Nonconservative gammaEqn
Like Tree2Likes
Old   April 22, 2009, 12:50
Default pressure decomposition
  #21
Elisabet Mas de les Valls
elisabet is on a distinguished road
Hi Kyian,
As always, you should go to the sources. In this case:
OpenFOAM-1.5.x/applications/solvers/heatTransfer/buoyantSimpleFoam/UEqn.H
there, you would see that both the pressure gradient term and the body force term, which in its most general form are:
-grad(p) + rho*g
become
-fvc::grad(pd) - fvc::grad(rho)*gh
this transformation is straight forward if you consider p=pd+rho*g*h+pref
In this case, rho is obtained from the "basicThermo" object (see createFields.H), and hence, depends on the equation of state defined there. You should go to basicThermo sources to know more about it.
Good luck,
elisabet
elisabet is offline   Reply With Quote
About the gammaEqn in interFoam sandy OpenFOAM Running, Solving & CFD 14 March 19, 2014 10:30
GammaEqn and UEqn in interFoam adekian OpenFOAM Running, Solving & CFD 1 April 11, 2007 03:03
about the nonconservative equation and FVM maximus Main CFD Forum 3 March 4, 2006 16:45
