time in gnuplot, I am not able to see the first components of the vectors.
I think gnuplot ignore those values because of the "("
Is there a workaround in gnuplot, which skip all the "("?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 12, 2009, 06:29
Wolfgang Heydlauff
wolle1982 will become famous soon enough
use the forceCoeffs Tool. Set v=1, A=1,63 in controlDict so the tool calculates the CL values as if there were the L values.
wolle1982 is offline   Reply With Quote
Old   May 12, 2009, 07:14
-mAx-'s Avatar
Maxime Perelli
yes, I have already tested this trick , but I wanted to use the force, for plotting the convergence of the pressure inlet ( I was septic because of the non-wall type, but it's ok ).
So I get the pressure force at the inlet (this is the x-axis in my case ) and I divide it with the inlet-area
On the other hand, the viscous effects should be negligible, so I can work with the total force, eg: the coefficients
Old   May 13, 2009, 03:53
-mAx-'s Avatar
Maxime Perelli
To filter the opening parenthesis in gnuplot
>plot "<sed 's/(/ /g' forces.dat" u 1:2 w l
Old   May 18, 2009, 05:10
Default Cannot relate answer to appropriate posting
  #118
P.A.
Hello wolle1982,
was this posting meant as a reply to my posting from May, 7th (don't understand the Linkback URL completely, but this is the only reference URL I can find for my posting: http://www.cfd-online.com/Forums/ope...rces-of15.html) about the wrong x forces in OF and the comparison to CFX?
If this is the case, I do not understand where the A=1.63 value comes from?
If this posting is a reply to mAx question about filtering of "(" in gnuplot, then I do not understand the correlation either.
Please shed a little light on this.
Thank you!
Cheers,
Pascal.
Old   May 18, 2009, 05:27
Wolfgang Heydlauff
Hi blaise,
was a reply to mAx post.
if on a wing the lift is L = 0.5 * rho * u^2 * A * cL
and you take U as 1m/s and the area A=1.63 m˛, then you get the values of cL as if they were the lift L. because 1.63 is the reciprocal of 0.5*rho .......
i think the results of the drag are calculated too high in OF (or forces-tool). I also have problems calculating an airfoil. drag is too high about 15% compared to windtunnel measurements. but the fit the calculated values of FLOWer e.g.
Old   May 30, 2009, 14:25
Hai Yu
hi ,dear foamers,
I am not sure whether the default density of liquid for turbFoam is air ? 1.29 or 1.225?
if I want to specify it, I should introduce a item in turbulenceProperty "rho" following nu?
thanks!
Cheers
CoupledFvScalarMatrix in OF15 fisher OpenFOAM Running, Solving & CFD 9 May 27, 2020 10:40
Fan type BC in OF15 hsieh OpenFOAM Running, Solving & CFD 31 July 30, 2015 13:22
Bug in patchIntegrateC OF15 anger OpenFOAM Bugs 8 May 29, 2009 05:36
OpenFOAMdev migration to OF15 fisher OpenFOAM Installation 1 November 25, 2008 15:39
Bug or a feature of OF15 rafal OpenFOAM Bugs 5 July 25, 2008 06:25
