#21 |
Hae-Won Choi
Rep Power: 17 ![]() |
Anybody have parallelize for chtMultiRegionFoam for tutorial in OpenFOAM-1.5.x?
If anyone have an experience, can share your experience? Thanks. |
#22 |
Niranjan Ghaisas
Hi
I am trying to run the tutorial case multiRegionHeater.tgz provided by Mattijs and the problem I face is that the command splitMeshRegions does not recognize cellZones as an argument. If I simply run splitMeshRegions without -cellZones, the program says there is only 1 region and dosent do anything, What could I be doing wrong? Thanks in advance for any help. |
#23 |
Tobias Holzinger
Hi Niranjan,
sure you used the command in the right folder?? What is the output of your setsTozones command?
Tobias Holzinger Chair of Thermodynamics, TU München |
#24 |
Niranjan Ghaisas
Hi Tobias
The output of setsToZones is givern below. I am running all commands in the case directory ($FOAM_USR_TUTORIAL/chtMultiRegionFoam/multiRegionHeater) Thanks Niranjan \*---------------------------------------------------------------------------*/ Exec : setsToZones -noFlipMap Date : Nov 17 2008 Time : 04:51:26 Host : localhost.localdomain PID : 19964 Case : /home/niranjan/OpenFOAM/OpenFOAM-1.5/tutorials/chtMultiRegionFoam/multiRegionHea ter nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Seached : "constant/polyMesh/sets" Found : 5 ( topAir heater bottomAir rightSolid leftSolid ) pointSets: 0 ( ) cellSets: 5 ( heater topAir leftSolid bottomAir rightSolid ) faceSets: 0 ( ) Writing mesh. End |
#25 |
Tobias Holzinger
Hi Niranjan,
My output is after cellSets: Adding set heater as a cellZone. Adding set topAir as a cellZone. Adding set leftSolid as a cellZone. Adding set bottomAir as a cellZone. Adding set rightSolid as a cellZone. so there seems to be an error before... did you manipulate the cell regions?? Did your setSet run well (any region sets w/o cells)?
#26 |
Mahendra
hi Niranjan..
Do u have the ChtMultiRegionFoam tutorial? I was unable to download it. If you have can you please send it to me at mahendra.wankhede@gmail.com Where in Pune do you reside and what do you do? Regards, Mahendra |
#27 |
Niranjan Ghaisas
Tobias,
I executed the script Allrun as it is and I faced this problem. The log files generated are given below. From log.setSet, you can see that there is no error. But it does not give the output you've mentioned either. I havent changed anything manually. I did try to open files in constant/ and constant/polyMesh/sets directories to try to make some sense, but I havent modified anything. Thanks and regards Niranjan log.blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh Date : Nov 17 2008 Time : 06:10:31 Host : localhost.localdomain PID : 20959 Case : /home/niranjan/OpenFOAM/niranjan-1.5/tutorials/multiRegionHeater nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Writing polyMesh end log.setSet /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : setSet -batch makeCellSets.setSet Date : Nov 17 2008 Time : 06:10:32 Host : localhost.localdomain PID : 20960 Case : /home/niranjan/OpenFOAM/niranjan-1.5/tutorials/multiRegionHeater nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time:0 cells:3000 faces:9700 points:3751 patches:6 Reading commands from file "makeCellSets.setSet" Please type 'help', 'quit' or a set command after prompt. Doing:"cellSet heater new boxToCell (-0.01 0 -100 )(0.01 0.01 100)" Set:heater Size:0 Action:new Adding cells with center within box (-0.01 0 -100) (0.01 0.01 100) Writing heater (size 40) to "constant/polyMesh/sets/heater" and to vtk file "VTK/heater/heater_1.vtk" Doing:"cellSet heater add boxToCell (-0.01 -100 -0.01)(0.01 0.01 0.01)" Set:heater Size:40 Action:add Backing up heater into heater_old Adding cells with center within box (-0.01 -100 -0.01) (0.01 0.01 0.01) Writing heater (size 80) to "constant/polyMesh/sets/heater" and to vtk file "VTK/heater/heater_1.vtk" Doing:"cellSet leftSolid new boxToCell (-100 0 -100 )(-0.01 0.01 100)" Set:leftSolid Size:0 Action:new Adding cells with center within box (-100 0 -100) (-0.01 0.01 100) Writing leftSolid (size 130) to "constant/polyMesh/sets/leftSolid" and to vtk file "VTK/leftSolid/leftSolid_1.vtk" Doing:"cellSet rightSolid new boxToCell (0.01 0 -100 )(100 0.01 100)" Set:rightSolid Size:0 Action:new Adding cells with center within box (0.01 0 -100) (100 0.01 100) Writing rightSolid (size 130) to "constant/polyMesh/sets/rightSolid" and to vtk file "VTK/rightSolid/rightSolid_1.vtk" Doing:"cellSet topAir new boxToCell (-100 0.01 -100 )(100 100 100)" Set:topAir Size:0 Action:new Adding cells with center within box (-100 0.01 -100) (100 100 100) Writing topAir (size 1200) to "constant/polyMesh/sets/topAir" and to vtk file "VTK/topAir/topAir_1.vtk" Doing:"cellSet bottomAir clear" Set:bottomAir Size:0 Action:clear Writing bottomAir (size 0) to "constant/polyMesh/sets/bottomAir" and to vtk file "VTK/bottomAir/bottomAir_1.vtk" Doing:"cellSet bottomAir add cellToCell heater" Set:bottomAir Size:0 Action:add Adding all elements of cellSet heater ... Writing bottomAir (size 80) to "constant/polyMesh/sets/bottomAir" and to vtk file "VTK/bottomAir/bottomAir_1.vtk" Doing:"cellSet bottomAir add cellToCell leftSolid" Set:bottomAir Size:80 Action:add Backing up bottomAir into bottomAir_old Adding all elements of cellSet leftSolid ... Writing bottomAir (size 210) to "constant/polyMesh/sets/bottomAir" and to vtk file "VTK/bottomAir/bottomAir_1.vtk" Doing:"cellSet bottomAir add cellToCell rightSolid" Set:bottomAir Size:210 Action:add Backing up bottomAir into bottomAir_old Adding all elements of cellSet rightSolid ... Writing bottomAir (size 340) to "constant/polyMesh/sets/bottomAir" and to vtk file "VTK/bottomAir/bottomAir_1.vtk" Doing:"cellSet bottomAir add cellToCell topAir" Set:bottomAir Size:340 Action:add Backing up bottomAir into bottomAir_old Adding all elements of cellSet topAir ... Writing bottomAir (size 1540) to "constant/polyMesh/sets/bottomAir" and to vtk file "VTK/bottomAir/bottomAir_1.vtk" Doing:"cellSet bottomAir invert" Set:bottomAir Size:1540 Action:invert Backing up bottomAir into bottomAir_old Writing bottomAir (size 1460) to "constant/polyMesh/sets/bottomAir" and to vtk file "VTK/bottomAir/bottomAir_1.vtk" End of batch file End log.setsToZones /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : setsToZones -noFlipMap Date : Nov 17 2008 Time : 06:10:32 Host : localhost.localdomain PID : 20962 Case : /home/niranjan/OpenFOAM/niranjan-1.5/tutorials/multiRegionHeater nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Seached : "constant/polyMesh/sets" Found : 5 ( topAir heater bottomAir rightSolid leftSolid ) pointSets: 0 ( ) cellSets: 5 ( heater topAir leftSolid bottomAir rightSolid ) faceSets: 0 ( ) Writing mesh. End log.splitMeshRegions /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Usage: splitMeshRegions [-insidePoint point] [-case dir] [-parallel] [-largestOnly] [-help] [-doc] [-srcDoc] Invalid option: -cellZones FOAM exiting |
#28 |
Tobias Holzinger
Dear Niranjan,
my output looks quite different. Typing splitMeshRegions -help I get some output like this: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Usage: splitMeshRegions [-cellZones] [-blockedFaces faceSet] [-overwrite] [-insidePoint point] [-case dir] [-parallel] [-largestOnly] [-makeCellZones] [-help] [-doc] [-srcDoc] and the splitting works very well. Are you sure, you installed OF properly? Regards Tobias
#29 |
Mahendra
Dear All,
The case multiRegionHeater ran sucessfully when i executed the commands one by one. And when I exported the mesh and result files to fluent, using "foamMeshToFluent" and foamDataToFluent" I got nothing to see. Also the mesh file shows only minimum and maximum boundaries and no split regions. Can anyone guide me to the problem and it's resolution. Thanks and Regards, Mahendra |
#30 |
Niranjan Ghaisas
Hi Tobias.
There was some problem with my installation. The case ran successfully when I tried it on a different machine. Thanks for your help. Mahendra, the answer to your question is there in this thread itself in a post by Andrea. Niranjan |
#31 |
Mahendra
hi Niranjan...
I was asking for viewing the results and mesh from OpenFOAM into Fluent. Mahendra. |
#32 |
Mattijs Janssens
Rep Power: 26 ![]() |
The cht solver uses multiple 'regions'. These get stored as separate subdirectories inside the time directories. Compare the time directories to those of e.g. the cavity tutorial.
Some postprocess tools have a '-region' option to specify which region to work on (e.g. foamToVTK). I don't think foamMeshToXXX has such an option so you'll have to copy the mesh and data (of the region you want to look at) to a separate case. See also http://openfoamwiki.net/index.php/Ho...rocMultiregion. |
#33 |
Niranjan Ghaisas
Mahendra,
An oversight... sorry ![]() |
#34 |
Tobias Holzinger
i managed refining a part of the tutorial grid. I just did some manipulations: adding two files called "cellSetDict.1" and "refineMeshDict" in the system directory. "cellSetDict.1" should look like this: -------------------------------------------------------------------------------- -------------------- /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object cellSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // name c0; action new; topoSetSources ( boxToCell { box (0.01 -100 -0.02)(0.02 0 0.02); } ); // ************************************************** *********************** // -------------------------------------------------------------------------------- -------------------- The refineMeshDict" file looks like this: -------------------------------------------------------------------------------- -------------------- /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*------------------------------------------------------------------------------ -------------*/ FoamFile { version 2.0; format ascii; class dictionary; object refineMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // set c0; coordinateSystem global; globalCoeffs { tan1 (1 0 0); tan2 (0 1 0); } directions ( tan1 tan2 normal ); useHexTopology yes; geometricCut no; writeMesh no; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // -------------------------------------------------------------------------------- -------------------- Second, I manipulated Allun: -------------------------------------------------------------------------------- ---- #* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *# #!/bin/sh # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions refineMeshByCellSet() { echo "creating cell set for primary zone - $1" cp system/cellSetDict.$1 system/cellSetDict cellSet >& log.cellSet.$1 echo "refining primary zone - $1" refineMesh -dict -overwrite >& log.refineMesh.$1 rm constant/polyMesh/sets/*_old } rm -r constant/polyMesh/sets runApplication blockMesh runApplication setSet -batch makeCellSets.setSet rm constant/polyMesh/sets/*_old runApplication setsToZones -noFlipMap refineMeshByCellSet 1 runApplication splitMeshRegions -cellZones changeDictionary -region bottomAir changeDictionary -region topAir changeDictionary -region heater changeDictionary -region leftSolid changeDictionary -region rightSolid runApplication chtMultiRegionFoam cp -r 0.001/bottomAir/polyMesh/ constant/bottomAir/. cp -r 0.001/topAir/polyMesh/ constant/topAir/. cp -r 0.001/heater/polyMesh/ constant/heater/. cp -r 0.001/leftSolid/polyMesh/ constant/leftSolid/. cp -r 0.001/rightSolid/polyMesh/ constant/rightSolid/. foamToVTK -region bottomAir foamToVTK -region topAir foamToVTK -region heater foamToVTK -region leftSolid foamToVTK -region rightSolid #* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *# -------------------------------------------------------------------------------- -------------------- and Allclean: -------------------------------------------------------------------------------- -------------------- #* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *# #!/bin/sh # Source tutorial clean functions . $WM_PROJECT_DIR/bin/tools/CleanFunctions rm -r VTK rm -rf constant/polyMesh/sets > /dev/null 2>&1 rm -rf 0/polyMesh > /dev/null 2>&1 rm system/cellSetDict > /dev/null 2>&1 cleanCase #* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *# -------------------------------------------------------------------------------- -------------------- ,that's it. Hope this helps. Tobias
#35 |
Tobias Holzinger
there is one thing coming up in my simulation? Is it possible to change the patch type for the Interface patch to wall directly?? I need this because otherwise, my turbulent wallfunctions won't be computed, will they? Which polyMesh/boundary file will be looked up and compared to?? Thanks Tobias
#36 |
Yibing Xin
Rep Power: 0 ![]() |
I got an error when trying the Allrun with the tutorial case. All suggestions/comments are appreciated. Thanks. /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : chtMultiRegionFoam Date : Dec 03 2008 Time : 08:57:30 Host : FMCompute04 PID : 25608 Case : /nfshome/xiny/OpenFOAM/OpenFOAM-1.5/tutorials/chtMultiRegionFoam/multiRegionHeat er nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region bottomAir for time = 0.001 Create fluid mesh for region topAir for time = 0.001 Create solid mesh for region heater for time = 0.001 Create solid mesh for region leftSolid for time = 0.001 Create solid mesh for region rightSolid for time = 0.001 *** Reading fluid mesh thermophysical properties for region bottomAir Adding to pdf Adding to thermof Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>> Adding to rhof Adding to Kf Not implemented#0 Foam::error::printStack(Foam: ![]() #1 Foam::error::abort() in "/nfshome/xiny/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::basicThermo::e() const in "/nfshome/xiny/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so" #3 main in "/nfshome/xiny/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/chtMultiRe gionFoam" #4 __libc_start_main in "/lib64/tls/libc.so.6" #5 Foam::regIOobject::readIfModified() in "/nfshome/xiny/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/chtMultiRe gionFoam" From function basicThermo::e() in file basicThermo/basicThermo.H at line 194. FOAM aborting (FOAM_ABORT set) |
#37 |
Vishal Nandigana
Rep Power: 18 ![]() |
Hi All,
I am new to Openfoam. I just downloaded the tutorial and would like to know where is the solidwallHeatflux boundary condition used in the tutorial. Can anyone help me out in explaining this. Because I have a case where I need to set B.cs given by the equation -D1*dC1/dn - K1*C1*dPhi/dn = 0 where n is the normal direction. I am solving a 2d system hence I want to set the flux in the y direction as zero. i.e -D1*dC1/dy - K1*C1*dPhi/dy = 0 where C1 and Phi are my variables. Can anyone suggest how exactly I have to go about incorporating this boundary condition. Thanks Regards Vishal |
#38 |
Aram Amouzandeh
Dear all!!
I would like to adapt yPlusRAS utility to calculated/written y+ only in the fluid region. I already managed (at least I believe so) to adapt yPlusRAS for a compressible case (yPLusRASCompressible). I tried to realize that yPLusRASCompressible follows the structure of the time directories "timeName/fluidRegionName" (e.g. 51/topAir) to access the needed fields for the calculation of yPlus in the fluidRegionName region. The problem occures when creating the "phi" field like: surfaceScalarField phi ( IOobject ( "phi", runTime.timeName(), fluidRegions[i], IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), linearInterpolate(rho[i]*U[i]) & fluidRegions[i].Sf() ); I get the following error message from the compiler: yPlusRASCompMultiRegion.C: In function 'int main(int, char**)': yPlusRASCompMultiRegion.C:176: error: no matching function for call to 'linearInterpolate(Foam::Vector<double>)' I wounder because the linearInterpolate-function should be available as included by -I$(LIB_SRC)/finiteVolume/lnInclude. I would greatly appreciate any hint on that! Thx in advance, Aram |
#39 |
Aram Amouzandeh
Dear all!!
#40 |
Aram Amouzandeh
Hi!!
The code compiles now after removing the indix [i] at rho and U to compute the phi field. But when executing the yPlusRASCompMultiRegion I get the error message shown below at the point where thermophysical properties are read: Time = 1.001 Reading field p Reading thermophysical properties Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>> Not Implemented Trying to construct an genericFvPatchField on patch air_to_ceiling of field h#0 Foam::error::printStack(Foam: ![]() #1 Foam::error::abort() in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::genericFvPatchField<double>::genericFvPatchF ield(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libfiniteVolume.so" #3 Foam::fvPatchField<double>::addpatchConstructorToT able<foam::genericfvpatchfield <double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double,> const&) at ~/OpenFOAM/OpenFOAM-1.5.x/src/finiteVolume/lnInclude/newFvPatchField.C:70 #5 Foam::GeometricField<double,>::GeometricBoundaryFi eld::GeometricBoundaryField(Fo am::fvBoundaryMesh const&, Foam::DimensionedField<double,> const&, Foam::List<foam::word> const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so" #6 Foam::GeometricField<double,>::GeometricField(Foam ::IOobject const&, Foam::fvMesh const&, Foam::dimensionSet const&, Foam::List<foam::word> const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so" #7 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::hThermo(Foam::fvMesh const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so" #8 Foam::basicThermo::addfvMeshConstructorToTable<foa m::hthermo<foam::puremixture<f oam::consttransport<foam::speciethermo<foam::hcons tthermo<foam::perfectgas> > > > > >::New(Foam::fvMesh const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so" #9 Foam::basicThermo::New(Foam::fvMesh const&) in "/home/aa/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libbasicThermophysicalMode ls.so" #10 main at ~/OpenFOAM/aa-1.5.x/applications/yPlusRASCompMultiRegion/yPlusRASCompMultiRegion .C:152 #11 __libc_start_main in "/lib/libc.so.6" #12 _start in "/home/aa/OpenFOAM/aa-1.5.x/applications/bin/linux64GccDPOpt/yPlusRASCompMultiRe gion" From function genericFvPatchField<type>::genericFvPatchField(con st fvPatch& p, const DimensionedField<type,>& iF) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 45. FOAM aborting Aborted I dug a bit in genericFvPatchField.C and basicThermo.C/.H but couldn t figure out yet what the error message tries to tell me. Could anybody give me a suggestion please!! Thx in advance! Aram |
---------Tutorial help | mech | FLUENT | 4 | May 16, 2007 02:43 |
tutorial 6 in Fluent 6.2 tutorial and Mesh | pilli4u | FLUENT | 2 | April 2, 2007 05:09 |
3D Tutorial | MJ | FLUENT | 0 | January 16, 2007 08:45 |
tutorial | masood yooceframandi | FLUENT | 1 | January 25, 2005 12:28 |
tutorial | adil | FLUENT | 0 | March 8, 2004 03:48 |
