August 11, 2015, 11:14 |
#121 |
Rep Power: 11 |
hi my friends,
what should i do to reach high compression ratio in kivaTest? what's the role of the clearance and conRodLength ? thanks in advance ---- hi nishio, you can change stoichiometricAirFuelMassRatio stoichiometricAirFuelMassRatio [ 0 0 0 0 0 0 0 ] 15.0336; to any value that you want Last edited by wyldckat; August 18, 2015 at 16:10. Reason: merged posts that were a couple of hours apart |
August 18, 2015, 07:33 |
engineFoam
#122 |
Rep Power: 11 |
hi ,
I want to run the blow case in kivaTest, Engine Specifications Engine Bore=81 mm Stroke=88 mm Displaced Volume=453.46 cm 3 Clearance Volume=27.82 cm 3 Compression Ratio=17.3 : 1 but I receive Vmax = 0.000631297, Vmin = 4.65038e-05 Vmax/Vmin = 13.5752 and when I want to run i receive from log , Mean pressure:6.29685e+59 Mean temperature:2847.02 Mean u':203.613 ExecutionTime = 125.73 s ClockTime = 126 s Courant Number mean: 5.68007e+36 max: 1.72382e+40 Crank angle = -20.75 CA-deg deltaZ = 8.60734e-05 clearance: 0.00125427 Piston speed = 3.30522 m/s diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.15084, Final residual = 6.32512e-06, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.529e-06, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.998471, Final residual = 3.86051e-06, No Iterations 3 DILUPBiCG: Solving for ft, Initial residual = 0.998068, Final residual = 2.16875e-06, No Iterations 2 PLEASE help me. |
August 18, 2015, 16:26 |
#123 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answers:
Quoting from the source code: https://raw.githubusercontent.com/Op...e/engineTime.H Code:
//- Return the engines connecting-rod length const dimensionedScalar& conRodLength() const { return conRodLength_; } //- Return the engines bore const dimensionedScalar& bore() const { return bore_; } //- Return the engines stroke const dimensionedScalar& stroke() const { return stroke_; } //- Return the engines clearance-gap const dimensionedScalar& clearance() const { return clearance_; } Code:
conRodLength_(dimensionedScalar("conRodLength", dimLength, 0)), bore_(dimensionedScalar("bore", dimLength, 0)), stroke_(dimensionedScalar("stroke", dimLength, 0)), clearance_(dimensionedScalar("clearance", dimLength, 0)) -------------- Quote:
edit: duplicate question had been asked... will address the topic to here: http://www.cfd-online.com/Forums/ope...tml#post560504 Last edited by wyldckat; August 21, 2015 at 08:41. Reason: see "edit:" |
August 23, 2015, 10:02 |
#124 |
Rep Power: 11 |
hi wyldckat,
1)Bore=0.081 ,Stroke=0.088 2)no i didn't |
August 23, 2015, 13:16 |
#125 |
Bruno Santos
Rep Power: 128 |
That didn't answer my question. But it doesn't matter, because your questions on this topic are being answered in this thread: http://www.cfd-online.com/Forums/ope...ilitities.html - and on that thread you provided more details, some of which answered my previous questions.
January 6, 2016, 10:00 |
#126 |
Sean
Rep Power: 11 |
hi my friend,
Would you please send the 5-steps ch4/air mechanism to me? my email address:13903423r@connect.polyu.hk. Thank you so much! Sean |
June 24, 2016, 07:16 |
#127 |
AdOo
Rep Power: 10 |
Hi all,
I'm completely new on combustion, so I would like to apologize first for my lake of knowledge, and the stupidity I will probably write. FIRST: I was wondering if one of you has the documents posted by Mr. Weller at the very beginning of that topic. (Because of the age of this topic the links aren't still available sadly...). SECOND: Without any disrespect (on the contrary, I admire the work that has been done), because of the age of this model, is there nowadays any new model (usable in RANS simulation) that are now more efficient to model the turbulent flame speed than the Weller one ? FIRD: This question is more personal. In fact I'm a student in internship, and my tutor want me to simulate explosion on large scale simulation (on tunnel about 10 meters) (in order to compare the result to the FLACS code one). Do you think that XiFoam would be appropriate for that type of simulation ? Thank you, Adrien. |
combustion model in premixed combustion chamber | wuyu | FLUENT | 9 | February 16, 2018 11:40 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 19:40 |
Sawdust Combustion-Non-premixed Combustion Model | Jessy | FLUENT | 1 | June 19, 2007 11:59 |
combustion in internal combustion engine | George | Main CFD Forum | 0 | September 7, 2006 15:41 |
combustion | prasat | Main CFD Forum | 1 | June 16, 2003 14:17 |
