Forces in OF15
Like Tree6Likes
Old   February 15, 2009, 06:59
Default Patel, Are you using symmet
  #81
Richard Samuel
rsamuel is on a distinguished road
Patel,
Are you using symmetry planes in your domain geometry ? The forces code does not know about symmetry planes in the geometry so forces will not appear to be balanced, Cd and Cl will be too small and moments in to or out of the symmetry plane will appear when none should be generated.
Here is a patch I have been meaning to submit. It recognises three variables in the forces dict which switch on symmetry planes in the forces code across the coordinate axes.
diff --git a/src/postProcessing/forces/forceCoeffs/forceCoeffs.C b/src/postProcessing/forces/forceCoeffs/forceCoeffs.C
index 86de02e..1c0bc82 100644
--- a/src/postProcessing/forces/forceCoeffs/forceCoeffs.C
+++ b/src/postProcessing/forces/forceCoeffs/forceCoeffs.C
@@ -112,9 +112,20 @@ void Foam::forceCoeffs::write()
vector totForce = fm.first().first() + fm.first().second();
vector totMoment = fm.second().first() + fm.second().second();
- scalar liftForce = totForce & liftDir_;
- scalar dragForce = totForce & dragDir_;
- scalar pitchMoment = totMoment & pitchAxis_;
+ vector sumTotForce = totForce;
+ vector sumTotMoment = totMoment;
+ if (symmetryX_) sumTotForce += vector(-sumTotForce.x(), sumTotForce.y(), sumTotForce.z());
+ if (symmetryY_) sumTotForce += vector(sumTotForce.x(), -sumTotForce.y(), sumTotForce.z());
+ if (symmetryZ_) sumTotForce += vector(sumTotForce.x(), sumTotForce.y(), -sumTotForce.z());
+ if (symmetryX_) sumTotMoment += vector(sumTotMoment.x(), -sumTotMoment.y(), -sumTotMoment.z());
+ if (symmetryY_) sumTotMoment += vector(-sumTotMoment.x(), sumTotMoment.y(), -sumTotMoment.z());
+ if (symmetryZ_) sumTotMoment += vector(-sumTotMoment.x(), -sumTotMoment.y(), sumTotMoment.z());
+ scalar liftForce = sumTotForce & liftDir_;
+ scalar dragForce = sumTotForce & dragDir_;
+ scalar pitchMoment = sumTotMoment & pitchAxis_;
scalar Cl = liftForce/(Aref_*pDyn);
scalar Cd = dragForce/(Aref_*pDyn);
diff --git a/src/postProcessing/forces/forces/forces.C b/src/postProcessing/forces/forces/forces.C
index 433ef1e..e06cdff 100644
--- a/src/postProcessing/forces/forces/forces.C
+++ b/src/postProcessing/forces/forces/forces.C
@@ -147,6 +147,9 @@ Foam::forces::forces
obr_(obr),
active_(true),
log_(false),
+ symmetryX_(false),
+ symmetryY_(false),
+ symmetryZ_(false),
patchSet_(),
pName_(""),
Uname_(""),
@@ -183,6 +186,18 @@ void Foam::forces::read(const dictionary& dict)
log_ = dict.lookupOrDefault<switch>("log", false);
+ symmetryX_ = dict.lookupOrDefault<switch>("symmetryX", false);
+ symmetryY_ = dict.lookupOrDefault<switch>("symmetryY", false);
+ symmetryZ_ = dict.lookupOrDefault<switch>("symmetryZ", false);
+ if (symmetryX_ && symmetryY_ && symmetryZ_)
+ active_ = false;
+ WarningIn("void forces::read(const dictionary& dict)")
+ << "Three planes of symmetry is a trivial case"
+ << endl;
const fvMesh& mesh = refCast<const>(obr_);
patchSet_ =
diff --git a/src/postProcessing/forces/forces/forces.H b/src/postProcessing/forces/forces/forces.H
index 7b03805..cd8ac0d 100644
--- a/src/postProcessing/forces/forces/forces.H
+++ b/src/postProcessing/forces/forces/forces.H
@@ -121,6 +121,9 @@ protected:
//- Switch to send output to Info as well as to file
Switch log_;
+ //- Switches to turn on symmetry planes
+ Switch symmetryX_, symmetryY_, symmetryZ_;
// Read from dictonary
//- Patches to integrate forces over
rsamuel is offline   Reply With Quote
Old   February 15, 2009, 07:04
  #82
Richard Samuel
Patel,
obr_(obr),
active_(true),
log_(false),
patchSet_(),
pName_(""),
Uname_(""),
+ active_ = false;
+ << endl;
patchSet_ =
Switch log_;
Old   February 15, 2009, 10:14
Default Hi.. Richard Thanks for rep
  #83
mehulkumar is on a distinguished road
Hi.. Richard
Thanks for reply.
I have not used symmetry boundary type. (As given in paper from which I adopt problem to try.) It required to give top and bottom as a free stream condition.
I think I am giving some wrong BC, which is not physical !!!
I also tried with same mesh and BCs in FLUENT to validate the result.
Almost Cd Cl graph pattern is same as OF, but this results are not at all acceptable.(Its horrible!!!)
See this velocity plot at t=21s:
my Cd value plot:
paper's Cd plot:
If I am clear give me some suggestion.
I can also give paper for ur refrence.
mehulkumar is offline   Reply With Quote
Old   February 15, 2009, 10:17
  #84
Hi.. Richard
Thanks for reply.
my Cd value plot:
paper's Cd plot:
Old   February 17, 2009, 04:46
Default Hi foamers i would like to
  #85
antonio segalini
antonio_ing is on a distinguished road
Hi foamers
i would like to measure the torque in a certain patch which belongs to a rotating 2d region. I simulate a turbulent flow (with a standard kepsilon model) around some rotating airfoils with a sliding interface method (indeed I am using turbDyMFoam). How can i measure the torque?
thanks in advance
antonio_ing is offline   Reply With Quote
Old   February 17, 2009, 04:50
Default is it different from the nonro
  #86
antonio segalini
is it different from the nonrotating case?
Old   February 17, 2009, 14:09
Default Hi Patel, when you send me
  #87
Daniel Harlacher
harly is on a distinguished road
Hi Patel,
when you send me your case and the paper you are using I will take a look - when you search the forum you will find a lot of questions from myself on square cylinders - but never a quite satisfying answer - but I managed to get "steady" vortex shedding and not what you plotted so maybe I can find something.
openfoam.messageboard at gmail.com
And now the GENERAL QUESTION:
Is it possible to define a second liftDir ?? I am simulating flow around a 3D sphere and need all coefficients ...
Thanks
- harly
harly is offline   Reply With Quote
Old   February 18, 2009, 00:23
Default Hi..Daniel I am herewith gi
  #88
Hi..Daniel
I am herewith giving my case folder and paper inside it.(I have made grid:51x62 as given in paper.)
If you get any insight pls. reply me ..
Thanks for reply.
Old   February 18, 2009, 01:34
Default Hi..Deniel. Sorry!! I was not
  #89
Hi..Deniel.
Sorry!! I was not able to upload files together due to file size restriction.
For your problem I am not clear about the word "second liftDir".Can you give insight?
Here is a link for paper which I followed:
http://www.esnips.com/doc/d62fcd4c-af89-430c-8400-5d325df3c11c/A-numerical-study -of-vortex-shedding-from-rectangles
Thanks
Old   February 18, 2009, 01:44
Default Sorry!!I failed again so uploa
  #90
Sorry!!I failed again so upload all think on following link.
http://www.esnips.com/web/patelmehulkumarlsStuff
Old   February 18, 2009, 10:44
Default Hi all. Im newby with OpenF
  #91
Johannes Mauss
mauss is on a distinguished road
Hi all.
Im newby with OpenFoam and experience some difficulties. I hope one of you can help me.
Im running simulation (single and parallel) with simpleFoam. Everything is fine until I try to use this force util. The directory "forces" and the file containing the forces for each iteration is created but when finalizing the run (it does not matter if it is a single or parallel run) OpenFoam crashes with the error message:
End
Finalising parallel run
*** glibc detected *** simpleFoam: corrupted double-linked list: 0x00000000033e1e30 ***
*** glibc detected *** simpleFoam: free(): invalid pointer: 0x00000000036cff10 ***
======= Backtrace: =========
/lib64/libc.so.6[0x2ba07ca6521d]
/lib64/libc.so.6[0x2ba07ca66c55]
/lib64/libc.so.6(cfree+0x76)[0x2ba07ca66f76]
/opt/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/libstdc++.so.6(_ZNSsD 2Ev+0x3d)[0x2ba07c32573d]
/lib64/libc.so.6(__cxa_finalize+0x85)[0x2ba07ca2a6f5]
/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASModels.so[0x2 ba07a3a3506]
======= Memory map: ========
00400000-0045a000 r-xp 00000000 08:03 1553025 /opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/simpleFoam
00659000-0065b000 r--p 00059000 08:03 1553025 /opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/simpleFoam
0065b000-0065c000 rw-p 0005b000 08:03 1553025 /opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/simpleFoam
0065c000-0376d000 rw-p 0065c000 00:00 0 [heap]
2ba07a132000-2ba07a14e000 r-xp 00000000 08:03 2480754 /lib64/ld-2.6.1.so
2ba07a14e000-2ba07a150000 rw-p 2ba07a14e000 00:00 0
2ba07a34d000-2ba07a34f000 rw-p 0001b000 08:03 2480754 /lib64/ld-2.6.1.so
2ba07a34f000-2ba07a541000 r-xp 00000000 08:03 1077801 /opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASModels.so
2ba07a541000-2ba07a740000 ---p 001f2000 08:03 1077801 /opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libin/lib64/libc.so.6[0x2b5dc251b 21d]
2ba07a740000-2ba07a745000 r--p 001f1000 08:03 1077801 /opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASModels.so
2ba07a745000-2ba07a748000 rw-p 001f6000 08:03 1077801 /opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASModels.so
2ba07a748000-2ba07a7ab000 r-xp 00000000 08:03 1077799 /opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleTransportModels. so
. . . . and so on.
I thougt it might be a problem of the simpleFoam solver and had a try with turbFoam but the same problem ocuured.
Any ideas?
Thanks in advance for any help.
Johannes
mauss is offline   Reply With Quote
Old   February 19, 2009, 09:14
Default Pls..guide me...look after my
  #92
Pls..guide me...look after my case file and suggest me where I am wrong.
I am trying with some what finer mesh..but still not much improvement..
Thanks
Old   February 23, 2009, 14:22
Default To answer Leonardo Honfi Camil
  #93
Wolfgang Heydlauff
wolle1982 will become famous soon enough
To answer Leonardo Honfi Camilo's quastion of how to calculate forces of multiple patches in a case.
you need to define in the controlDict
patches (front middle rear);
so it's separated by a simple blank, not by comma.
Furthermore see snappyHexMesh example in thread
http://www.cfd-online.com/OpenFOAM_D...s/1/11251.html
wolle1982 is offline   Reply With Quote
Old   February 27, 2009, 16:09
  #94
antonio segalini
Hi foamers
i would like to measure the torque in a certain patch which belongs to a rotating 2d region. I simulate a turbulent flow (with a standard kepsilon model) around some rotating airfoils with a sliding interface method (indeed I am using turbDyMFoam). How can i measure the torque?. It is different from the non rotating case?
i tried with the force and forcecoeffs function as described above but the moment, which should be oriented principally along the z direction (it is a 2d case) is instead fully 3d(i.e.Mx is of the same order of magnitude of My and Mz), so completely unphysical!
thanks in advance for any advice
Old   February 27, 2009, 18:41
Default Hi FOAMers, I am wondering
  #95
BastiL
bastil is on a distinguished road
Hi FOAMers,
I am wondering if you can use some kind of regex to match your patch names? I have models with lots of patches and I tried:
patches (surface*) to match all patches starting with surface. SimpleFOAM does not conplain about it but results look strange.
Regards.
bastil is offline   Reply With Quote
Old   February 28, 2009, 05:39
Default Hi, Foamers There is a bug
  #96
ssp
Sopheak Seng
ssp is on a distinguished road
Hi, Foamers
There is a bug in the way "forces" handle multiple patches. I'm using OF 1.5.
If you have two patches e.g. B6 and B666 and you define
patches (B6);
then "forces" will include both patches in the calculation, simply because B666 contains the substring B6. If you name the two patches differently, e.g. B6 and A666, then "forces" will behave as it should.
This is a serious bug. Can someone please confirm this behavior? I don't know how to fix it but i have made some ugly changes in the source code to overcome this problem.
Sopheak
ssp is offline   Reply With Quote
Old   February 28, 2009, 19:42
Default Hi Antonio, I know this i
  #97
John Wang
cwang5 is on a distinguished road
Hi Antonio,
I know this is kind of off topic, but I'm wondering if you can shad some light on the boundary setup for the rotating airfoil to me? I could not seems to find any tutorials or example that deals with a rotating airfoil.
Thanks
John
cwang5 is offline   Reply With Quote
Old   March 2, 2009, 05:20
Default actually that was slightly tri
  #98
antonio segalini
actually that was slightly tricky, but i managed to do the simulation because someone explained me the procedure in the post:
SlidingInterface problem
i had to install openfoam-1.5-dev as explained in the post in the installation section in the post:
Installation of OpenFOAM-1.5-dev
hope this helps
Old   March 2, 2009, 19:25
Default Hallo,PO I have included your
  #99
Hai Yu
yuhai is on a distinguished road
Hallo,PO
I have included your paragraph in foamLog, but I can get the result of only one line in file:
#Time FpX FpY FpZ FvX FvY FvZ MpX MpY MpZ MvX MvY MvZ
And no data followed at all, while, in forces.Dat, everything seems OK.
I don't know what is the reason.
well, thx in advance.
yuhai is offline   Reply With Quote
Old   March 6, 2009, 01:16
Default Hi Antonio, Humm...could
  #100
John Wang
Hi Antonio,
Humm...could you post the links to the posts you mentioned? I can't seems to find those threads using Search in the forum. Thanks
John
CoupledFvScalarMatrix in OF15 fisher OpenFOAM Running, Solving & CFD 9 May 27, 2020 10:40
Fan type BC in OF15 hsieh OpenFOAM Running, Solving & CFD 31 July 30, 2015 13:22
Bug in patchIntegrateC OF15 anger OpenFOAM Bugs 8 May 29, 2009 05:36
OpenFOAMdev migration to OF15 fisher OpenFOAM Installation 1 November 25, 2008 15:39
Bug or a feature of OF15 rafal OpenFOAM Bugs 5 July 25, 2008 06:25
