Writing y
Old   August 22, 2008, 13:35
Default "I realised what was wrong. In
  #21
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
"I realised what was wrong. In my boundary file, the type of my wall boundaries was set to "patch". When I changed them to "wall" everything works fine. Thanks for taking the time to help me. "
thank you for reporting that, I had the same problem with yPlusRAS.
louisgag is offline   Reply With Quote
Old   September 25, 2008, 07:53
Default Hi, I am unable to get y+ usi
  #22
Vishal Jambhekar
vishal is on a distinguished road
I am unable to get y+ using checkYPlus utility command
it throws me an error as command not found.
I am currently working on suse linur operating system.
Please help me in this matter.
Thanks
VIshal
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   September 25, 2008, 08:01
Default Hi, i have also downloaded
  #23
Vishal Jambhekar
i have also downloaded and kept the chechyPlusCompressible.C file and Make file
can any one please tell me where is the exact location to place it and do i have to compile the entire program again.
Thanks
Vishal
Cheers,
Vishal Jambhekar...
Old   September 25, 2008, 11:11
Default Hi Vishal, If you are using
  #24
louisgag's Avatar
Louis Gagnon
Hi Vishal,
If you are using OF 1.5 the utilities to check yplus are yPlusLES and YplusRAS.
regards,
-Louis
Old   February 19, 2009, 06:43
Default Dear all!! I adapted the yP
  #25
Aram Amouzandeh
mabinty is on a distinguished road
Dear all!!
I adapted the yPLusRAS utility for a compressible case (yPLusRASCompressible) and it seems to work (at least I believe so ...). As I m currently working with a multi region solver (chtMultiRegionFoam) I need to adapt it further, so that yPlus is calculated/written only in the fluid region. I couldn t figure out yet how to realize that yPLusRASCompressible follows the structure of the time directories "timeName/fluidRegionName" (e.g. 51/topAir) to access the needed fields for the calculation of yPLaus in the fluidRegionName region. I would greatly appreciate any hint on that! Thx in advance,
Aram
mabinty is offline   Reply With Quote
Old   February 27, 2009, 05:55
Default Hi!! I managed to make yPLu
  #26
Aram Amouzandeh
Hi!!
I managed to make yPLusRASCompressible to follow the structure of the time directories and the code compiles now. But when executing the utility
I get the error message shown below at the point where thermophysical properties are read:
Time = 1.001
Reading field p
Reading thermophysical properties
Selecting thermodynamics package hThermo>>>>
Not Implemented
Trying to construct an genericFvPatchField on patch air_to_ceiling of
field h#0 Foam::error::printStack(Foam:stream&) in
"/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in
#2 Foam::genericFvPatchField::genericFvPatchField(Foa m::fvPatch
const&, Foam::DimensionedField const&) in
"/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#3 Foam::fvPatchField::addpatchConstructorToTable >::New(Foam::fvPatch
#4 Foam::fvPatchField::New(Foam::word const&, Foam::fvPatch const&,
Foam::DimensionedField const&) at
~/OpenFOAM/OpenFOAM-1.5.x/src/finiteVolume/lnInclude/newFvPatchField.C:70
Foam::GeometricField::GeometricBoundaryField::Geom etricBoundaryField(Fo am::fvBoundaryMesh const&, Foam::DimensionedField const&, Foam::List const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so"
#6 Foam::GeometricField::GeometricField(Foam::IOobjec t const&,
Foam::fvMesh const&, Foam::dimensionSet const&, Foam::List const&) in
#7 Foam::hThermo > > > >::hThermo(Foam::fvMesh const&) in
#8 Foam::basicThermo::addfvMeshConstructorToTable > > > >
> >::New(Foam::fvMesh const&) in
#9 Foam::basicThermo::New(Foam::fvMesh const&) in
#10 main at
~/OpenFOAM/aa-1.5.x/applications/yPlusRASCompMultiRegion/yPlusRASCompMultiRegion .C:152
#11 __libc_start_main in "/lib/libc.so.6"
#12 _start in
"/home/aa/OpenFOAM/aa-1.5.x/applications/bin/linux64GccDPOpt/yPlusRASCompMultiRe gion"
>From function genericFvPatchField::genericFvPatchField(const fvPatch&
p, const DimensionedField& iF)
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at
line 45.
FOAM aborting
Aborted
It seems to be a problem with the patch-type of the fluid-solid interface introduced by splitMeshRegions (is this a simple patch or wall ..??). I dug a bit in genericFvPatchField.C and basicThermo.C/.H but couldn t figure out yet what's wrong. Could anybody give me a suggestion please!!
Thx in advance!
Aram
Old   March 10, 2009, 11:11
Default Dear all!! I was searching
  #27
Aram Amouzandeh
Dear all!!
I was searching a bit in the forum and found an entry explaining the error message I received (http://www.cfd-online.com/OpenFOAM_D...ges/1/593.html). So it seems that the solid-fluid interface air_to_ceiling is a default or generic patch field, and hence does not know how to evaluate itself, but what in turn would be necessary to calculated an enthalpy field h (by basicThermo). Isn t it? Unfortunately I haven t found a solution to this problem yet but keep on digging. Appreciate any comments!!
Thx in advance,
Aram
Old   July 17, 2009, 05:40
Sebastian Krick
sebastiank is on a distinguished road
Originally Posted by mabinty View Post
Dear all!!
Aram
Dear Mabinty,
I'am currently struggeling on adapting the yPlusRAS utility for a compressible case, in my case, rhoPorousSimpleFoam. How did you adapt yPlusRAS in order to get it to work with a compressible case ?
Regards,
Sebastian
sebastiank is offline   Reply With Quote
Old   July 19, 2009, 09:32
Aram Amouzandeh
Hi Sebastian!
You have to use a compressible RASModel:
# include "compressibleCreatePhi.H"
autoPtr<compressible::RASModel> RASModel
compressible::RASModel::New(rho, U, phi, thermo())
Study the code Bernhard posted in this thread some while ago (checkYplusCompressible).
All the best,
Aram
Old   June 1, 2010, 07:55
Francois Gallard
fgal is on a distinguished road
Hi everybody,
I would like to compute Delta Y+ (first cell height scaled by intern zone scales) to know which boundary condition to set to k (zero gradient or uniform 0.0).
I am using a compressible LES solver, so I tried the yPlusLES utility but it needs nuSgs, so to be adapted for incompressible cases. How can I solve that problem ? Do I need to modify yPlusLES and divide muSgs by rho ?
thanks
Francois
fgal is offline   Reply With Quote
New with writing UDF/Need help pls mac FLUENT 6 June 14, 2007 07:11
New to writing UDF Sandilya FLUENT 0 May 31, 2007 13:03
UFD writing help Nelly FLUENT 1 January 19, 2007 12:29
Writing geometry Dadou Siemens 0 March 15, 2004 12:34
error while writing bc Theju FLUENT 3 March 8, 2002 14:20
